10004
Hjälp angående att ta bort ett innertak från en 740 med taklucka.
59 Inlägg
1 maj 2011
jo som rubriken lyder.. själva innertaket har jag fått ner men tyget som sitter på själva luckan? hur får man lös dessa? tacksam för svar / jimpa
59 Inlägg
2 maj 2011
länken fungerar dock inte hmm
326 Inlägg
2 maj 2011
den fungerar för mig, har du nåt program inlagt för att läsa PDF filer med?
59 Inlägg
2 maj 2011
joe har acrobat reader xD
326 Inlägg
2 maj 2011
If the sunroof needs the headliner replaced the roof panel must be removed as well as the headliner
panel. The best guide for removal is the Haynes manual.
Once removed lay the sunroof’s upholstered panel on a table and remove any remnants of the old
material. The original glue most likely will remain and that is OK.
Cut a piece for the rear vent door, using the old piece as a template or allow about two inches all around
the vent. With the material lying on the vent door, cut darts in the material so it will pull tight around the
corners of the vent door. You will be pulling the material like stretching a canvas so it is OK to cut close to
the edge of the vent door.
Test fit the piece and, with it lying in place, from the backside spray adhesive on the exposed 2-inch area
around the vent door. Use newspapers to shield the rest of the sunroof panel from overspray.
Fold over the edges of the material to glue them in place on the backside of the vent door. Do not glue the
center area of the vent door. The material is intended to float on the vent door. Remember to pull tight like
stretching a canvas. Start at one side and attach the darts to the back and move to the opposite side as
well as the third and forth side.
Finally do the rest of the panel the same way as the vent door. It is best to do the overall panel and cut the
hole and glue it after the outside edge is complete.
Replace the sunroof in the car and it will look as good as new. The sunroof may close slowly the first time
because the new material has more crush than the old. Allow the roof to stay closed for a day and it will
compress the material along the edges for a smooth operation.
59 Inlägg
3 maj 2011
tack smile ska se om jag kan fixa detta nu smile
3 Inlägg
19 juli 2011
Hej,
har sett denna länk på flera forum, men den leder inte till någon fil. Är det någon som har en kopia, så vore jag tacksam om ni kan posta en länk.
Jag har en 88 740 GLE. Har snäppt bort de två hakarna för innertaket via luckan i vent läge, men kan inte skjuta innertaket bakåt. Vet inte hur mycket kraft som jag törs lägga på kanten. Några tips?
740 Gle 1988, V70 Awd 2011
3 Inlägg
29 juli 2011
Det finns två clips i framkanten, nära ytterkanten, bakom en vinklad bit som sticker ner från taket. Med en skruvmejsel, kan man bända upp dem lite och hjälpa till när innertaket skall skjutas bakåt. Har nu fått bak taket, men kvar är att få ut innertaket för takluckan.
3 Inlägg
16 augusti 2011
Efter att innertaket skjutits bakåt, så gick det fint att skruva lös takluckan. Sedan tar man lätt bort den lilla luckan som viks upp i ventilationsläge. Den stora delen av innertaket för luckan, fick jag inte bort. Det gick dock bra att klä om den på plats.
1 Inlägg
14 december 2011
Bojm skrev:
Hej,
Ledsen för att jag tar upp den här tråden igen men ville inte starta en ny på grund av just det här. Ska snart klä om mitt innertak då det hänger och är skitigt på grund av att förra ägare har rökt i bilen.
Den här länken fungerade tidigare i år för mig men inte nu längre när jag har användning för den. tongue Så jag undrar samma sak om någon har kvar den här PDF filen på sin dator som kan kanske lägga upp den igen och länka? roll
Edit: Hittat filen nu. http://www.ipdusa.com/files/product/335 … 0GUIDE.PDF
Senast redigerat av Robin_o93 (5 mars 2012)
