Har scannar bilen, fattar inte riktigt felkoder är och undrar om det finns någon här som kan hjälpa mig?
Vad är trasigt?
Car Scanner ELM OBD2
DTC report
Selected brand: Ford Transit
============1==============
P0299
Raw code: 0299
ECU: Engine control unit
Status: Pending
OBDII: Turbocharger (TC)/supercharger (SC) - low boost
============2==============
P0234
Raw code: 0234
Status: Pending
OBDII: Turbocharger (TC), engine boost condition - limit exceeded
Ford: Engine Overboost Condition
============3==============
P1102
Raw code: 1102
Status: Pending
OBDII: MAF Sensor In Range But Lower Than Expected
Ford: MAF Sensor In Range But Lower Than Expected
============4==============
P0404(73)
Raw code: 040473
ECU: Engine control unit[Archive (inactive)]
Status: Confirmed, Test failed since last DTC clear
OBDII: Exhaust gas recirculation (EGR) system - range/performance problem
Ford: EGR Circuit Range/Performance
============5==============
P1102(00)
Raw code: 110200
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
============6==============
P0403(11)
Raw code: 040311
OBDII: Exhaust gas recirculation (EGR) - circuit malfunction
Ford: EGR Circuit Malfunction
============7==============
P0299(00)
Raw code: 029900
============8==============
P0234(00)
Raw code: 023400
============9==============
P1103(00)
Raw code: 110300
OBDII: MAF Sensor In Range But Higher Than Expected
Ford: MAF Sensor In Range But Higher Than Expected
============10==============
P02A4(00)
Raw code: 02A400
Status: Test not completed since last DTC clear
OBDII: Injector 3 - leak
============11==============
P02A0(00)
Raw code: 02A000
OBDII: Injector 2 - leak
============12==============
P02A8(00)
Raw code: 02A800
OBDII: Injector 4 - leak
============13==============
P0404(73)
Raw code: 040473
============14==============
P1102(00)
Raw code: 110200
============15==============
P0403(11)
Raw code: 040311
============16==============
P0299(00)
Raw code: 029900
============17==============
P0234(00)
Raw code: 023400
============18==============
P1103(00)
Raw code: 110300
Vad är trasigt?
DTC report
P0299
Raw code: 0299
Status: Pending
P0234
Raw code: 0234
Status: Pending
P1102
Raw code: 1102
Status: Pending
P0404(73)
Raw code: 040473
P1102(00)
Raw code: 110200
P0403(11)
Raw code: 040311
P0299(00)
Raw code: 029900
P0234(00)
Raw code: 023400
P1103(00)
Raw code: 110300
P02A4(00)
Raw code: 02A400
P02A0(00)
Raw code: 02A000
P02A8(00)
Raw code: 02A800
P0404(73)
Raw code: 040473
P1102(00)
Raw code: 110200
P0403(11)
Raw code: 040311
P0299(00)
Raw code: 029900
P0234(00)
Raw code: 023400
P1103(00)
Raw code: 110300
0
0
0
0
