2981
BMW E30 Street/TimeAttack (DTM style control arms)
-work in progress-
134 275 Visningar
Uppdaterades senast 22 augusti 2018
144 Inlägg
5 april 2016
Wastegate arrived quickly, also got few stickers:
http://i187.photobucket.com/albums/x281/mice325/wastegate50_zpsqhsbybc0.jpg
Then I started to make wastegate piping, need to make a mild steel flange though, I don't like to mix it to stainless steel:
http://i187.photobucket.com/albums/x281/mice325/wastegate501_zpsvrrfuned.jpg
144 Inlägg
7 april 2016
Story continues:
http://i187.photobucket.com/albums/x281/mice325/hukkistatinaillen_zpsvzuf4dt9.jpg
Divided all the way to valve, with sophisticated testing (by blowing air into primaries) the flow seems to find its path well towards the wastegate:
http://i187.photobucket.com/albums/x281/mice325/WP_20160407_20_43_08_Pro__highres_zpsydrcy0ka.jpg
144 Inlägg
16 april 2016
Recently I've machined and bought some new stuff.
Current engine mounts were kind of temporary, never welded them complete, because turbo and supercharger locations were only approximate.
I wanted a lower design to clear the turbo intake pipe.
The design, steel sleeve with delrin bushing:
http://i187.photobucket.com/albums/x281/mice325/moottorikannake_zps5ih18uqe.jpg
This was something I could machine by myself roll
http://i187.photobucket.com/albums/x281/mice325/moottorikannake2_zpsmxitmuiq.jpg
Obviously I had to mockup alternator location before making intake/charge air piping, but the old one had seen it's best days. Instead of refurbishing and machining new pulleys for the old one I bought a new, smaller, modern alternator:
http://i187.photobucket.com/albums/x281/mice325/laturit_zpsaqtblilc.jpg
This spring and summer will probably be busy time with the project, more parts is already on the way tongue
144 Inlägg
4 maj 2016
Some new bits acquired, Toyota MR2 electric power steering pump. Remain to be seen if it's even working, connectors had damaged badly during shipping...
http://i187.photobucket.com/albums/x281/mice325/mr2electricpowersteeringpump_zpsutcpdc7b.jpg
Today's job was to make another front fender, it was easy one, I used the same cardboard templates which I made for the driver's side:
http://i187.photobucket.com/albums/x281/mice325/WP_20160504_21_37_27_Pro__highres_zps1i5zpcye.jpg
Extra pic:
http://i187.photobucket.com/albums/x281/mice325/ilta_arska_e30_zpshulrjrz0.jpg
144 Inlägg
5 maj 2016
Ricke W skrev:
Det ser riktigt bra ut, kämpa på! Kommer du att tävla i Sverige nånting eller blir det bara i Finland?
Tackar! Mest i Finland, men jag vill också delta i någon Gatebil event om vi har tid.. cool
144 Inlägg
15 maj 2016
This will be a frustrating and time-consuming job roll 1 out of 4 corners in progress, after spraying a paint layer I noticed one spot needed to be cut open and hammered down.
http://i187.photobucket.com/albums/x281/mice325/WP_20160511_21_02_57_Rich__highres_zpshsqppjfr.jpg
http://i187.photobucket.com/albums/x281/mice325/WP_20160514_21_18_32_Rich__highres_zpsa57enneo.jpg
Finally got all the parts for the control arms, roll-center/bump steer -adapter fits perfectly cool
http://i187.photobucket.com/albums/x281/mice325/WP_20160512_20_20_45_Rich__highres_zpsgz3olt5b.jpg
Also few lengths of aluminium tubing appeared this week, need to build up something of those
http://i187.photobucket.com/albums/x281/mice325/6tag_110516-111754_zpsc853fp5e.jpg
144 Inlägg
19 maj 2016
Thanks cool
Earlier this week I bought few liters of paint, should be plenty for mock-ups and molds. I picked the same hue which might be the final color, we'll see...
At this point the fender starts to look like something, but still a lot to do. A couple of bigger dents showed up after the first gray paint layer.
http://i187.photobucket.com/albums/x281/mice325/IMG_7332_zpsxh5hrp5o.jpg
But... this will probably do, picture taken this evening. I'm afraid something goes wrong when I start to mess up with fiberglass big_smile
http://i187.photobucket.com/albums/x281/mice325/IMG_7342_zpsz82mzzru.jpg
I think I should take the camera more often with me, mobile pics look crap besides these..
144 Inlägg
20 maj 2016
The color, I like cool Paintwork not so perfect but ok for molding
http://i187.photobucket.com/albums/x281/mice325/lokarivari_pieni_zpsxh99mppm.jpg
144 Inlägg
21 maj 2016
Precis så Victor smile Och stort tack för alla!
Jag kommer bygga alla skärmar, dörrar, tacklucka, huven osv. i glasfiber så bara inre karosseri och tak är i plåt. Hoppas det väger några kilo mindre. big_smile
144 Inlägg
26 maj 2016
After the front fender was done I moved to the rear end to see if I could conjure it up to "mold ready". Massive filler layer hid under the paint. Round corner will be made into the mold, I find it easier than forming the metal mockup.
http://i187.photobucket.com/albums/x281/mice325/takalokarii_zpss0kr17ge.jpg
144 Inlägg
1 juni 2016
Postman brought me some goods; Davies Craig electric water pump and controller, now I can get rid of belt driven pump and thermostat housing, keep things simple cool Package also contained very compact cabin heater and a 16in radiator fan:
http://i187.photobucket.com/albums/x281/mice325/watersystem_small_zpsawbwk8ob.jpg
144 Inlägg
10 juni 2016
Kiitos kiitos! Auto majailee Tampereen nurkilla, ensi kesänä tarkoitus kierrellä TimeAttack -sarjaa.
Tires arrived yesterday.. tongue All I can say that's a lot of rubber! Although they look massive it will fit inside the fender strictly:
http://i187.photobucket.com/albums/x281/mice325/meat_zpskugfazo7.jpg
To avoid ruining them in the first practices I ordered E46 MK60 ABS/DSC unit, but only ABS will be used. I've seen people using MK60 standalone systems earlier, but the price of the complete harness was far out of my budget. Lately I started to sort out ABS system again and found out it could be done by myself maybe.
If anyone has a complete wiring diagram or MK60 ABS unit pin layout, please send me a message! All the info I've come across is kind of dispersed..
144 Inlägg
15 juni 2016
Tusen tack! smile
Here's the Mk60 ABS unit. This thing is mini size compared to E30 pump + ecu!
http://i187.photobucket.com/albums/x281/mice325/WP_20160615_18_11_11_Rich__highres_zps7edjhp7a.jpg
I'm probably going to mount it in passenger's footwell, easy to route piping and electrics. Cabin heater will be bolted somehow over the IC:
http://i187.photobucket.com/albums/x281/mice325/WP_20160615_20_59_23_Rich__highres_zps7szbvi4r.jpg
ABS unit sits nice behind the aluminium foot rest:
http://i187.photobucket.com/albums/x281 … tseub5.jpg
144 Inlägg
23 juni 2016
BBS RF centres look much better with decent lips and barrels smile 11.5x17"
http://i187.photobucket.com/albums/x281/mice325/WP_20160623_16_24_47_Rich__highres_zpskptx27vz.jpg
http://i187.photobucket.com/albums/x281/mice325/WP_20160623_16_15_26_Rich__highres_zpssk1ufkoy.jpg
http://i187.photobucket.com/albums/x281/mice325/WP_20160623_19_14_56_Rich__highres_zpseg1xiile.jpg
144 Inlägg
30 juni 2016
One day I tried how things fit in those RF wheels, 15mm spacer is minimum to clear the caliper but with 7" inner barrel it's pretty close to damper. So maybe a 6.5" barrel would be a better choice.
http://i187.photobucket.com/albums/x281/mice325/frontend_zps0bni7gbm.jpg
As someone might ask, here's the complete list of the parts:
-E36 M3 spindles
-E46 M3 OEM rotors with aluminum hub
-Brembo ZL/ZR18 calipers
-MagnusRacingTeam control arms with roll-center/bump steer adapters
-K-sport circuit dampers with custom valving and spring rates for my car
144 Inlägg
6 augusti 2016
If anyone else is interested in similar front control arm kit, I've got a few extra sets in stock.
U.S. buyers please contact dylan@neuemotorsports.com he's making a pre-order.
Scandinavian buyers please contact info@motornord.se
If located elsewhere, please contact us magnusracingteam@gmail.com
"These control arms are made for E30 chassis to accept and correct the front end geometry using E36 or E36-M spindles.
E36-series spindles are often used to get 5-lug bolt pattern, but they also have better variety of brakes and coilovers than E30-series. Spindle itself has better geometry for racing as it is closer to E30 M3 variants.
The most notable advantages are correct wheel location and roll-center/bump steer correction which are decayed when substantially lowering the car. On the side the adapter plate also makes the steering ratio quicker. Kit only has about half the weight of orginal cast control arms.
The kit offers a chance to adjust the front end the way you want it; width, caster and anti-dive properties are all adjustable.
This is pure motorsports from the E30 DTM era."
http://i187.photobucket.com/albums/x281/mice325/set1_zpsosrbu0f6.jpg
144 Inlägg
6 augusti 2016
Summer vacation is over... back to work and back to build the project.
I supposed to fabricate intake manifold right after the exhaust was done, but I ended up doing something else. Now I felt like doing aluminium parts. Previously I did aluminium charge pipes for my friends E21 turbo and welding felt pretty easy, maybe because of the thicker material or gained experience big_smile Anyway...
Got to start from somewhere, cut hole for IC to throttle body -pipe:
http://i187.photobucket.com/albums/x281/mice325/WP_20160804_18_05_25_Rich__highres_zpsdlcp5w82.jpg
Making plenum backplate:
http://i187.photobucket.com/albums/x281/mice325/WP_20160805_15_37_02_Pro__highres_zps6rvlpapm.jpg
http://i187.photobucket.com/albums/x281/mice325/WP_20160805_15_43_20_Pro__highres_zpsilueewxn.jpg
Our hydraulic press channel:
http://i187.photobucket.com/albums/x281/mice325/WP_20160805_16_23_42_Pro__highres_zpsnddn6las.jpg
Now with integrated trumpets:
http://i187.photobucket.com/albums/x281/mice325/WP_20160805_16_38_49_Pro__highres_zpsug6cyd9z.jpg
http://i187.photobucket.com/albums/x281/mice325/WP_20160805_16_39_01_Pro__highres_zpsqv8lyymi.jpg
Next on to do -list are the runners, there's no too much space and I think I have to do some minor compromises.
Senast redigerat av Mickey_ (6 augusti 2016)
144 Inlägg
10 augusti 2016
...story of the intake manifold continues:
Tuned length 330mm:
http://i187.photobucket.com/albums/x281/mice325/IMG_8469_zpsyd4zmytn.jpg
http://i187.photobucket.com/albums/x281/mice325/IMG_8477_zpsbdctbdyk.jpg
http://i187.photobucket.com/albums/x281/mice325/IMG_8481_zpsefq67oa6.jpg
144 Inlägg
14 augusti 2016
big_smile
Next thing was to make the airbox/plenum part. Space was limited but the volume will be near 9 liters when finished. I think there's no ultimate formula for calculating ideal volume, but 2-3 times the engine displacement should do when seeking at maximum power.
Started with two long radius elbows and a piece of straight tube:
http://i187.photobucket.com/albums/x281/mice325/WP_20160811_19_12_33_Rich__highres_zpss9ultapz.jpg
http://i187.photobucket.com/albums/x281/mice325/WP_20160811_21_35_55_Rich__highres_zpsjvnltjeo.jpg
Tried to fabricate a smooth air inlet transition piece, this should distribute air better than just an elbow welded to the bottom:
http://i187.photobucket.com/albums/x281/mice325/WP_20160813_16_46_24_Pro__highres_zpsduhndxhd.jpg
http://i187.photobucket.com/albums/x281/mice325/WP_20160813_16_53_56_Rich__highres_zps6cawzai7.jpg
144 Inlägg
23 augusti 2016
Lately I was browsing the interwebs looking for a throttle body to get the intake finished. No reason to go massive size flap so I wanted one to fit my alu elbows. I found a 80mm TB and same shop was selling v-band flanges suitable for the upcoming exhaust system, incidentally I found an oil filter relocation kit with thermostat, I think the blue color won't stay though... wink
http://i187.photobucket.com/albums/x281/mice325/WP_20160823_17_45_39_Rich_zpsnelm7rrn.jpg
