10886
VW Golf 1,6 årsmodell-03. fel kod kylvätsketemperaturgivarkrets 1 hög signal
170 Inlägg
6 december 2012
Hej fick felkod idag när jag besiktigade bilen. Som rubriken lyder gäller det en golf årsmodell 03.
Det står så här på lappen: (EG:8.2.1.1) Omborddiagnossystem, felkod identifierad
                                        P0118 Motorns kylvätsketemperaturgivarkrets 1 hög signal
tror ni det räcker att byta temperatur givaren så löser det sig?
MVH
Bromölla
Projektråd till supran: http://www.garaget.org/forum/viewtopic.php?id=167349
Avstängd
10 388 Inlägg
6 december 2012
MVH
Orkar inte översätta;
The engine coolant temperature (ECT) sensor is a thermistor screwed into a coolant passage in the cylinder head. Sensor resistance is high when coolant temperature is low and resistance drops when coolant temperature increases. The powertrain control module (PCM) provides a 5 volt reference and a ground to the sensor. The PCM monitors voltage drop to determine coolant temperature. If the ECT reads less than freezing temp. when engine has been running for more than a few minutes, the PCM determines a circuit fault and sets this code. Or if the PCM determines the sensor resistance is out of specs, this code is set.
Potential Symptoms
Symptoms of a P0118 could include:
Very poor fuel economy
A no start condition
Vehicle may start, but run very poorly, blowing black smoke, running very rough and misfiring
Illumination of MIL
Causes
A code P0118 may mean that one or more of the following has happened:
A bad connection at the sensor
An open in the ground circuit between the ECT sensor and the PCM
A short in the voltage feed between the sensor and the PCM
A bad PCM (less likely)
A bad temperature sensor (shorted internally)
Possible Solutions
First, if you have access to a scan tool, check the reading of the coolant sensor. Does it read a logical number? If so, the problem is likely intermittent. Perform a "wiggle" test by wiggling the connector and harness to the sensor while watching the reading on the scan tool. Watch for any drop-outs. Drop-outs would indicate a bad connection. If the scan tool reads an illogical temperature, check the resistance of the temperature sensor. If it is out of specs, replace it. If it is in specifications, unplug the sensor and, using a fused jumper wire, jumper the two terminals of the connector together. The temperature reading should now be maxed out to above 250 degrees F. If not, there is likely a problem with the ground circuit or voltage supply.
Check for 5 volts reference voltage at the connector. Also check for ground presence at the connector. If you do not have 5V ref. and/or ground continuity, check for these back at the PCM connector. If you have these at the PCM connector, then repair open or short between the PCM and the sensor. If you do not, remove the offending wire from the PCM and then check for proper voltage at the PCM pin. If it's present now, repair short on the circuit. If it isn't present after removing the wire and checking the pin, replace PCM
NOTE: Usually, P0118 is indicative of a bad temperature sensor, but doesn't rule out these other possibilities. If you're unsure of how to diagnose a PCM, do not attempt.
170 Inlägg
6 december 2012
tack för svaret. men då är det förmodligen som jag skrev att byta tempgivaren så ska det vara löst?
Bromölla
Avstängd
10 388 Inlägg
6 december 2012
Verkar rätt troligt ja
170 Inlägg
6 december 2012
har läst runt lite och sett att fler haft samma problem och folk säger byt tempgivare så får börja med det.
Tack för hjälpen!smile
Bromölla
Avstängd
10 388 Inlägg
6 december 2012
Det är en (antar jag) billig och lätt sak att börja med iaf smile
Så lite så
