9157
"Besiktning" av Mazda Rx7???
29 Inlägg
26 februari 2009
Will write in english since my swedish isn't that good. Feel free to reply in Swedish.
Just curious about if anyone with Rx7 have had problems with besiktning of Rx7's?
I'm about to send my new one to Importbesiktning and are a bit worried.. it's a 2001 and completly standard.
Did any of you know about problems or what to do if so?
1 867 Inlägg
26 februari 2009
If the car is standard there should be no problem, as long as the lights and such are swedish-spec.
Specialsvarv.se - Hårda bussningar till hårda bilar.
Saab älskare!
4 597 Inlägg
26 februari 2009
agree there, just that the lights, and horn ofc. are working and of swedish spec. Check that all lights of the cars exterior are working, turnsignal, all lights tongue And good luck to you mate!
Greetings Patrik
29 Inlägg
26 februari 2009
Thanks guys.
I'm mostly worried about the emission test sad
Saab älskare!
4 597 Inlägg
26 februari 2009
if you are worried about that, fill up you fuel tank with E85, so you have a bit E85 and regular "bensin" hehe, about 40% E85 and 60% Fuel! Its taking down some values so they cant complain about that!´Hope its woring for you!
/Patrik
29 Inlägg
26 februari 2009
ah nice, I will do that just to be sure.. it will not hurt the engine?
Saab älskare!
4 597 Inlägg
26 februari 2009
hehe, no, it wont hurt it, i did it on my saab 9000, and alot of other are doing that before their "besiktning" smile just relax and it will go exelent! big_smile
BR
Patrik
29 Inlägg
26 februari 2009
thanks smile
1 867 Inlägg
26 februari 2009
I would'nt put that much E85 in, not in that engine, as it's more delicate than many other engines.
If you're gonna mix with ethanol i would recommend 20% or less, just to get the emissions down.
Is the car dead standard? Stock exhaust and everything? If so, the emissions test wont be a problem.
29 Inlägg
26 februari 2009
the engine is as reliable as many other engines as long as you use the correct oil (Royal Purple) and make sure it's hot when launching
dead standard.
10 576 Inlägg
26 februari 2009
/Patrik
No no no no noooo!
-=[Performance by Torpis]=-
1 892 Inlägg
26 februari 2009
Personally I wouldn´t fill more then 15% E85
Good luck
/Mats
If your not out of control, your not in control
686 Inlägg
26 februari 2009
If its a standard rx7 whit a catalytic converter (katalysator) then it should be no problem whit (besiktningen)
Be very careful whit how much E85 you put in that car, its made to be run on 98-oktanig bensin i think.
/Påsen
PÅSEN RACING
KTM 660
537 Inlägg
26 februari 2009
Har brådis så får bli på svenska. Men ingen e85 i rx-7an, ditt hc värde lär bli bra galet då. Se till att luftpump (airpump)  och katalysator är okej så är det inga problem med avgasvärden.
Testade själv med e85 i min och det hc värdet ja fick då var inte att leka med.
Pontiac Gto 69a
Volvo 740 90a projekt bil
13 Inlägg
27 februari 2009
Do not use any other liquid in the tank beside gasoline...probobly 98 octane. The FD3S engine is sensitive against strange liquids.
I have had a few rx7s before that I imported and went through Swedish car inspection.
As the other members say that if the eninge is standard then it shouldn't be any problem at all but one trick that you can do is to force the airpump for constant function. It's not recommended to drive the car for a long time like that but for the inspections its ok. After the inspections, just switch it back.
good luck
