Mack
Forum- och sitemoderator
5 september 2011
· 26 180 Inlägg
Altavistar man det lite snabbt så kommer detta upp:
SPC Performance Suspension Camber Kit with Adjustable Camber Angles for Different Height Setup for Lowered Vehicle. When you change your vehicle's height you can expect to change your vehicle's suspension geometry as well. These camber changes can affect both your tire wear and how your vehicle handles. By correcting camber with one of SPC Performance's alignment camber kits or parts you can save your tires and bring back the handling of your vehicle. SPC Camber Kit available for most vehicles with Min. 1.5" drop to Max. 3.0" drop.
Kort sagt. Verkar ha nåt med upphängningen att göra.
