3884
wolkswagen split bus type 2
Totalrenovering av vw split bus type 2 T1 RHD 1962.Elsystemet ska bytas från 6v till 12v motor från 1200cc till 1500cc framöver blir det en massa förbättringar :)
1 004 169 Visningar
Uppdaterades senast 24 januari
3 746 Inlägg
6 oktober 2022
då var motorn ur. avgas toppar kolvar kylning bort taget
nu ska det beställas grejer så den blir tät å går fint igen smile
https://www1.garaget.org/gallery/images/38/37069/37069-3f9857b2000d965c6499f13dead5cec8.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-8e33220dec97aff83e9bae3c7e2ba46a.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-5e834946c56c0d3621a43da3bf840305.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-d1858b8fc734a3859756e79ce63735d9.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-d3557ac4730d6acb8236b26a43f4d884.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-5239e22d337925ee06ea427576bf2ee1.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-c30e40e13d6e15b287122a086625f0b3.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-ed52b94ecb24980b06417428c2188164.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-240ebe6296f434c7198633043945c207.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-f877078befd426b8e5dd9da293416e86.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-46419fb6364b9065d11a480d237efb31.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-3c763a1a53948ece26e62695cbfd5051.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-06105e20afca964ce4e0300afd073919.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-fe9a66204d499aea427e78ba83b77f86.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-dbe8c0de77a04ef195a3c27eeb96196e.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-a43360dee78919a6dd0e0182c4f340eb.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-d455ed335b4b8fa7af2348de6979c2eb.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-79ad419884063dd13cbeab69366cd051.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-2c08e599f4e4150a437f629e25b53426.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-bb3cf8a29c3a523a4e6653f0f300cd33.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-e655d92cac1c635542c1a02a05049685.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-af5655dbd87b1ce04a023da566784c46.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-30327dec1938a52cff75a60f921be10f.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-177ba878239ce96ddd7403864be91631.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-ba80d1288f2ee33c199135aa0ca147ef.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-d96695978fd2d080d814fa09a4d6b87f.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-17e0df83b491f3dc8f47f33b85d47a29.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-46b8c100a4e0e5e35e7bad1d5a3c0dce.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-cfca9a1e7f49715c7e1340eb96da4231.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-e909d910208a1c02bc9b556ea74707ea.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-3b9d261dadfbaed7d646a3912a683f43.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-c44fd1d5b12b2709515d52e3ef736977.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-5e41ffb98e8a403a4791b1a72ecf4416.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-f8b0a9739b2639ec578cc39e696dde6a.jpg
vw bubbla beetle barndoor splitbuss
1 049 Inlägg
13 oktober 2022
#2162
Ser ut som ringarna läckt lite. Har du mätt spelet mellan kolv och cylinder, de motorerna kan skramla lite.
3 746 Inlägg
14 oktober 2022
Ja tänkte horna cylindrarna och byta till 1600cc kolvar smile
Senast redigerat av Dr_snuggels (14 oktober 2022)
3 746 Inlägg
28 november 2022
jappp bara läckt lite -.....men motorn är ju från 1968 så efter 54år så får den vara lite sliten.skramla eller rasla inget i motorn gick som en dröm smile förutom oljeläckan men det löses med nya packningar smile
3 746 Inlägg
28 november 2022
inte hänt så mycket här. väntar på delar till inredning och är sugen på att beställa detta kitt.så från 1500cc till 1600cc blir lite mer vrid och fart i kärran smile
https://www1.garaget.org/gallery/images/38/37069/37069-6b18592606b999f3d0692d29e6e44c0d.jpg
1 317 Inlägg
28 november 2022
#2166
Köper du de kittet får du väl vikta ner framkofångaren då den kommer skicka upp framhjulen i luften varje ggn du kliver av kopplingen...hehehehe
3 746 Inlägg
28 november 2022
ajaj blir ju massa extra jobb är det inte bättre att ja går upp i vikt smile  smile
1 049 Inlägg
28 november 2022
#2168
Beställ inte innan du kollat vad ett strokerkit till 2,2 liter kostar. bör gå att finna begagnat. Veven behöver bytas och viss bearbetning av blocket, delar bör finnas begagnade då de är en populär uppgradering vad jag sett i motortidningar.
3 746 Inlägg
29 november 2022
går ja upp så mycket så drar det med sig mer grejer som skivbromsar/byta till bubbla vlåda drivaraxlar måste sänkas då det blir helt annan vinkel.så ja kommer hålla men till typ orginal hk ja blir ju lite lite mer nu.kan i framtiden kanske bygga om den till nått mycket värre smile detta räcker gott och väl när man har redutionsaxlar och man varvar sönder motorn
3 746 Inlägg
1 december 2022
toppar och fördelar förgasaren hamnade i ett bad. låter do ligga där ett tag så dom blir rena å fina tills motorn ska, sättas ihop smile
https://www1.garaget.org/gallery/images/38/37069/37069-aad5943a9754677c91b6fd6772c70056.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-2e3de32bcf02030f0da9740b31283a3d.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-4ab80b5ade7d0974c3a80674b1a1f20d.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-4205b252cb43351e20dc23d23218f01f.jpg
3 746 Inlägg
13 december 2022
var och titta på nya splitbussen hmm nja ja vet inte
https://www1.garaget.org/gallery/images/38/37069/37069-8c40651c1f57cd564b42f73757a9a71e.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-81b4382e0f226540bde6fb559cef3018.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-96b0a098f559126c858a4bc8fe2d36ad.jpg
Senast redigerat av Dr_snuggels (13 december 2022)
3 746 Inlägg
19 december 2022
beställde dessa små godingar i maj idag döck dom hem 🙂
https://www1.garaget.org/gallery/images/38/37069/37069-260b3a345912162ec70e1b0adf173036.jpg
https://www1.garaget.org/gallery/images/38/37069/37069-decb731dbb742738bbbaac68820e1431.jpg
Lastbilsmekaniker
5 268 Inlägg
20 december 2022
#2173
Bättre sent den aldrig, beställde en sak på Volvo för något år sedan glömde bort det för delen var restad tog nästan ett år innan delen helt plötsligt hade anlänt😂
3 746 Inlägg
20 december 2022
oj var ju ingen stress me dessa är skruvar till panelerna på insidan. Men ville ju ha dom så man kan snygga till insidan 🙂
363 Inlägg
15 januari 2023
#2175
3 746 Inlägg
15 januari 2023
Giuseppe skrev:
https://www.linkedin.com/posts/activity-7020303595229048833-nZMs?utm_source=share&utm_medium=member_ios
Inspiration till nästa projekt smile
kan inte så sad
363 Inlägg
16 januari 2023
#2177
https://www1.garaget.org/gallery/images/168/167987/167987-3780f2dac382325b1156d554a0bdc091.jpg
kan inte så sad
3 746 Inlägg
17 januari 2023
kan inte så sad
jaa den har ja sett så fränt bygge
3 746 Inlägg
31 januari 2023
så är grejerna på väg https://www1.garaget.org/gallery/images/38/37069/37069-89b86547fdf1bc4a37c2c7ed6cc5e65e.jpg
