2415
Flywheel position problem B230et motronic
5 Inlägg
för 6 timmar sedan
Hi, I have a problem. I took my Volvo with a 760 B230ET motronic engine to a garage to change the clutch, and they removed the flywheel without marking it first... and you can imagine what happened. I don't think my flywheel has any missing teeth. My engine model has two sensors next to each other, one is the rpm sensor and the other is the crankshaft sensor. It seems they positioned the flywheel incorrectly and of course... now I'll have to put the engine in top dead center and replace the flywheel. I can't find any references for my engine model (manual transmission B230et) and we're going crazy. I have no idea what references I have to follow, and the Haynes book doesn't have any information about this... could someone help me? Thank you very much to everyone.
