vad är det för carsoft ? hittade ett " Description:
Digital total test: It gives you a complete idea of the overall condition of the car
Digital single test: It gives you detailed information about the appropriate control unit. Stored errors will be shown in a written report. This report has a short info-text which help you to eliminate the error.
Special functions for some models: Including service interval reset, component activation, live data, LCM reading, sync. EWS and ECU, adaptation values, and coding.
Compatible vehicle list:
E30 - 3 Series
DME ALL,DDE ALL
AB From 1998
BC/MID ALL,DWA ALL
E36-3 Series
DME ALL,DDE ALL
KOMBI Except kompakt
AB ALL,ABS ALL,ASC ALL,BC/MID ALL,DWA ALL
ZKE From 1994
ZVM Till 1994
HKL ALL,EGS ALL,EWS ALL
E46 - 3 Series
DME ALL,DDE ALL,KOMBI ALL,AB ALLlABS ALL,ASC ALL,DSC ALL,ZKE ALL,HKL ALL,EGS ALL,EWS ALL,LCM ALL,CCM ALL,PDC ALL,CVM ALL
Z3
DME ALL,AB ALL,ABS ALL,ASC ALL,ZKE ALL,HKL ALL,EGS ALL,EWS ALL
E34 - 5 Series
DME ALL,DDE ALL
KOMBI From 02/98
AB ALL,ABS From 1992,ASC From 1992,BC/MID ALL,DWA ALL,ZKE ALL,HKL ALL,EGS ALL,EWS ALL
E39 - 5 Series
DME ALL,DDE ALL,KOMBI ALL,AB ALL,ABS ALL,ASC ALL,DSC ALL,ZKE ALL,ZVM ALL,HKL ALL,EGS ALL,EWS ALL,LCM ALL,CCM ALL,PDC ALL
E53 - X5
E32 - 7 Series .... E38, E31, E52"
