peterholm skrev:
hej jag har 2 st slutsteg å sälja det kommer lite info här om du e sugen
Number Of Channels: 1
DC Power Supply: 11-16 Volt
Max Stereo Power to 13.8V, 4 Ohm: 1x1200 Watt
RMS Stereo Power to 13.8V, 4 Ohm: 1x600 Watt
Max Stereo Power to 13.8V, 2 Ohm: 1x1700 Watt
RMS Stereo Power to 13.8V, 2 Ohm: 1x850 Watt
Bass Booster : ON/OFF at 40 Hz
Phase Shifter: 0o-180o
Low-Pass Crossover 12db: 40-300 Hz at 24 db
Distortion THD 1KHz: <2.0 %
Frequency Response: 10-300 Hz
Input Sensitivity(Gain): 0.3-6.0 Volt
Advisable Fuse: 1x150 Amp
Damping Factor: >300
Dimensions: 250x280x63 mm
Weight: 4.2 Kg
mitt pris 2400kr
