3301
Lampan lyser, motorfel
18 Inlägg
1 mars 2022
Har scannar bilen, fattar inte riktigt felkoder är och undrar om det finns någon här som kan hjälpa mig?
Vad är trasigt?
Car Scanner ELM OBD2
DTC report
Selected brand: Ford Transit
============1==============
P0299
Raw code: 0299
ECU: Engine control unit
Status: Pending
OBDII: Turbocharger (TC)/supercharger (SC) - low boost
============2==============
P0234
Raw code: 0234
Status: Pending
OBDII: Turbocharger (TC), engine boost condition - limit exceeded
Ford: Engine Overboost Condition
============3==============
P1102
Raw code: 1102
Status: Pending
OBDII: MAF Sensor In Range But Lower Than Expected
Ford: MAF Sensor In Range But Lower Than Expected
============4==============
P0404(73)
Raw code: 040473
ECU: Engine control unit[Archive (inactive)]
Status: Confirmed, Test failed since last DTC clear
OBDII: Exhaust gas recirculation (EGR) system - range/performance problem
Ford: EGR Circuit Range/Performance
============5==============
P1102(00)
Raw code: 110200
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
============6==============
P0403(11)
Raw code: 040311
OBDII: Exhaust gas recirculation (EGR) - circuit malfunction
Ford: EGR Circuit Malfunction
============7==============
P0299(00)
Raw code: 029900
============8==============
P0234(00)
Raw code: 023400
============9==============
P1103(00)
Raw code: 110300
OBDII: MAF Sensor In Range But Higher Than Expected
Ford: MAF Sensor In Range But Higher Than Expected
============10==============
P02A4(00)
Raw code: 02A400
Status: Test not completed since last DTC clear
OBDII: Injector 3 - leak
============11==============
P02A0(00)
Raw code: 02A000
OBDII: Injector 2 - leak
============12==============
P02A8(00)
Raw code: 02A800
OBDII: Injector 4 - leak
============13==============
P0404(73)
Raw code: 040473
============14==============
P1102(00)
Raw code: 110200
============15==============
P0403(11)
Raw code: 040311
============16==============
P0299(00)
Raw code: 029900
============17==============
P0234(00)
Raw code: 023400
============18==============
P1103(00)
Raw code: 110300
18 012 Inlägg
1 mars 2022
Om du ser till att batteriet är ordentligt laddat och raderar felkoderna. Kommer någon tillbaka? Ser ut som skräpkoder.
18 Inlägg
1 mars 2022
Raderade på vägen hem, bilen hoppade till, oljelampan lyste 2 sekunder. Scannade igen men inget kom upp (trots att lampan för bromsbackarna lyste)
3 214 Inlägg
2 mars 2022
Har du programmet Forscan med en ELM som interface?
Eller ett mer universellt program till ELM?
Universella som ofta medföljer div  interface läser bara motorn.
Förklarar i så fall varför du inte ser något från bromsarna.
Största felet ser ut att ligga i EGR, enl koderna.
Men vänta och se vilka som återkommer.
Räcker med spänningsfall i nån sekund vid kallstart en kall vinterdag för att sätta "spök-koder" som förvillar.
Senast redigerat av Mossan1 (3 mars 2022)
