14900
OBD2 Audi A3 8l -97 ?
18 Inlägg
26 augusti 2014
fick hem ett annat verktyg nu och fick fel koderna
00515: camshaft position sensor (half effect sensor)-no signal (G4):check CMP, if OK replace distributor
16487: mass or voltm air flow circuit-low input
17967: fanns inget i manualen men enligt google så står det  Throttle Valve Control.
någon som vet vilket man bör testa o byta ut först o se vilket funkar bäst ?
Avstängd
10 388 Inlägg
26 augusti 2014
00515 - Camshaft Position (Hall) Sensor (G40): No Signal
Possible Causes
Wiring to Camshaft Position (Hall) Sensor (G40) faulty
Possible Solutions
Check Wiring to Camshaft Position (Hall) Sensor (G40)
Check/Replace Camshaft Position (Hall) Sensor (G40)
Check/Replace Engine Control Module
Special Notes
Some older engines store this code as long as the engine is not running, if in doubt read fault codes with the engine running again.
16487/P0103/000259 - Mass Air Flow (MAF) (G70): Signal too High
Possible Symptoms
Probably no serious malfunctions
Loss of power
Possible Causes
Wiring and/or connections (short circuit?)
Mass Air Flow (MAF) (G70) defective
Possible Solutions
Check wiring and connections
Check / Replace Mass Air Flow (MAF) (G70)
Special Notes
In MY 1995-2002 (?) in Europe at VW-diesel-cars G70 had the bad reputation of slowly losing his performance, causing loss of power. It's not a matter of defective or breaking down, but it is filthy / dirty (not easy to clean). You can check functionality by making a log in [01-engine], [meas.blocks-08], group 003 (3e gear, full throttle, from 1700-4000rpm)
17967/P1559/005465 - Throttle Body (J338): Fault in Basic Settings
Possible Symptoms
Not known
Possible Causes
Idle Switch Open or Open Circuit
Throttle Valve sticks and won't close
Speed Impuls from Engine Speed Sensor (G28) recognized
Possible Solutions
Perform Throttle Body Adaptation
Så uppenbarligen; Sista skulle jag börja med och göra en TBA
(Tror spontant fortfarande det är portemuleringsfel med din kabel, men skit samma tongue )
Senast redigerat av it_mutt (26 augusti 2014)
18 Inlägg
26 augusti 2014
snackade med dom på Runns och dom sa att jag har en tidigare variant av obd så inte alla verktyg som fungerar tack vare de. och TBA är stortsätt bara en rengöring eller ?
Avstängd
10 388 Inlägg
26 augusti 2014
Ja, ELM funkar inte ex.vis, köper du en vagcom eller en kopia, så fungerar den så länge kabeln fungerar.
Så om du köpte; http://www.ebay.co.uk/itm/New-VAG-409-1 … 1c43fbd9a7 och kabeln fungerar, så fungerar den på din bil, oavsett vad trådspammarna från Runns säger (skapligt trött på det ja).
Nej, det är ingen rengöring utan en kalibrering bara.
- - Edit - -
Men, jag skulle radera koderna, ut o köra lite, och sen se vilka (om någon) som kommer tillbaka. Har du inte fått dessa raderade innan så vet du ju inte hur länge de legat lagrade smile
18 Inlägg
26 augusti 2014
okey möjligen lust o länka till en film hur man gör de ? smile
Avstängd
10 388 Inlägg
26 augusti 2014
INGEN aning alls om hur man gör det med ditt verktyg tyvärr. Får du liv i vcds-kablen så;
Procedure for performing a Throttle Body Alignment on Cable-Throttle Cars:
These are cars with a physical cable between the accelerator and the throttle, but WITHOUT an ISV.
Turn the key on but do not start the car.
[Select]
[01 - Engine]
[Measuring Blocks - 08]
Group 098 (Note: Some SIMOS or Marelli ECU's use Group 001 such as  ADY & AEE engines)
[Go!]
[Switch to basic settings]
Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switch to basic settings. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
[Switch to Meas. Blocks] button and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
18 Inlägg
26 augusti 2014
Avstängd
10 388 Inlägg
26 augusti 2014
Inte en blekaste tyvärr =/
Inget i manualen om det?
- - Edit - -
Vet ju iofs inte ens om den klarar det
18 Inlägg
26 augusti 2014
raderade felkoderna och körde en ny test och då visade den bara 00515
Avstängd
10 388 Inlägg
26 augusti 2014
Se där, det bättrar sig iaf smile
18 Inlägg
26 augusti 2014
men då är de ju bara kolla kopplingen till den om inte annat byta den sensorn då. om det inte är nåt annat som Engine Control Module som behövs bytas
Avstängd
10 388 Inlägg
26 augusti 2014
Mnja, styrdonet får vi väl hoppas att det inte är iaf.
Givarfel kan ju vara ... "spännande" =/
18 Inlägg
26 augusti 2014
okey. de som hände när bilen blev som den blev var de att jag körde lite lätt på en stubbe och pajade hela kylaren och neder delen av kofångaren bytte kylaren och den blev sån här
Avstängd
10 388 Inlägg
27 augusti 2014
Hmm, kan iofs inte säga hur kablage och annat går
- - Edit - -
Tog en titt, och ptja, det är väl inte omöjligt att kablaget till den fått sig "en jävel". Kan ju givetvis vara så att det bara är en tillfällighet att det hände samtidigt också
Senast redigerat av it_mutt (27 augusti 2014)
18 Inlägg
27 augusti 2014
får hoppas på fint väder imorgon då så man kan trycka in magen lite och lägga sig halvt under bilen o se om de skulle ha hänt för kunde inte redigt så nåt idag när jag ryckte och kollade kontakterna.
Avstängd
10 388 Inlägg
27 augusti 2014
Vilken motor har du?
18 Inlägg
28 augusti 2014
Avstängd
10 388 Inlägg
5 september 2014
CrackzY skrev:
1.8
Glömde ju svara;
Ja, då ska den ju sitta i "toppen" av motorn på höger sida (kan inte ge en bättre förklaring tongue) Hittar du inte den så ordnar vi väl fram en bild
