5950
BMW E30 Street/TimeAttack (DTM style control arms)
-work in progress-
143 283 Visningar
Uppdaterades senast 22 augusti 2018
144 Inlägg
25 mars 2016
Roligt att höra! smile
Exhaust manifold finally welded together, but still needs wastegate piping and coating:
http://i187.photobucket.com/albums/x281/mice325/pakosadsi_zpsi5s6yp18.jpg
Virtuell Designer
545 Inlägg
25 mars 2016
#122
Holy f*cking moley what a project! Ser riktigt bra ut! Följer med spänning! smile
144 Inlägg
5 april 2016
Wastegate arrived quickly, also got few stickers:
http://i187.photobucket.com/albums/x281/mice325/wastegate50_zpsqhsbybc0.jpg
Then I started to make wastegate piping, need to make a mild steel flange though, I don't like to mix it to stainless steel:
http://i187.photobucket.com/albums/x281/mice325/wastegate501_zpsvrrfuned.jpg
144 Inlägg
7 april 2016
Story continues:
http://i187.photobucket.com/albums/x281/mice325/hukkistatinaillen_zpsvzuf4dt9.jpg
Divided all the way to valve, with sophisticated testing (by blowing air into primaries) the flow seems to find its path well towards the wastegate:
http://i187.photobucket.com/albums/x281/mice325/WP_20160407_20_43_08_Pro__highres_zpsydrcy0ka.jpg
144 Inlägg
16 april 2016
Recently I've machined and bought some new stuff.
Current engine mounts were kind of temporary, never welded them complete, because turbo and supercharger locations were only approximate.
I wanted a lower design to clear the turbo intake pipe.
The design, steel sleeve with delrin bushing:
http://i187.photobucket.com/albums/x281/mice325/moottorikannake_zps5ih18uqe.jpg
This was something I could machine by myself roll
http://i187.photobucket.com/albums/x281/mice325/moottorikannake2_zpsmxitmuiq.jpg
Obviously I had to mockup alternator location before making intake/charge air piping, but the old one had seen it's best days. Instead of refurbishing and machining new pulleys for the old one I bought a new, smaller, modern alternator:
http://i187.photobucket.com/albums/x281/mice325/laturit_zpsaqtblilc.jpg
This spring and summer will probably be busy time with the project, more parts is already on the way tongue
144 Inlägg
4 maj 2016
Some new bits acquired, Toyota MR2 electric power steering pump. Remain to be seen if it's even working, connectors had damaged badly during shipping...
http://i187.photobucket.com/albums/x281/mice325/mr2electricpowersteeringpump_zpsutcpdc7b.jpg
Today's job was to make another front fender, it was easy one, I used the same cardboard templates which I made for the driver's side:
http://i187.photobucket.com/albums/x281/mice325/WP_20160504_21_37_27_Pro__highres_zps1i5zpcye.jpg
Extra pic:
http://i187.photobucket.com/albums/x281/mice325/ilta_arska_e30_zpshulrjrz0.jpg
374 Inlägg
5 maj 2016
#127
Det ser riktigt bra ut, kämpa på! Kommer du att tävla i Sverige nånting eller blir det bara i Finland?
Ta gärna en titt i min projekttråd!
Ricke Ws Volvo 740 projekt
144 Inlägg
5 maj 2016
Tackar! Mest i Finland, men jag vill också delta i någon Gatebil event om vi har tid.. cool
144 Inlägg
15 maj 2016
This will be a frustrating and time-consuming job roll 1 out of 4 corners in progress, after spraying a paint layer I noticed one spot needed to be cut open and hammered down.
http://i187.photobucket.com/albums/x281/mice325/WP_20160511_21_02_57_Rich__highres_zpshsqppjfr.jpg
http://i187.photobucket.com/albums/x281/mice325/WP_20160514_21_18_32_Rich__highres_zpsa57enneo.jpg
Finally got all the parts for the control arms, roll-center/bump steer -adapter fits perfectly cool
http://i187.photobucket.com/albums/x281/mice325/WP_20160512_20_20_45_Rich__highres_zpsgz3olt5b.jpg
Also few lengths of aluminium tubing appeared this week, need to build up something of those
http://i187.photobucket.com/albums/x281/mice325/6tag_110516-111754_zpsc853fp5e.jpg
144 Inlägg
19 maj 2016
Thanks cool
Earlier this week I bought few liters of paint, should be plenty for mock-ups and molds. I picked the same hue which might be the final color, we'll see...
At this point the fender starts to look like something, but still a lot to do. A couple of bigger dents showed up after the first gray paint layer.
http://i187.photobucket.com/albums/x281/mice325/IMG_7332_zpsxh5hrp5o.jpg
But... this will probably do, picture taken this evening. I'm afraid something goes wrong when I start to mess up with fiberglass big_smile
http://i187.photobucket.com/albums/x281/mice325/IMG_7342_zpsz82mzzru.jpg
I think I should take the camera more often with me, mobile pics look crap besides these..
144 Inlägg
20 maj 2016
The color, I like cool Paintwork not so perfect but ok for molding
http://i187.photobucket.com/albums/x281/mice325/lokarivari_pieni_zpsxh99mppm.jpg
-sommar ska de va....
4 545 Inlägg
21 maj 2016
#133
Så jäkla läckert!
75 Inlägg
21 maj 2016
#134
följer detta
374 Inlägg
21 maj 2016
#135
Hur stor del av karossen kommer du bygga i glasfiber?
2Fast4You
499 Inlägg
21 maj 2016
#136
Det kanske är i väldigt tidigt skede att ställa denna fråga men, vad har du tänkt för färg på den när du börjar bli klar?
Hade varit kul att veta så man kan se bilen framför sig i huvudet!
203 Inlägg
21 maj 2016
#137
Han skrev ju att den färgen han lackade med nu kan bli den färgen han kommer använda så om du tittar på bilden han la upp så ser du ju vad det är för färg.
144 Inlägg
21 maj 2016
Precis så Victor smile Och stort tack för alla!
Jag kommer bygga alla skärmar, dörrar, tacklucka, huven osv. i glasfiber så bara inre karosseri och tak är i plåt. Hoppas det väger några kilo mindre. big_smile
261 Inlägg
22 maj 2016
#139
Fan så sjukt!
Detta måste man följa.  big_smile
Besök gärna mitt Ke70 driftingprojekt
203 Inlägg
22 maj 2016
#140
Det är en jävligt snygg färg kan jag tillägga!
