10800
Felkodsläsare från www.vvme.com bra ??
1 749 Inlägg
1 maj 2010
sandzoo skrev:
patrikke skrev:
Japp, men det kanske har att göra med att jag har en diesel??
Har ingen annan bil hemma att testa den på heller för tillfället.
borde ej ha nån betydelse om de e diesel eller ej ? :S
vad fick du ge för din GS500 ??
Jo, det har betydelse om det är diesel eller inte:(
Min kostade ca 700 kronor efter tull och moms och "behandlingsavgift"
Alla stavfel ni hittar i mina inlägg ska vara där, det är alltså meningen med dem och ingen felstavning.
2 072 Inlägg
1 maj 2010
men du har OBD2 på forden eller?
de va ej så farligt smile köpte du den på vvme.com ?
Sandzoo i da house
1 353 Inlägg
1 maj 2010
sandzoo skrev:
vad är skillnaden mellan OBD1 och OBD2 ?
What is the difference between OBD 2 and OBD 1? With OBD 1 each manufacturer used their own unique codes and definitions for identifying failures in the computerized engine management system.
This made it difficult on auto mechanics, servicing multiple vehicle brands. With OBD2 common codes and definitions were developed to identify all basic emissions related failures OBD 2 trouble codes consist of one alpha character followed by four digits.
The alpha character indicates the area of the vehicle were the failure occurred. This includes B for body, C for chassis, P for power train, and U for network.
The network would be considered a manufacturer specific code used only on a specific model or brand.
The body would include the airbag system or SRS codes. This includes all discriminating crash sensors, clock spring and the air bag deployment module.
The chassis would include ABS codes as well as suspension codes if the vehicle is equipped with active suspension.
The power train includes the transmission and engine codes. This is by far the most common system to set computer trouble codes.
The first digit of the diagnostic trouble code denotes the origin of the code. Check engine light codes authored by the Society of automotive engineers or, SAE are identified by zero.
Hittade på http://www.auto-facts.org/OBD-2.html , står lite mer fakta där också.
There's no replacement for displacement
711 Inlägg
26 juni 2010
Vet nån med säkerhet att den från kjell funkar till min S40 99?
http://www.kjell.com/?item=48224&pa … ,317000000
Eller vet nån en som funkar till min!?
2 Inlägg
12 februari 2011
sandzoo skrev:
hoj alla garagare..
funderar på att innskaffa en felkodsläsare och har hittat billigt på vvme.com
nån som vet om de är bra.. eller nån som har en och kan utrycka sig smile
gäller denna mod... : http://www.vvme.com/gs500-universal-han … l?cPath=19
kostar ca 500-550sek med frakt o allt smile
något att satsa på eller ?
de ta ju cirka 200-400 för en felsökning på verksad :S
inte så säker på om det är bra att använda eller inte .... men det verkar som detta VVME märke är populärt här ....
62 Inlägg
13 oktober 2011
Ni som har en vag405 hur uppdaterar man mjuvaran i enheten via usb?
