5427
Flywheel position problem B230et motronic
10 Inlägg
17 mars 2025
Hi, I have a problem. I took my Volvo with a 760 B230ET motronic engine to a garage to change the clutch, and they removed the flywheel without marking it first... and you can imagine what happened. I don't think my flywheel has any missing teeth. My engine model has two sensors next to each other, one is the rpm sensor and the other is the crankshaft sensor. It seems they positioned the flywheel incorrectly and of course... now I'll have to put the engine in top dead center and replace the flywheel. I can't find any references for my engine model (manual transmission B230et) and we're going crazy. I have no idea what references I have to follow, and the Haynes book doesn't have any information about this... could someone help me? Thank you very much to everyone.
Fri fart för ett fritt folk!
15 286 Inlägg
18 mars 2025
On b220ft/fk you  zero engine and missing
teeth pointing to startmotor hole.  But dont know if it same on a b230et.
Senast redigerat av Growe (18 mars 2025)
10 Inlägg
18 mars 2025
Hello, thanks for responding. In motronic I believe there are no missing teeth, it is a model with 142 teeth. From what I have been able to find out, there is a flat tooth that with the engine at TDC you have to put it below the crank sensor... its motronic system
6 041 Inlägg
18 mars 2025
Found this thread with a guy that has the same problem
https://volvoforums.com/forum/volvo-240 … ms-101872/
He does not seem to have got it fixed.
Sadly there is very little info to be found of the motronic cars, best would be if someone found an old Volvo repair-manual on this engine
15 286 Inlägg
18 mars 2025
it is a shit engine so no one cares smile
but its easy to fix..  put flywheel in  mark it  without gearbox and clutch    test start.  if its not working   move it a clockwise one bolt hole  test start..
even if you try all ways it can sit its takes only 15-20min to test it.. smile
10 Inlägg
18 mars 2025
even if you try all way it can sit its only 15-20min to test it.. smile
"The motronic flywheels I've seen (B230ET) only have 1 single pip at TDC for one sensor the other countered the ring gear teeth."
I think setting it to TDC with the flat tooth aligned above where the crankshaft and rpm sensors are is the right way to go. I'm going to try it today and let you know, thanks a lot. (It's true that it's a shitty engine because the ECU doesn't accept changes, but I have it at 250 hp in drift configuration and it's really, really fun. When I can, I'll switch to a programmable ECU.)
10 Inlägg
19 mars 2025
nobody have a B230ET motronic open it? i need help please, thanks guys!!!!!
10 Inlägg
19 mars 2025
if next monday is not fixed, i tried your answer. Thanks a lot. ( my volvo have 250cv drift fitment, and is a nice car jajaja with a shit ecu)
thanks a lot
https://www1.garaget.org/gallery/images/242/241087/241087-379f191efe7ce0f801619f9546b08359.jpg
10 Inlägg
26 mars 2025
Hi guys, thanks a lot for the help. Thanks to someone on another forum, I was able to fix it. I'm leaving this contribution here in case anyone else has the same problem.
Put the car in TDC and position the flywheel with the sensor's pin near the starter motor hole, at about 9:00 AM if you look at it from behind. If you look at it from in front of the engine, it would be 3:00 PM. And everything is perfect. B230ET Motronic engine.
Regards and thanks.
