Tjo,
Välkomna till min projekttråd
7/5-14 735hk/918nm i motorn.
19/5-16 755hk/884nm i motorn.
12/5-17 854hk/1010nm i motorn.
18/5-18 904,5hk/1052,9nm I motorn
Har Monterats
Motor och avgassystem-Greddy Evo3 catback
-Z1 Motorsports Urethane Motor Mounts
-Nismo thermostat
-Injected Performance Girdle
-Nismo High-Rev Oil Pump 15010-RRZ30
-ARP custom age +625 head and mainbolts
-Ngk LFR6A-11 sparkplugs
-Supertech Viton Valve Seal Kit
-Brian Crower BC0220 Spring and Retainer
-Pathfindercoolingkit
-Cosworth Oil Control Baffle
-HKS Hybrid Sports Oil Filter 52009-AK001
-Mishimoto Thermostatic Oil Sandwich
-Greddy Twin turbo TD06sl2 hybrids 20g 9 blade turbines with 18g billet impellers
-Greddy turbo feed lines -an4
-Greddy Intercoolerkit
-Greddy Oilplug
-JWT S7R camshaft
-CJM Stage 2 Complete Fuel System
-AAM 3" downpipes with open WGs
-4-port MAC valve
-Koyo Radiator 36mm V2588
-AEM 3.5bar mapsensor
-AEM Infinity-8 ECU
-AEM Ecu Harness 350z/G35 p&p
-Olje och bräsletrycksgivare
-Aeromotive 340LPH Fuelpump
-Integrated Dual 044 Billet Surge Tank
-3,25" MAF housing
-K&N Ru-5111 filter
-Nismo G35 Brake Fluid Cover
-HKS SSQV IV
-HKS Radiatorcap 1.1bar
-Setrab 25-row oilcooler 210x194x50mm
-Vq37vhr head gasket OEM
-Arias Extreme Duty pistons
-ACL Engine Bearings HX (Rods, Mains, Thrust)
-6x ExhaustGasTechnologies Stinger probe EGT
-Continental ethanol content sensor mini
-Braille B3121 lightweight battery
-Hitachi ETB0021 75mm throttlebody
-Manley Stainless Racer Master Valve Set
-Z1 Manganese-Bronze Valve Guides
-ASNU 1500cc injectors
-Deatschwerks fuel filter
-2x AEM 400Lph fuel pumps
-J-spec alu fläns till tryckrör
-Fluidamp Harmonic Balancer
-Brian Crower rods BC6228
-EcuMaster Can-EGT
Drivlina-Infiniti G37 Differential 3.3 final drive
-RJM Clutch Pedal Systems Rev 3.3
-Chromoly Clutch Pivot Ball & Stainless Steel Clutch Line
-Zspeed Willwood Clutch master cylinder
-Quaife Differential QDF10L
-DriveShaftShop Pro-level 1200hp 108mm CV-joint
-DriveShaftShop carbon driveshaft
-Motul 300 Gear Oil
-Exedy TripleDisc carbon clutch NMA73HBMC1
-AMS short shift
-Dewla shift knob
Chassi-Hotchkis Swaybars
-KW Clubsport coilovers Inox-line
-GT-spec Strutbar
-SPC Toebolts for RAS
-SPC camber arms rear
-SPL front A-arms V3
-SPL Pro SPL Solid Subframe Bushings
-SPL PRO Titanium Rear Traction Links
-SPL Front Compression Rod Bushings
-SPL Front Lower Inner Arm Bushings
-SPL PRO Front Outer Tie Rod Ends V5
-Energy Suspension Rear Suspension Bushing Set
-Energy Suspension Power Steering Rack & Pinion Bushings
-Energy Suspension Differential Bushingskit + 68,5x20,5mm teflonbussning
Fälgar, däck och bromsar-Akebono BBK, 14"/13,8"
-Z1 2 Piece Akebono Front & Rear Rotors
-Castrol SRF DOT4 brakefluid
-Hawk DTC-60 brakepads
-18" Trackday rims, ES2 Varrstoen 18x9,5 & 10,5 ET22
-Michelin Cup2 18" 295 & 265
-Hoosier Drag radials DR2 295/55-15 DOT
-Vision 521 Nitro Drag rims 15x10" et25
-M&H 185/50R18 frontrunners
-Z1 350Z / G35 Stainless Steel Brake Lines
Exteriör-Strafe Speed V1 CarbonFiber trunk
-Nismo Skyline Tail Light, JDM
-Nismo Front Clear Corners JDM
-Z Speed Performance Aluminum Undershroud
-KurumaZ front
-Impul sideskirts
-Black stainless hood dampers
-D-spec headlights
Interiör-Planted Technology Seat Brackets
-TVandNav2Go
-Grom audio GROM-AUX-NIS02
-GaugeArt CanBus
-2x Corbeau Sprint Vinyl FIA Bucket Seat
Ska monteras, har hemma-370z Nismo VLSD 3.692 utväxling
Har beställtSka beställasFramtidsplaner-Hellack
-1000hp
