17743/P1335 - Engine Torque Monitor 2: Control Limit Exceeded
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Reduced Power
Possible Causes
Intake hose(s) or intake system leaks (Unmetered Air) after MAF
Intake Air Temperature sensor faulty
Mass Air Flow Sensor (G70) faulty
Engine Coolant Temperature sensor faulty
Restricted Air or Fuel Filters
Possible Solutions
Check intake hose(s) or intake system for leaks (Unmetered Air) after MAF
Check Intake Air Temperature sensor
Check Mass Air Flow Sensor (G70)
Check Engine Coolant Temperature sensor
Check Air and Fuel Filters
Special Notes
Check O2 Sensor(s) Adaptation Values Before Clearing Faults
Senast redigerat av it_mutt (22 juli 2013)
