hi
since you can buy the Nakamichi in sweden im turning to you! Is it pure aliexpress or on par with pioneer,sony etc..? (around same prize range)
Oh dont reply if you dont have any experience with it.
https://youtu.be/Lo0bnoAZTpQwas looking for this Nakamichi NQ722BD.. since it has:
3 preout 4v
25band EQ (on app control)
time-alignment
Thing is.. im trying to do a setup with no box subwoofer. so running 2 Raptor-6 6.5" subs in the rear self, mtx rtx165 with b2 tweeters and crossover, on a pioneer deh9600 to a rockford fosgate p600x4.
But the raptors will go wild if i allow sub 35hz < because of the Infinite baffle setup. (and my setup does not have a subsonic filter) here i would use the big EQ to cut or dampen the lowest stuff. And the timealignment could maybe tweak the hole thing abit.
If you have a suggestion for another headunit that would do the job.. i would consider.
Oh the car is a 1998 lancer evolution 5.
