5856
Har toyota soarer samma chassi/bromsar/fram-bakvagn som supra mk4?
7 Inlägg
23 september 2014
Tjena, har en toyota soarer och funderar alltså på min fråga i rubriken?
huh?
10 427 Inlägg
26 september 2014
För att citera info på Wikipedia:
"Mark IV (A80; 1993–2002)
With this version Toyota took a big leap in the direction of a more serious high-performance car. Again using subframe, suspension,and drivetrain assemblies from the Z30 Soarer (Lexus SC300/400), test model pre-production started in December 1992 with 20 models,"
http://en.wikipedia.org/wiki/Toyota_Sup … .932002.29
Risken finns väl wink
"Z30 Soarers share alot of parts with many of the big Toyotas, front upper arms are common to Aristo/GS300, Supra, Soarer. Not 100% sure on front lowers, look the same but have totally different part numbers.
Rear upper and lower same as Supra, but the bushes are slotted on the Soarer and not on the Supra.
Again coilovers are common across the Aristo/Supra/Soarer. As are brakes. The LS400 calipers fit but you will have to grind bits off them to make them fit, or fit an RCA kit.
Track rod ends the same, not sure about roll bars but they look very similar and share the same drop links "
http://www.driftworks.com/forum/technic … oarer.html
Söker man lite så hittar man en del, men lite flummigt kanske.
