_Dolle_'s Projekttråd, Infiniti G35 Coupe --> Nya uppdateringar <--
Infiniti G35 Twinturbo med plusmeny
  • 213 Följare
  • 229 102 Visningar
  • Uppdaterades senast 21 februari 2020
_Dolle_ Fortkörare
27 augusti 2013 · 1 101 Inlägg
Tjo,
Välkomna till min projekttråd smile
7/5-14  735hk/918nm i motorn.
19/5-16 755hk/884nm i motorn.
12/5-17 854hk/1010nm i motorn.
18/5-18 904,5hk/1052,9nm I motorn
Har Monterats
Motor och avgassystem
-Greddy Evo3 catback
-Z1 Motorsports Urethane Motor Mounts
-Nismo thermostat
-Injected Performance Girdle
-Nismo High-Rev Oil Pump 15010-RRZ30
-ARP custom age +625 head and mainbolts
-Ngk LFR6A-11 sparkplugs
-Supertech Viton Valve Seal Kit
-Brian Crower BC0220 Spring and Retainer
-Pathfindercoolingkit
-Cosworth Oil Control Baffle
-HKS Hybrid Sports Oil Filter 52009-AK001
-Mishimoto Thermostatic Oil Sandwich
-Greddy Twin turbo TD06sl2 hybrids 20g 9 blade turbines with 18g billet impellers
-Greddy turbo feed lines -an4
-Greddy Intercoolerkit
-Greddy Oilplug
-JWT S7R camshaft
-CJM Stage 2 Complete Fuel System
-AAM 3" downpipes with open WGs
-4-port MAC valve
-Koyo Radiator 36mm V2588
-AEM 3.5bar mapsensor
-AEM Infinity-8 ECU
-AEM Ecu Harness 350z/G35 p&p
-Olje och bräsletrycksgivare
-Aeromotive 340LPH Fuelpump
-Integrated Dual 044 Billet Surge Tank
-3,25" MAF housing
-K&N Ru-5111 filter
-Nismo G35 Brake Fluid Cover
-HKS SSQV IV
-HKS Radiatorcap 1.1bar
-Setrab 25-row oilcooler 210x194x50mm
-Vq37vhr head gasket OEM
-Arias Extreme Duty pistons
-ACL Engine Bearings HX (Rods, Mains, Thrust)
-6x ExhaustGasTechnologies Stinger probe EGT
-Continental ethanol content sensor mini
-Braille B3121 lightweight battery
-Hitachi ETB0021 75mm throttlebody
-Manley Stainless Racer Master Valve Set
-Z1 Manganese-Bronze Valve Guides
-ASNU 1500cc injectors
-Deatschwerks fuel filter
-2x AEM 400Lph fuel pumps
-J-spec alu fläns till tryckrör
-Fluidamp Harmonic Balancer
-Brian Crower rods BC6228
-EcuMaster Can-EGT
Drivlina
-Infiniti G37 Differential 3.3 final drive
-RJM Clutch Pedal Systems Rev 3.3
-Chromoly Clutch Pivot Ball & Stainless Steel Clutch Line
-Zspeed Willwood Clutch master cylinder
-Quaife Differential QDF10L
-DriveShaftShop Pro-level 1200hp 108mm CV-joint
-DriveShaftShop carbon driveshaft
-Motul 300 Gear Oil
-Exedy TripleDisc carbon clutch NMA73HBMC1
-AMS short shift
-Dewla shift knob
Chassi
-Hotchkis Swaybars
-KW Clubsport coilovers Inox-line
-GT-spec Strutbar
-SPC Toebolts for RAS
-SPC camber arms rear
-SPL front A-arms V3
-SPL Pro SPL Solid Subframe Bushings
-SPL PRO Titanium Rear Traction Links
-SPL Front Compression Rod Bushings
-SPL Front Lower Inner Arm Bushings
-SPL PRO Front Outer Tie Rod Ends V5
-Energy Suspension Rear Suspension Bushing Set
-Energy Suspension Power Steering Rack & Pinion Bushings
-Energy Suspension Differential Bushingskit + 68,5x20,5mm teflonbussning
Fälgar, däck och bromsar
-Akebono BBK, 14"/13,8"
-Z1 2 Piece Akebono Front & Rear Rotors
-Castrol SRF DOT4 brakefluid
-Hawk DTC-60 brakepads
-18" Trackday rims, ES2 Varrstoen 18x9,5 & 10,5 ET22
-Michelin Cup2 18" 295 & 265
-Hoosier Drag radials DR2 295/55-15 DOT
-Vision 521 Nitro Drag rims 15x10" et25
-M&H 185/50R18 frontrunners
-Z1 350Z / G35 Stainless Steel Brake Lines
Exteriör
-Strafe Speed V1 CarbonFiber trunk
-Nismo Skyline Tail Light, JDM
-Nismo Front Clear Corners JDM
-Z Speed Performance Aluminum Undershroud
-KurumaZ front
-Impul sideskirts
-Black stainless hood dampers
-D-spec headlights
Interiör
-Planted Technology Seat Brackets
-TVandNav2Go
-Grom audio GROM-AUX-NIS02
-GaugeArt CanBus
-2x Corbeau Sprint Vinyl FIA Bucket Seat
Ska monteras, har hemma
-370z Nismo VLSD 3.692 utväxling
Har beställt
Ska beställas
Framtidsplaner
-Hellack
-1000hp
Senast redigerat av _Dolle_ (21 februari 2020)
Infiniti G35 Coupe "Back In Black" (2006)
Ikrana
27 augusti 2013 · 105 Inlägg
VA???? vafan säger du sad
sjukt tråkigt att höra, och all tid du la ner på den!  skall dock bli kul att see en ny verion med widebody ! kommer lätt att följas.
Honda S2000 (2007)
_Dolle_ Fortkörare
28 augusti 2013 · 1 101 Inlägg
Sånt som händer ibland.. sad
Ja, men det e nya friska tag nu smile Japp, det blir widebody i vintern.. om allt går enligt planerna så står den på Elmia 2014 smile
Ikrana
28 augusti 2013 · 105 Inlägg
kommer nog bli riktigt fet ! blir det ungefär samma motorspec?
Honda S2000 (2007)
_Dolle_ Fortkörare
Japp, blir nog runt 800 :-)
T0p_s3cr3t-s
28 augusti 2013 · 37 Inlägg
HELL YEAH! big_smile btw såg dig på mcd i hbg under vallåkrahelgen lol
Nissan 200sx s13 "SR20DET" (1989)
Ikrana
Grymme!!!!
Honda S2000 (2007)
_Dolle_ Fortkörare
29 augusti 2013 · 1 101 Inlägg
wink Japp, jag var där så det kan stämma tongue
Ikrana skrev:
Grymme!!!!
Ja för fan smile men nu ska jag ha en ordentlig oljepump o.s.v smile
_Dolle_ Fortkörare
30 augusti 2013 · 1 101 Inlägg
Idag har jag uppgraderat mina DSS level 5 drivaxlar till Pro level. Man byter bara den inre drivknuten för att uppgradera.
DSS 108mm CV-joint ink conversion plate for nissan
Level 5 klarar ca 900hk och pro klarar ca 1200.
Varför jag uppgraderade var för att jag tyckte där var lite glapp i inre knut
https://www1.garaget.org/gallery/images/26/25778/25778-d081448d4ddbf076616941fd8de9e1ec.jpg
https://www1.garaget.org/gallery/images/26/25778/25778-b9cc4b741894588415963cf0cc3877c6.jpg
https://www1.garaget.org/gallery/images/26/25778/25778-b0823a68a2391aa0b051179699954d7f.jpg
https://www1.garaget.org/gallery/images/26/25778/25778-4026fe36607a114df1c7daf826ab721e.jpg
Martin_78
30 augusti 2013 · 398 Inlägg
Detta låte helt klart intressant så det får vi nog ta å följa smile
Lycka till
floff
30 augusti 2013 · 270 Inlägg
Detta har man väntat på big_smile Kul att du är tillbaka i banorna igen..
Väldigt kul och intressant på med APR widebody wink
Kommer absolut följas och denna gången från starten smile Lycka till
Nissan 350Z GT "Vortech V3 Supercharger" (2004)
_Dolle_ Fortkörare
1 september 2013 · 1 101 Inlägg
Lycka till
Det kommer hända mkt i vinter med den big_smile So stay put wink
Ja, för fan smile så lätt ger jag inte upp wink
Ja den måste breddas för jag ska få in 12- 12,5" breda fälgar så jag kan behålla greppet smile
Tackar big_smile
_Dolle_ Fortkörare
Här har vi gubbilen wink
https://www1.garaget.org/gallery/images/26/25778/25778-08843cf9c010b3857f2f4203047cf99f.jpg
https://www1.garaget.org/gallery/images/26/25778/25778-13d8e2bad8ee67d2762c2178e071b924.jpg
Mina KW coilovers kommer nästa vecka och då blir det att montera krängningshämmare, bigbrakekit, coilovers och lite annat smått o gott smile
LuCiiifer DrivmedelsTekniker
1 september 2013 · 1 632 Inlägg
Tråkigt med den blå sad Men bli förmodligen en värre verison av denna antar jag? Grymma projekt!
350Z-R
1 september 2013 · 219 Inlägg
Back in Black!! V2 - G35TT, fast denna gången snäppet vassare.. wink Plus att det är facelift modellen!!
Senast redigerat av 350Z-R (1 september 2013)
Nissan 350z - N/A (UpRev)
_Dolle_ Fortkörare
3 september 2013 · 1 101 Inlägg
Japp, det sög tongue men som du säger så tar jag denna bilen en nivå högre smile
Mm big_smile förhoppningsvis så blir den rätt så fet wink
_Dolle_ Fortkörare
Fick ett paket ifrån Japan igår smile
https://www1.garaget.org/gallery/images/26/25778/25778-8d481c36c26cf854a15c3bea60782f41.jpg
https://www1.garaget.org/gallery/images/26/25778/25778-8879921523d4dcd65f8e56d372733c9a.jpg
https://www1.garaget.org/gallery/images/26/25778/25778-297f4dfa6a9faa70ab7ae4cee1333f1a.jpg
https://www1.garaget.org/gallery/images/26/25778/25778-f09ecbb48524d048c64472cf1aa96b51.jpg
https://www1.garaget.org/gallery/images/26/25778/25778-ac0ad3ec7f9079162e68851e5928f688.jpg
NISMO high pressure oil pump
Sen fick jag meckat lite med bakvagnen smile KW coilisar, SPC camberstag och broms kit e på plats
https://www1.garaget.org/gallery/images/26/25778/25778-1dc0c8a7606c2067a6380a21cc9d0744.jpg
https://www1.garaget.org/gallery/images/26/25778/25778-9aa94715ff6c87653511b1b77110e320.jpg
Så det e bara drivaxlar och krängningshämmare kvar sen e bakvagn klar..
Senast redigerat av _Dolle_ (3 september 2013)
Lofvis
3 september 2013 · 143 Inlägg
Gött kött.
Tror du svart går fortare än blått wink
June 2011 - Imagine sitting in a deckchair in your garden on a summer’s day. It’s quiet and peaceful and you are enjoying the birdsong. Then you are hit from behind by a Boeing 747. That’s what the acceleration feels like in a GT-R. Absolutely unbefrigginglievable.
Move Over Veyron, There’s A New King In Town.
Nissan GT-R "Alpha 9" (2012)
_Dolle_ Fortkörare
Lofvis skrev:
Gött kött.
Ja, Svart kommer gå bättre än blått ! Det ska jag bevisa.. smile Men svart kommer aldrig gå så fort som svart tongue
3 september 2013 · 1 632 Inlägg
Personligen så kommer den svarta i mina ögon - oavsett om det blir bättre motormässigt aldrig bli densamma som den blå. Jag gillar udda bilar med udda färger och den du hade var sjukt egen bil! Kommer däremot bli ännu intressantare att följa denna då jag väntar mig väääldigt mycket mer nu än förra gången smile
