DEN FÖRSTA FREESTYLEN KOM 1979.
DEN FÖRSTA ÄGAREN TILL FÖRETAGET MARLBORO DOG I LUNGCANCER.
DET FINNS ÖVER 500 NAMNGIVNA FOBIER. EN AV DE MER SÄLLSYNTA ÄR HOPLOFOBIN DÄR MAN ÄR RÄDD FÖR BRANDBILAR.
GLOBALT SETT FINNS DET TOTALT 17 000 FLYGPLAN, VARAV 4000 ALLTID FLYGER.
90% AV NEW YORKS TAXIFÖRARE ÄR NYLIGEN ANLÄNDA INVANDRARE.
MADAGASKAR UTANFÖR AFRIKAS ÖSTKUST ÄR VÄRLDENS FJÄRDE STÖRSTA Ö.
CHARLES BRONSON HETTE FRÅN BÖRJAN CHARLES BUCHINSKY OCH ERIC CLAPTON HETTE FAKTISKT SÅ MYCKET SOM ERIC PATRICK CLAPP.
ORDET AMATÖR KOMMER FRÅN FRANSKANS ORD FÖR ÄLSKARE, AMATEUR.
3S % AV ALLA SOM ANNONSERAR I KONTAKTANNONSER ÄR REDAN GIFTA.
FRAM TILL I BÖRJAN AV 1900-TALET SÅ SÅLDES DET RENT KOKAIN PÅ HARRODS I LONDON.
OM DU BESTÄLLER VIKING-RYORI I JAPAN FÅR DU PLOCKA MAT FRÅN ETT SMÖRGÅSBORD.
REMBRANDTS MORFAR VAR BAGARE.
HARPO MARX GJORDE SIG EN PLOJ AV ATT INTE SÄGA ETT ORD I DE KLASSISKA FILMERNA HAN GJORDE MED SINA BRÖDER. I VERKLIGHETEN HADE HAN INGA SOM HELST PROBLEM ATT PRATA.
KLOCKAN I THE CLOCK TOWER PÅ WESTMINSTER BRIDGE I LONDON,I FOLKMUN KALLAT BIG BEN, ÄR EN KLOCKA SOM GÅR PERFEKT. 1945 SACKADE DEN SIG DOCK MED FEM MINUTER. ORSAKEN VAR EN FLOCK STARAR SOM SATT SIG PÅ MINUTVISAREN.
DET FINNS TRAFIKLJUS PÅ VENEDIGS KANALER.
ORDET SKOLA KOMMER FRÅN GREKISKANS SKHOL SOM BETYDER FRITID; TID FÖR ANDLIGA ÖVNINGAR.
I DEN AMERIKANSKA STADEN MONTPELIER ANORDNAS VARJE ÅR EN TÄVLING OM VEM SOM HAR DE MEST UTSLITNA SPORTSKORNA. TÄVLIGEN HETER "ANNUAL INTERNATIONAL ROTTEN SNEAKER CONTEST".
METALLEN OCH GRUNDÄMNET GALLIUM HAR EN KUL EGENSKAP. OM DU LÄGGER EN BIT AV METALLEN I DIN HAND SMÄLTER DEN. DESS SMÄLTPUNKT ÄR NÄMLIGEN 29,76 GRADER CELSIUS.
EN ÄLG HAR FYRA MAGAR.
REGISSÖREN ALFRED HITCHCOCK GJORDE SIG EN GIMMICK GENOM ATT VARA MED I SINA EGNA FILMER I NÅGRA SEKUNDER. MEN I LÅNGT IFRÅN ALLA - 125 AV HANS FILMER SER MAN INTE RÖKEN AV HONOM.
EN RÅTTAS TÄNDER VÄXER CIRKA 15 CENTIMETER PÅ ETT ÅR.
HISINGEN NORR OM GÖTEBORG ÄR SVERIGES FJÄRDE STÖRSTA Ö.
ADOLF HITLER FÖDDES I ÖSTERRIKE OCH FLYTTADE TILL TYSKLAND FÖR ATT UNDSLIPPA MILITÄRTJÄNSTEN.
JAPAN HAR VÄRLDENS ÄLDSTA NATIONALSÅNG.
EN KROKODIL KAN INTE STICKA UT SIN TUNGA.
UNDER EN VANLIG DAG KOMMER DIN HAND INDIREKT ATT KOMMA I KONTAKT MED 15 ST PENISAR.
STEWIE WONDER SKIVDEBUTERADE NÄR HAN VAR 12 ÅR GAMMAL.
HOLLAND OCH NEDERLÄNDERNA ÄR INTE SAMMA SAK. NATIONEN HETER NEDERLÄNDERNA OCH HAR GJORT DETTA SEDAN 1500-TALET. HOLLAND BESTÅR AV TVÅ PROVINSER SOM TILLSAMMANS UTGÖR CIRKA EN SJÄTTEDEL AV NEDERLÄNDERNAS YTA.
EN KO RAPAR VAR 40:E SEKUND.
INNAN DE BYTTE TILL SINA NYA NAMN HETTE DEMI MOORE DEMETRIA GUYNES OCH WALTER MATTHAU HETTE WALTER MATUSCHANSKATASKY.
GENOMSNITTSÅLDERN FÖR EN PORSCHEÄGARE ÄR 49 ÅR OCH FÖR EN HARLEY DAVIDSONFÖRARE 52 ÅR.
DE AUSTRALIENSISKA URINVÅNARNA HAR FLER TÄNDER ÄN ANDRA MÄNNISKOR.
PÅ 1950-TALET LÅG DEN SVENSKA PASTAKONSUMTIONEN PÅ 0,8 KG PER PERSON OCH ÅR. IDAG ÄTER SVENSKEN I GENOMSNITT CIRKA 7 KG PER PERSON OCH ÅR.
I FAIRBANKS, ALASKA FINNS EN LAG SOM FÖRBJUDER ÄLGAR ATT HA SEX PÅ STADENS GATOR.
EN MAN FÅR CIRKA 7200 UTLÖSNINGAR UNDER SIN LIVSTID.
MEDELHASTIGHETEN FÖR EN MANS UTLÖSNING ÄR 44 KM/H.
VALAR HAR INGA STÄMBAND.
JAMES DEAN HETTE FRÅN BÖRJAN JAMES BYRON OCH WHOOPI GOLDBERG HETTE FAKTISKT SÅ MYCKET SOM CARYN JOHNSON.
ENDAST 55% AV ALLA AMERIKANER VET ATT SOLEN ÄR EN STJÄRNA.
ODDSEN FÖR ATT DÖ GENOM ATT RAMLA UR SÄNGEN ÄR 1 PÅ 2 MILJONER.
I MEDELTAL SVÄLJER VARJE PERSON TRE SPINDLAR PER ÅR.
EINSTEIN KUNDE INTE VID NIO ÅRS ÅLDER PRATA RENT. HANS FÖRÄLDRAR MISSTÄNKTE ATT HAN VAR UTVECKLINGSSTÖRD.
DE FLESTA "MOTTAGAREN BETALAR" SAMTALEN SKER PÅ FARS DAG.
GEORGE WASHINGTON ODLADE MARIJUANA I SIN TRÄDGÅRD.
OM DU SIMMAR EN TIMME I EN ALLMÄN POOL KOMMER DU ATT HA KOMMIT I KONTAKT MED UNGEFÄR EN OCH EN HALV LITER URIN.
FLER ÄN 110 MILJARDER TAMPONGER HAR SÅLTS SEN 1936.
SKULLE DET VARA SÅ ATT MAN HAR EN SJUKLIG RÄDSLA FÖR MÄN SÅ LIDER MAN AV ANDROFOBI.
PÅ ETT ÅR KOMMER DU HA SVALT 14 INSEKTER, I SÖMNEN.
ÅRLIGEN KOMMER DU SKAKA HAND MED 11 KVINNOR SOM NYLIGEN ONANERAT OCH DÄREFTER INTE TVÄTTAT HÄNDERNA.
UNDER EN LIVSTID KOMMER I GENOMSNITT 22 ARBETARE (SNICKARE, ELEKTRIKER MM.) ATT HA GÅTT IGENOM INNEHÅLLET I DIN TVÄTTKORG.
DAGLIGEN INANDAS DU CA 1 LITER AV ANDRA MÄNNISKORS FISAR.
EN RÅTTA KAN KLARA SIG UTAN VATTEN LÄNGRE ÄN EN KAMEL.
VÄRLDENS VANLIGASTE NAMN ÄR MOHAMMED.
UNDER SIN LIVSTID ÄTER EN VANLIG MAN 50 TON MAT.
DE FLESTA MÄNNISKOR SOMNAR INOM SJU MINUTER.
DET UPPTÄCKTES UNDER EN RYMDFÄRD ATT GRODOR KAN KRÄKAS. GRODAN KRÄKS UPP SIN MAGE FÖRST, SÅ ATT DEN HÄNGER UT UR MUNNEN. SEDAN ANVÄNDER GRODAN SINA FRAMBEN TILL ATT PLOCKA BORT ALLT INNEHÅLLET FÖR ATT SEDAN SVÄLJA NED MAGEN IGEN.
DEN MÄNSKLIGA KROPPEN INNEHÅLLER TILLRÄCKLIGT MYCKET FETT FÖR ATT TILLVERKA SJU TVÅLAR OCH TILLRÄCKLIGT MYCKET JÄRN FÖR EN SJU TUMS SPIK.
26 ASTRONAUTER HAR RAPPORTERAT ATT DE SETT UFON NÄR DE KRETSAT KRING JORDEN.
DIN HJÄRNA ANVÄNDER 10 GÅNGER MER SYRE ÄN RESTEN AV DIN KROPP.
HÖGER TESTIKEL VÄGER I GENOMSNITT 10 GRAM HOS EN KINES OCH 22 GRAM HOSEN EUROPE.
FLADDERMUSEN ÄR DET ENDA DÄGGDJUR SOM KAN FLYGA.
LORD NELSON SAKNADE TVÅ KROPPSDELAR - ETT ÖGA OCH ETT BEN.
DET ÄR INTE BARA I "PULP FICTION" SOM DE ÄTER HAMBURGAREN "BIG KAHUNA BURGER". I TVÅ UTAV QUENTIN TARANTIONS ANDRA FILMER, "FROM DUSK TILL DAWN" OCH "RESERVOIR DOGS", ÄTS DE OCKSÅ.
DET FINNS HÖNS SOM LÄGGER GRÖNA ÄGG.
MELLAN 1990 OCH 1992 DÖPTES INGA POJKAR I SVERIGE TILL BERT.
DET VAR PASTAN SOM FRAMTVINGADE UPPFINNINGEN AV BORDSGAFFELN. I NEAPEL ÅT MAN I HUNDRATALS ÅR MAKARONER MED FINGRARNA. MEN VID HOVET SATT MAN JU I GULDSTICKADE SIDENDRÄKTER OCH DÄR GICK DET INTE FÖR SIG ATT KLADDA. DET VAR FERDINAND, VICE KUNG I SPANIEN, SOM LÄT UPPFINNA GAFFELN. HAN VAR MYCKET FÖRTJUST I MAKARONER.
DET FINNS INGA FISKAR I DÖDA HAVET.
DET KRIG MELLAN ENGLAND OCH FRANKRIKE SOM KALLAS HUNDRAÅRSKRIGET PÅGICK MELLAN 1337 OCH 1453 - ALLTSÅ 1116 ÅR!
UNDER NIO VECKOR DELADE VINCENT VAN GOGH ATELJÉ MED PAUL GAUGUIN. DE TVÅ KONSTNÄRERNA BRÅKADEOFTA MED VARANDRA OCH I ETT VANSINNIGT ANFALL SKAR VAN GOGH AV EN BIT AV SITT VÄNSTRA ÖRA.
LIDER DU AV ONOMATOFOBI ÄR DU ORDENTLIGT RÄDD FÖR ATT HÖRA VISSA NAMN ELLER ORD.
ÅTERVINNING ÄR VANLIGT I FILMER, EXEMPELVIS SÅ ÄR DEKOREN FRÅN AXIS KEMIKALIEFABRIK I "BATMAN" ÖVERBLIVEN DEKOR FRÅN KLASSIKERN "ALIEN" OCH MYCKEN TAKDEKOR OCH BYGGNADER I "MATRIX" ANVÄNDES I "DARK CITY" FRÅN ÅRET INNAN.
VÄRLDENS LÄNGSTA RULLTRAPPA FINNS I S:T PETERSBURG - 729 STEG FÖR DEN ÅKANDE ÖVER 59 METER NER I ELLER UPP UR DJUPET.
DVÄRGMISTELN HAR ETT INTRESSANT SÄTT ATT SPRIDA SINA FRÖN. NÄR DE HAR MOGNAT SÅ EXPLODERAR DE OCH SKJUTER IVÄG SINA FRÖN MED EN HASTIGHET AV OMKRING 54 KM/H.
FÖRKORTNINGEN "EEG" STÅR FÖR ELEKTROENCEFALOGRAFI.
QUENTIN TARANTINO SKREV FRÅN BÖRJAN ROLLEN SOM MR PINK I "RESERVOIR DOGS" TILL SIG SJÄLV. STEVE BUSCEMI FICK DOCK ROLLEN.
WALKIE-TALKIE HETER PÅ FRANSKA TALKIE-WALKIE OCH SJUKDOMEN AIDS HETER SIDA.
DEN RÖDA CIRKELN PÅ JAPANS FLAGGA SKA SYMBOLISERA DEN UPPÅTGÅENDE SOLEN.
VINCENT VAN GOGH LYCKADES UNDER SITT KORTA LIV BARA SÄLJA EN ENDA TAVLA, TROTS ATT HAN MÅLADE ÖVER 800 MÅLNINGAR OCH 700 TECKNINGAR.
1970 FÖRSÖKTE SOVJETISKA VETENSKAPSMÄN TRÄNA KATTER ATT STYRA ROBOTAR. FÖRSÖKET MISSLYCKADES.
13 PERSONER DÖR VARJE ÅR AV FALLANDE GODIS - OCH LÄSKAUTOMATER.
ELEFANTENS HJÄRNA ÄR FEM GÅNGER STÖRRE ÄN MÄNNISKANS.
DE FÖRSTA EGYPTISKA MUMIERNA BALSAMERADES INTE UTAN LADES I DEN TORRA ÖKENSANDEN SÅ ATT DE SKULLE TORKA OCH INTE RUTTNA.
VALAR KAN HA LÖSS.
BENSIN ÄR I SIG SJÄLV HELT FÄRGLÖS MEN FÄRGAS RÖD ENBART FÖR ATT MAN INTE VILL RISKERA ATT MAN AV MISSTAG FÖRVÄXLAR VÄTSKORNA VID HANTERINGEN.
DEN FÖRSTA MASSAGEAPPARATEN UPPFANNS 1869 OCH DREVS AV ÅNGA.
ENLIGT EN UNDERSÖKNING HAR HÄLFTEN AV ALLA MÄN SOM VUXIT UPP PÅ BONDGÅRDAR HAFT SEXUELLA KONTAKTER MED DJUR.
JORDNÖTTER ÄR INGA NÖTTER UTAN EN ÄRTVÄXT. ENGELSKANS PEANUT - ÄRTNÖT - SKVALLRAR OM DESS VÄXTFAMILJ.
KULTBOKEN "LIFTARENS GUIDE TILL GALAXEN" AV DOUGLAS ADAMS KOM FÖRST SOM RADIOFÖLJETONG OCH DÄREFTER I BOKFORM.
UPP TILL 10 TON VATTEN KAN AVDUNSTA FRÅN BLADEN PÅ ETT STORT TRÄD EN VARM DAG.
OM DU INTE TYCKER OM ATT VARA I NÄRHETEN AV TRÄD ELLER RENT AV ÄR SKRÄCKSLAGEN AV DEM LIDER DU AV DENDROFOBI.
ETT SPÄDBARNS SKRIK KAN KOMMA UPP I OMKRING 90 DECIBEL. JÄMFÖRELSEVIS LIGGER ETT VANLIGT SAMTAL PÅ 60 DECIBEL OCH EN BILTUTA PÅ 110 DECIBEL.
"SPHENO PALATINE GANGLIONEURALGIA" ÄR DEN MEDICINSKA TERMEN FÖR DEN HUVUDVÄRK SOM UNGEFÄR EN TREDJEDEL AV VÄRLDENS BEFOLKNING KAN FÅ NÄR DE ÄTER GLASS.
DEN VITA VALEN I HERMAN MELVILLES ROMAN MOBY DICK VAR EN KASKELOT.
I EN SÄNG KAN DET FINNAS UPP TILL TVÅ MILJONER KVALSTER.
I SIN ROLL SOM MASSMÖRDAREN GARLAND GREENE I FILMEN "CON AIR" FRÅGADE STEVE BUSCEMI REGISSÖREN SIMON WEST IFALL HAN SKULLE HAR NÅGON SPECIELL SMINKNING ELLER PERUK FÖR ATT SE HEMSKARE UT. REGISSÖREN SVARADE ATT STEVE INTE BEHÖVDE GÖRA NÅGOT MED SITT UTSEENDE, DET RÄCKTE ATT HAN VAR SIG SJÄLV.
I SVERIGE FINNS DET BARA EN ENDA FISK SOM ÄR GIFTIG OCH DET ÄR FJÄRSINGEN. DEN ÄR UNGEFÄR LIKA GIFTIG SOM EN GETING.
1994 SLÄPADES 36021 FELPARKERADE BILAR BORT FRÅN NEW YORKS GATOR.
I FILMEN "FORREST GUMP" FÅR MAN OFTA SE OLIKA FOTON FRÅN FORRESTS LIV OCH TOM HANKS, SOM SPELADE FORREST, BLUNDAR PÅ VARTENDA AV DEM.
EN BLIXT ÄR INTE SÅ BRED, I REGEL BARA MELLAN 2 OCH 4 CENTIMETER MEN KAN VARA UPP TILL 15 CENTIMETER STORA.
DOCK ÄR LÄNGDEN DESTO MER IMPONERANDE - VANLIGTVIS MELLAN 300 METER OCH 3 KILOMETER.
PASTA BETYDER DEG PÅ ITALIENSKA.
ETT FINARE ORD FÖR SKRIVKRAMP ÄR MOGIGRAFI.
PRODUCENTERNA FÖR FILMEN "SEVEN" HADE TÄNKT ATT TA MED KEVIN SPACEYS NAMN I BÖRJAN AV FILMEN, BLAND DE ANDRA SKÅDESPELARNAS NAMN, MEN SPACEY VILLE INTE DET. HAN VILLE HELLRE ÖVERRASKA PUBLIKEN I SIN ROLL SOM MÖRDARE. DET BLEV SOM SPACEY VILLE OCH SOM KOMPENSATION FÖR HANS UTELÄMNADE NAMN I INLEDNINGEN STÅR HAN FÖRST I ROLLISTAN I SLUTET AV FILMEN.
RUNT 100 MÄNNISKOR KVÄVS ÅRLIGEN AV KULSPETSPENNOR.
AMERIKANSKA TANDLÄKARE HAR REKOMMENDERAT ATT ENS TANDBORSTE SKA FÖRVARAS MINST 2 METER FRÅN TOALETTSTOLEN FÖR ATT INTE LUFTBURNA SMÅPARTIKLAR FRÅN SPOLNINGEN SKA HAMNA PÅ BORSTEN.
FÖRKORTNING PÅ VÅRA VIDEOAPPARATER HEMMA - VHS - STÅR FÖR VIDEO HOME SYSTEM.
VÄRLDENS KORTASTE FILMRECENSION ÄR LEONARD MALTINS RECENSION AV FILMEN "ISN'T IT ROMANTIC" FRÅN 1948, RECENSIONEN LYDER: "NO."
ETT ANNAT OCH LITE KRÅNGLIGARE ORD FÖR SKELNING ÄR STRABISM.
I DEN DATAANIMERADE FILMEN "TOY STORY 2" KAN MAN SE EN ALMANACKA MED MOTIV FRÅN EN ANNAN DATAANIMERAD FILM, "ETT SMÅKRYPS LIV". BÅDA FILMERNA HAR GJORTS AV FILMFÖRETAGET PIXAR.
I DEN GREKISKA MYTOLOGIN HETER KÄRLEKENS GUD EROS OCH I DEN ROMERSKA GÅR HAN UNDER NAMNET AMOR.
SILL SOM LEVER I ÖSTERSJÖN NORR OM ÖLAND KALLAS STRÖMMING. DEN ÄR LITE MINDRE ÄN DEN VANLIGA SILLEN.
NÄR MONTY PYTHONS FILM ETT HERRANS LIV - LIFE OF BRIAN - SKULLE UPP PÅ BIOGRAFERNA 1979 SÅ BLEV DEN TOTALFÖRBJUDEN I NORGE OCH SLÄPPTES FÖRST ETT ÅR SENARE.
ENLIGT SÄGNEN DRACK DEN AZTEKISKE HÄRSKAREN MONTEZUMA 50 KOPPAR CHOKLAD OM DAGEN I KOPPAR AV GULD.
LOS ANGELES HELA NAMN ÄR "EL PUEBLO DE NUESTRA SENORA LA REINA DE LOS ANGELES DE PORCIUNCULA".
TUNGT VATTEN ÄR FAKTISKT TYNGRE ÄN VANLIGT VATTEN, CIRKA 10 PROCENT TYNGRE.
DANNY DEVITO FICK ROLLEN SOM MARTINI I FILMEN "GÖKBOET" EFTERSOM HAN HADE SPELAT ROLLEN I EN TEATERUPPSÄTTNING PÅ BROADWAY NÅGRA ÅR TIDIGARE.
ÅR 1984 KÖPTE DEN BELGISKE ÄVENTYRAREN BRUNO LEUNEN VÄRLDENS LÄNGSTA BILJETT TILL EN JORDENRUNTRESA MED 80 FLYGBOLAG OCH 109 MELLANLANDNINGAR.NÄR BILJETTEN SKREVS UT VAR DEN INTE MINDRE ÄN TOLV METER LÅNG.
CIGARETTÄNDAREN UPPFANNS FÖRE TÄNDSTICKORNA.
ALLA ISBJÖRNAR ÄR VÄNSTERHÄNTA.
KVINNOR BLINKAR NÄSTAN DUBBELT SÅ MYCKET SOM MÄN.
MAN KAN LEDA EN KO UPPFÖR EN TRAPPA, MEN INTE NEDFÖR.
ENDAST EN PERSON PÅ TVÅ MILJARDER KOMMER BLI 116 ÅR ELLER ÄLDRE.
ELEFANTER ÄR DET ENDA DJUR SOM INTE KAN HOPPA.
MÄNNISKANS RYGGMÄRG ÄR CIRKA 45 CENTIMETER LÅNG OCH VÄGER INTE MER ÄN 30 GRAM.
ÄKTA PÄRLOR SMÄLTER OM MAN LÄGGER DEM I VINÄGER.
FJÄRILAR KÄNNER SMAK GENOM FÖTTERNA.
PÅ LATIN HETER SÄLDJUREN PINNIPEDIA SOM BETYDER FENFOTADE.
KALKONER KAN DRUNKNA GENOM ATT DE STÅR OCH STIRRAR UPP I HIMLEN MED ÖPPEN MUN DÅ DET REGNAR.
VÄRLDENS LÄNGSTA TIDSENHET ÄR HINDUERNAS KALPA. DEN ÄR LIKA MED 4,32 MILJARDER ÅR. DETTA ÄR DEN TID DET TAR ATT NÖTA NER HIMALAYA GENOM ATT GNIDA PÅ DEN ENORMA BERGSKEDJAN MED EN SILKESTRÅD.
I VARTENDA AVSNITT AV TV-SERIEN SEINFELD KAN MAN SE NÅGOT MED STÅLMANNEN PÅ.
VARLDENS ALDSTA LEVANDE ORGANISM LEVER PÅ ÖN TASMANIEN. DET ÄR ETT ÖVER 10 000 ÅR GAMMALT BARRTRÄD, VILKET INNEBÄR ATT DET LEVT MÄNNISKANS HELA KULTURELLA UTVECKLING. TRÄDET TÄCKER EN YTA STOR SOM ETT HELT KVARTER.
I FILMEN GULDFEBER ÄTER CHARLIE CHAPLIN UPP SINA SKOR I BRIST PÅ MAT. SKORNA I FILMEN ÄR GJORDA AV LAKRITS.
I KINA HAR MAN SATT SOM MÅL ATT VARJE KINES SKA KUNNA FÅ ÄTA 200 ÄGG OM ÅRET. FÖR ATT FÅ FRAM ÄGG TILL 1,3 MILJARDER MÄNNISKOR MÅSTE MAN HA 1,3 MILJARDER HÖNS - SOM KOMMER ATT ÄTA MER SÄD ÄN VAD SOM PRODUCERAS VARJE ÅR I AUSTRALIEN.
PÅ FLERA OLIKA STÄLLEN I TROPIKERNA FINNS DET FISKAR SOM KAN KLÄTTRA I TRÄD. KLÄTTERABBORREN TILL EXEMPEL KAN IBLAND KLÄTTRA UPP TILL 10 M HÖJD. MÅNGA AV DESSA FISKAR ÄR SÅ VÄL ANPASSADE TILL ATT ANDAS LUFT, ATT DE SKULLE DRUNKNA OM DE TVINGADES UPPEHÅLLA SIG UNDER VATTNET ALLTFÖR LÄNGE.
I ARIZONA, USA, ÄR DET FÖRBJUDET ATT SLICKA PÅ EN VISS PADDA, BUFO ALVARIUS. PADDANS HUD UTSÖNDRAR ETT SEKRET SOM SKA SKRÄMMA BORT ROVDJUR, OCH SEKRETET VERKAR SOM ETT HALLUCINOGENT NARKOTIKUM. EN DEL AV MISSBRUKARNA SLICKAR AV DET FRÅN PADDORNA, ANDRA SKRAPAR AV DET OCH RÖKER DET.
KÄLLVATTEN PÅ BURK ELLER FLASKA KOSTAR CA 1000 GÅNGER MER ÄN VANLIGT DRICKSVATTEN UR KRANEN.
ÄVEN OM EN KACKERLACKA MISTER HUVUDET KAN DEN LEVA I FLERA VECKOR - TILLS DEN DÖR AV SVÄLT.
DET ÄR SÄLLAN EN KORTLEK BLANDAS ORDENTLIGT. OM MAN BARA BLANDAR LEKEN 3-4 GÅNGER KOMMER MÅNGA KORT FORTFARANDE ATT LIGGA I SAMMA ORDNING. MAN MÅSTE BLANDA MINST SJU GÅNGER, SÄGER MATEMATIKERNA.
TANDPETARE ÄR DET FÖREMÅL AMERIKANER OFTAST SÄTTER I HALSEN.
ALLA KLOCKOR I QUENTIN TARANTINOS FILM PULP FICTION STÅR PÅ TJUGO ÖVER FYRA. DET KAN MYCKET VÄL VARA EN REFERENS TILL ALBERT HOFMANN, UPPTÄCKAREN AV LSD, SOM TOG VÄRLDENS FÖRSTA LSD-TRIPP KLOCKAN 16.20 DEN 19:E APRIL 1943.
MÄNNISKAN HAR I GENOMSNITT 100 000 HÅRSTRÅN PÅ HUVUDET OCH TAPPAR MELLAN FEMTIO OCH HUNDRA STRÅN VARJE DAG.
BLONDA HAR CIRKA 140 000, RÖDHÅRIGA UNGEFÄR 90 000 STRÅN OCH BRUNHÅRIGA NÅGOT MITT EMELLAN.
DET FINNS EN INTERNATIONELL FÖRENING VARS SYFTE ÄR ATT UPPLYSA VÄRLDEN OM ATT ALLA VETENSKAPLIGA FAKTA ÄR OSANNA. BLAND ANNAT SÅ PÅSTÅR MEDLEMMARNA ATT JORDEN ÄR PLATT OCH ATT AVSTÅNDET TILL SOLEN ÄR 5184 KM - OCH INTE 149 MILJONER KM.
BRITTISKA DROTTNINGEN ELIZABETH I VAR OTROLIGT FRIKOSTIG MED SITT SMINK. NÄR HON DOG HADE HON EN HALV CENTIMETER TJOCKT LAGER LÄPPSTIFT PÅ SIG.
NÄR HUNDAR HAR GJORT TOALETT SÅ SPRÄTTER DE SOM ALLA VET MED TASSARNA OCH RIVER UPP GRÄS ELLER GRUS ELLER PLASTMATTA. TVÄRTEMOT VAD MAN KAN TRO SÅ GÖR DE INTE DETTA FÖR ATT TÄCKA ÖVER SITT AVSKRÄDE, UTAN FÖR ATT SÄTTA DOFTSPÅR DÄR FRÅN SINA DOFTKÖRTLAR DE HAR PÅ TASSARNA.
FLYGER MAN INRIKESFLYG I USA MÅSTE MAN STATISTISKT SETT FLYGA VARJE DAG 119 000 ÅR INNAN MAN RÅKAR UT FÖR EN OLYCKA.
MAN PÅFRESTAR STÄMBANDEN MER NÄR MAN VISKAR ÄN NÄR MAN PRATAR VANLIGT.
TRANSSIBIRISKA JÄRNVÄGEN ÄR EN 930 MIL LÅNG JÄRNVÄGSRUTT GENOM RYSSLAND, FRÅN MOSKVA TILL VLADIVOSTOK. FRÅN BÖRJAN FICK MAN HALVVÄGS IN I RESAN ÅKA TÅGFÄRJA ÖVER BAJKALSJÖN MEN SEDAN BYGGDES EN LINJE FÖRBI SJÖN I STÄLLET. EN ENKEL RESA PÅ TRANSSIBIRISKA JÄRNVÄGEN TAR STRAX ÖVER SJU DYGN.
FÖRSTA GÅNGEN SOM EN LASER AVBILDAS PÅ FILM ÄR I BONDFILMEN "GOLDFINGER".
1969 VAR DET ÅR DEN AMERIKANSKA RYMDFARKOSTEN APOLLO 11 FÖRDE DEN FÖRSTA MÄNNISKAN TILL MÅNEN. STYRSYSTEMET I RYMDFARKOSTEN VAR INTE LIKA AVANCERAT SOM DE DATORER SOM IDAG FINNS I VANLIGA MINIRÄKNARE.
DAVID PROWSE, KILLEN SOM SPELADE DARTH VADER I FILMEN STJÄRNORNAS KRIG, HADE INGEN ANING OM ATT SKÅDESPELAREN JAMES EARL JONES SKULLE GE SIN RÖST TILL DARTH. DETTA MÄRKTE HAN FÖRST DÅ HAN SATT I BIOSALONGEN OCH SÅG FILMEN.
INOMHUSARENAN GLOBEN I STOCKHOLM BYGGDES 1986-88 OCH ÄR VÄRLDENS STÖRSTA SFÄRISKA BYGGNAD.
EN NYUPPTÄCKT MYRART I CENTRALAMERIKA HAR FÅTT SITT NAMN EFTER SKÅDESPELAREN HARRISON FORD. PEIDOLE HARRISONFORDI HETER ARTEN.
OM MAN INTE HÅLLER FÖR MUNNEN KAN MAN I EN ENDA NYSNING NYSA UT 20 000 SMÅ DROPPAR SOM KAN FARA IVÄG UPP TILL FYRA METER.
SVERIGE ÄR ETT AVLÅNGT LAND. AVSTÅNDET MELLAN TRERIKSRÖSET LÄNGST UPP I NORR OCH TRELLEBORG LÄNGST NERE I SÖDRA SKÅNE ÄR UNGEFÄR DET SAMMA SOM MELLAN TRELLEBORG OCH NEAPEL I ITALIEN.
KÄRNOR I KLEMENTINER HITTAR DU ALDRIG. DOCK HITTAR DU MED STÖRSTA SÄKERHET KÄRNOR I MANDARINER, SOM ÄR DEN URSPRUNGLIGA FRUKTEN. DEN KÄRNFRIA VARIANTEN ODLADES FRAM AV DEN FRANSKE PRÄSTEN CLEMENT RUNT ÅR 1900 OCH FICK DÄRFÖR SITT NAMN EFTER HONOM.
LÅR- OCH SKENBEN KAN UTSÄTTAS FÖR EN LODRÄT BELASTNING PÅ UPP TILL 1 TON UTAN ATT KNÄCKAS, DET VILL SÄGA DEN UNGEFÄRLIGA VIKTEN AV EN PERSONBIL.
UNDER EN HELT LIV PÅ 70 ÅR TAR MAN CIRKA 600 MIUONER ANDETAG. HJÄRTAT SLÅR CIRKA 125 MILJONER SLAG, OCH ÖGONEN BLINKAR OMKRING 350 MILJONER GÅNGER.
DEN DAGLIGA PRODUKTIONEN AV GASER I MÄNNISKANS TJOCKTARM ÄR 7-10 LITER. HÄRAV AVGES CIRKA 0,5 LITER MEDAN TARMVÄGGEN ABSORBERAR RESTEN.
GUINNESS REKORDBOK HAR UTSETT REPLIKEN "MITT NAMN ÄR BOND, JAMES BOND" TILL VÄRLDENS MEST KÄNDA FILMREPLIK.
UNDER ANDRA VÄRLDSKRIGET AVSLÖJADE TYSKARNA ÅTSKILLIGA AMERIKANSKA SPIONER GENOM ATT STUDERA HUR DE ÅT. AMERIKANER HAR NÄMLIGEN FÖR VANA ATT SKÄRA HELA BIFFEN I SMÅBITAR INNAN DE BÖRJAR ÄTA DEN.
DEN STÖRSTA NJURSTEN SOM NÄMNS I MEDICINENS HISTORIA VÄGDE 6,3 KG.
VÄRLDENS MINSTA FÅGEL, DEN KNAPPT 6 CENTIMETER STORA BIKOLIBRIN, MOTVERKAR TYNGDKRAFTEN GENOM ATT SLÅ MED VINGARNA UPP TILL 200 SLAG I SEKUNDEN.
STORBRITANNIEN DEPORTERADE 155000 FÅNGAR TILL SIN KOLONI AUSTRALIEN MELLAN 1788 OCH 1868.
OM JORDEN HADE VARIT HELT JÄMN OCH SLÄT SOM EN BILJARDBOLL SÅ HADE DEN VARIT TÄCKT AV ETT VATTENLAGER MED 250 METERS DJUP.
I BONDFILMEN "AGENT 007 SER RÖTT" FINNS FÖRFATTAREN IAN FLEMING MED I EN AV SCENERNA SOM STATIST.
DEN FÖRSTA DEPORTERINGEN TILL SIBIRIEN I RYSSLAND VAR INTE EN MÄNNISKA UTAN EN SYMBOL - DEN KVARTS TON TUNGA STADSKLOCKAN I UGLICH. 1581 MÖRDADES TSARSONEN DIMITRIJ OCH UPPVIGLARNA LÄT STADSKLOCKAN RINGA OCH SOM STRAFF FICK DE SPÖ OCH DERAS TUNGOR SKARS BORT. SOM EN MAKTUPPVISNING SPÖADES ÄVEN KLOCKAN, KLÄPPEN SLETS LOSS FRÅN SITT FÄSTE OCH SLUTLIGEN DEPORTERADES KLOCKAN TILL ETT ÖDE I EVIG TYSNAD I SIBIRIEN.
BÅTMOTORER SOM KÖRS PÅ TOMGÅNG HAR AKUSTISKA EGENSKAPER SOM PÅMINNER MYCKET OM GRÅVALENS SÅNG. I MEXICO HAR YRKESFISKARNA PROBLEM MED VALAR SOM VILL GNIDA RYGGEN MOT FISKEBÅTARNA.
OM MAN VASSAR EN BLYERTSPENNA RIKTIGT BRA, OCH DOPPAR DEN YTTERSTA SPETSEN I NIKOTIN OCH SEDAN TRYCKER IN DENNA MINIMALA MÄNGD GENOM HUDEN PÅ EN MÄNNISKA DÖR DEN PERSONEN DIREKT.
GUMMIBAND HÅLLER LÄNGRE OM DE FÖRVARAS KALLT.
STRAX INNAN MAN FRYSER IHJÄL BRYTER TEMPERATURSINNET I KROPPEN HELT OCH HÅLLET SAMMAN, SÅ ATT DET KÄNNS SOM OM MAN HÅLLER PÅ ATT STEKAS. DETTA ÄR FÖRKLARINGEN TILL ATT MÄNNISKOR SOM PÅTRÄFFATS IHJÄLFRUSNA IBLAND ÄR HELT AVKLÄDDA.
MARILYN MONROE HADE SEX TÅR PÅ ENA FOTEN.
EN DEL BLÄCKFISKAR LEVER PÅ SÅ DJUPT VATTEN, ATT DET ÄR HELT MÖRKT. DÅ HJÄLPER DET JU INTE ATT FÖRVIRRA FIENDEN MED EN SKVÄTT BLÄCK. I STÄLLET SÄNDER BLÄCKFISKARNA UT ETT MOLN AV SJÄLVLYSANDE BAKTERIER SOM BLÄNDAR FIENDEN.
DEN VITA HALVMÅNEN PÅ DINA FINGRAR ÄR EN LITEN, LITEN LUFTFICKA. INGEN VET VARFÖR DEN FINNS DÄR.
OM MAN KUNDE TA ALL DEN BRÖDSÄD SOM KONSUMERAS I VÄRLDEN UNDER ETT ÅR OCH BAKA ETT BRÖD AV DEN, SÅ SKULLE DETTA BRÖD BLI CIRKA 4 M BRETT, 2 M HÖGT OCH GÅ ETT VARV RUNT JORDEN.
SERIEN KALLE ANKA VAR EN GÅNG I TIDEN FÖRBJUDEN I FINLAND PÅ GRUND AV ATT HAN INTE HAR NÅGRA BYXOR.
LEGO UTVECKLAS 1949 OCH NAMNET KOMMER AV DE INLEDANDE BOKSTÄVERNA I DANSKANS LEG 'LEK' OCH GODT 'BRA'.
TVÅ TREDJEDELAR AV VÄRLDENS ÄGGPLANTEPRODUKTION SKER I NEW JERSEY I AMERIKA.
FILOSOFEN RENE DESCARTES, SOM ANSER SIG HA UPPTÄCKT FILOSOFINS FÖRSTA PRINCIP, SATSEN COGITO ERGO SUM (JAG TÄNKER, ALLTSÅ EXISTERAR JAG), DOG NÄR HAN VAR PÅ BESÖK HOS DROTTNING KRISTINA 1649. SLOTTET VAR KALLT OCH DESCARTES ÅDROG SIG LUNGINFLAMMATION SOM BLEV HANS BANEMAN.
DET FINNS FLER KYCKLINGAR ÄN VAD DET FINNS MÄNNISKOR PÅ VÅR PLANET.
SPANSKA FLUGAN ÄR EN SKALBAGGE SOM BLIVIT MER KÄND ÄN ANDRA SKALBAGGAR PÅ GRUND AV DESS PÅSTÅDDA VERKAN SOM AFRODISIAKUM. VAD SOM ÄR BEVISAT ÄR DOCK ATT TORKAD OCH PULVERISERAD SPANSK FLUGA FUNGERAR UTMÄRKT SOM GIFT OCH ÅTSKILLIGA HAR DUKAT UNDER FÖR DESS VERKAN. DÖDSFALL AV SPANSK FLUGA RAPPORTERADES SÅ SENT SOM PÅ 1960-TALET.
PÅ AL CAPONES VISITKORT STOD DET ATT HAN SÅLDE BEGAGNADE MÖBLER.
EN GULDFISK KOMMER BARA IHÅG DE TRE SENASTE SEKUNDERNA I SITT LIV.
OM MAN SER TILL STATISTIKEN SÅ HAFFAS DET FLER SNATTARE PÅ ONSDAGAR ÄN NÅGON ANNAN AV VECKANS DAGAR.
VI FÖDS UTAN KNÄSKÅLAR. DE ÄR FÖRST UTVECKLADE VID SEX ÅRS ÅLDER.
WILLIAM SHAKESPEARE "UPPFANN" MER ÄN 1700 ORD.
DET VÄRLDSBERÖMDA OPERAHUSET I SYDNEY RITADES AV JORN UTZON FRÅN DANMARK OCH ÄR BEKLÄTT MED ÖVER EN MILJON VITA KERAMIKPLATTOR SOM TILLVERKADES AV DET SVENSKA FÖRETAGET HÖGANÄS.
NORGE ÄR VÄSTVÄRLDENS STÖRSTA EXPORTÖR AV KAMELER.
VÅRA ÖGON HAR SAMMA STORLEK FRÅN VÅR FÖDELSE TILLS DEN DAG VI DÖR, MEN VÅRA ÖRON OCH NÄSOR SLUTAR ALDRIG VÄXA.
TAMKATTEN KOM TILL NORDEN FÖR UNGEFÄR 1500 ÅR SEDAN. INNAN DESS HADE MAN GÄRNA, TRO DET ELLER EJ, EN HUSORM.
ANTALET MÄNNISKOR SOM DÖDAS AV ÅSNOR VARJE ÅR ÄR FLER ÄN DET ANTAL MÄNNISKOR SOM DÖR I FLYGKRASCHER.
DET BEHÖVS 150 000 SAFFRANSKROKUSAR FÖR ATT FA IHOP TILL ETT KILO SAFFRAN.
AV ALLA DJUR SÅ ÄR DET KASKELOTVALEN SOM HAR DEN ALLRA STÖRSTA HJÄRNAN. NIO KILO VÄGER DEN.
GRODOR DRICKER ALDRIG VATTEN. DE FÅR I SIG DEN VÄTSKA DE BEHÖVER GENOM ATT DE LEVER DÄR DET ÄR VÅTT OCH FUKTIGT.
DEN STÖRSTA KONCENTRATION DJUR MAN NÅGONSIN IAKTTAGIT VAR EN OFATTBART STOR SVÄRM GRÄSHOPPOR. ÅRET VAR 1875, OCH MAN ANSER ATT SVÄRMEN TÄCKTE EN YTA MOTSVARANDE TYSKLANDS. SVÄRMEN INNEHÖLL MINST 12.500 MILJARDER INSEKTER, OCH TILLSAMMANS VÄGDE DE UPPSKATTNINGSVIS OMKRING 25 MILJARDER TON.
I FÖRHÅLLANDE TILL SIN STORLEK ÄR SKALBAGGAR TILLHÖRANDE SLÄKTET SCARABAEIDAE VÄRLDENS STARKASTE DJUR. VID FÖRSÖK MED DEN GANSKA SÄLLSYNTA NOSHÖRNSBAGGEN FANN MAN, ATT DEN KUNDE BÄRA 850 GÅNGER SIN EGEN VIKT PÅ RYGGEN.
EN MÄRKLIG MODEFÄRG SKAPADES AV FURSTINNAN ISABELLA, DOTTER TILL FILIP II AV SPANIEN. ÅR 1601 SVOR HON ATT HON INTE SKULLE BYTA UNDERKLÄDER FÖRRÄN STADEN OOSTENDE VAR INTAGEN. OLYCKLIGTVIS VARADE BELÄGRINGEN I TRE ÅR SÅ DROTTNINGENS UNDER-KLÄDER FICK DEN BEIGEGULA FÄRG SOM IDAG GÅR UNDER NAMNET ISABELLAFÄRGAT.
TÄNDERNAS EMALJ ÄR DET HÅRDASTE MATERIALET SOM DEN MÄNSKLIGA KROPPEN KAN PRODUCERA.
DÅ CHARLIE CHAPLIN HADE BLIVIT KÄND FÖR SINA FILMER VAR DET MASSOR AV MÄNNISKOR SOM KLÄDDE UT SIG OCH UPPTRÄDDE SOM HAN. DET ORDNADES TILL OCH MED CHARLIE CHAPLIN-LOOK-ALIKETÄVLINGAR. CHAPLIN VAR SJÄLV MED I EN - OCH BLEV TREA!
SJÖSTJÄRNOR HAR INTE SÅ BRA BORDSSKICK. DE VÄNDER IN OCH UT PÅ MAGEN OCH PRESSAR UT DEN GENOM MUNNEN ÖVER BYTET.
DEN "SVARTA LÅDAN" SOM ALLA LETAR EFTER DÅ ETT FLYGPLAN HAR KRASCHAT ÄR INTE SVART - DEN ÄR ORANGE. HELT ENKELT FÖR ATT DEN ÄR LÄTTARE ATT HITTA DÅ. DESSUTOM FINNS DET INTE BARA EN LÅDA UTAN TVÅ, DEN ENA LÅDAN SPELAR IN ALLA SAMTAL OCH LJUD FRÅN COCKPITEN OCH DEN ANDRA LÅDAN SPARAR ALLA FLYGDATA.
NÄR EN MÄNNISKA TAR SIG EN LUR PÅ EN TIMME FÖRBRÄNNER HON LIKA MYCKET ENERGI SOM DET BEHÖVS FÖR ATT KOKA VATTEN TILL CIRKA 7 KOPPAR TE.
VÄRLDSHISTORIENS KORTASTE KRIG UTKÄMPADES DEN 27 AUGUSTI 1896 MELLAN STORBRITANNIEN OCH ZANZIBAR. DET VARADE I 38 MINUTER.
OM MAN MULTIPLICERAR ANTALET INVÅNARE I USA MED SIFFRAN TVÅ FÅR MAN FRAM ANTALET KREDITKORT SOM FINNS I SAMMA LAND.
OM EN MÄNNISKAS HJÄRTA HADE SATTS ATT FYLLA ÖLFLASKOR PÅ ETT BRYGGERI, SÅ SKULLE DET DAGLIGEN KUNNA FYLLA 1600 BACKAR MED 30 FLASKOR I VARJE, OCH DET SKULLE KUNNA FUNGERA 170 ÅR UTAN ÖVERSYN ELLER REPARATIONER.
ADOLF HITLER HADE BARA EN TESTIKEL.
ETT FEM MÅNADER GAMMALT FOSTER HAR MERA HÅR PÅ RYGGEN ÄN EN VUXEN GORILLA.
OM EN FÅNGE FÖRR I TIDEN FLYDDE FRÅN FÄNGELSET I ALAMOS I MEXICO DÖMDE MAN DE VAKTER SOM HADE ANSVARET FÖR HONOM ATT SJÄLVA SITTA AV DEN RESTERANDE TIDEN.
JAKTPILOTER FÅR OFTARE DÖTTRAR ÄN SÖNER DÄRFÖR ATT X-KROMOSONERNA (SOM GER FLICKOR) I SPERMIERNA BÄTTRE TÅL DEN HÅRDA PÅVERKAN AV GRAVITATIONEN ÄN YKROMOSONERNA (SOM GER POJKAR).
MÄNNISKAN HAR I GENOMSNITT ARTON SKÖNHETSFLÄCKAR PÅ KROPPEN.
LAMMGAMEN HAR EN MAGSYRA SOM ÄR SÅ STARK ATT DEN BARA BEHÖVER NÅGRA TIMMAR PÅ SIG FÖR ATT LÖSA UPP EN SPIK.
FÖR VARJE MÄNNISKA PÅ JORDEN TROR MAN ATT DET FINNS ÖVER EN HALV MILJON INSEKTER. ETT ENDA TRÄD KAN EXEMPELVIS INHYSA 20 MILJONER BLADLÖSS.
SÄDESCELLERNA BILDAS I TESTIKLARNA SOM ÄR UPPBYGGDA SÅ ATT DE BILDAR RÖRFORMIGA STRUKTURER. I VARJE TESTIKEL HAR DESSA RÖR EN SAMMANLAGD LÄNGD PÅ 400 M.
EN ENDA TRÅD I EN SPINDELS NÄT ÄR LIKA STARK SOM EN STÅLVAJER MED SAMMA TJOCKLEK.
FÖRDELNINGEN MELLAN BLODGRUPPERNA VARIERAR FRÅN FOLKSLAG TILL FOLKSLAG.
DE AMERIKANSKA INDIANERNA ÄR DE ENDA SOM BARA HAR EN BLODGRUPP - 0.
I INDIEN, DÄR HINDUISMEN ÄR DEN STÖRSTA RELIGIONEN, RÄKNAR MAN ATT MAN TILLBER ÖVER 300 MILJONER GUDAR. NÄSTAN VARENDA BY HAR TILL EXEMPEL SIN EGEN LOKALA GUD.
CIRKA 1000 DUN KAN PRESSAS NER I EN FINGERBORG OCH SEDAN ÅTERFÅ SIN URSPRUNGLIGA VOLYM.
VARJE SEKUND BILDAR EN MÄNNISKAS BENMÄRG CIRKA 3 MILJONER NYA RÖDA BLODKROPPAR. LIKA MÅNGA DÖR. DEN DAGLIGA PRODUKTIONEN ÄR ÖVER 200 MILJARDER RÖDA BLODKROPPAR.
DET FÖDS NORMALT 94 FLICKOR PÅ 100 POJKAR, MEN BLAND FYRLINGAR FÖDS DET 156 FLICKOR PÅ 100 POJKAR.
LÅNGA MÄNNISKOR ÄR MER KVICKTÄNKTA. MAN HAR NÄMLIGEN KUNNAT VISA ATT LÅNGA MÄNNISKOR LYCKAS BÄST VID INTELLIGENSTESTER.
DE FÖRSTA NÄSTRANSPLANTATIONERNA UTFÖRDES I INDIEN REDAN CIRKA 750 F KR. NÄSORNA TOGS FRÅN OTROGNA HUSTRUR.
MAGSYRAN HOS EN MÄNNISKA ÄR SA STARK ATT DEN MÅSTE SPÄDAS UT CIRKA 400 GÅNGER FÖR ATT FÅ SAMMA SURHETSGRAD (PH-VÄRDE) SOM COCACOLA.
AV ALLA GRUNDÄMNEN I VÄRLDEN ÄR RADIUM 224 DEN GIFTIGASTE. DENNA NATURLIGT FÖREKOMMANDE ISOTOP ÄR 17 000 GÅNGER GIFTIGARE ÄN PLUTONIUM 239.
NÄR IAN FLEMING SKREV SIN FÖRSTA BOK CASINO ROYALE SÅ FICK HAN NAMNET PÅ SIN HJÄLTE JAMES BOND FRÅN EN FÖRFATTARE TILL EN BOK OM KARIBISKA FÅGLAR.
MEL BLANC, MANNEN SOM HAR GETT SIN RÖST ÅT BUGS BUNNY, VAR ALLERGISK MOT MORÖTTER.
SKOTTSÄKRA VÄSTAR, BRANDSTEGAR, VINDRUTETORKARE OCH LASERSKRI-VARE UPPFANNS AV KVINNOR.
DE TRE VISE MÄNNEN HETTE CASPAR, MELCHIOR OCH BALTHAZAR.
TJUVAR LYSSNAR VID DÖRRAR OCH DET HAR I NÅGRA FALL FÄLLT DEM. POLISEN INTRESSERAR SIG NÄMLIGEN INTE BARA FÖR FINGERAVTRYCK, UTAN OCKSÅ FÖR AVTRYCK AV ÖRON - VILKET SOM BEKANT ÄR OLIKA FRÅN MÄNNISKA TILL MÄNNISKA.
NYA DJURARTER KAN PÅTRÄFFAS PÅ DE MÄRKLIGASTE STÄLLEN. EN NY MYRART HITTADE MAN I EN KRUKVÄXT PÅ SEXTONDE VÅNINGEN I EN TYSK KONTORSBYGGNAD.
OM MAN STÄLLER SIG RIKTIGT RIKTIGT TÄTT TILLSAMMANS PA EN FOTBOLLSPLAN KAN MAN FÅ PLATS MED 51 000 MÄNNISKOR.
OM DU ÄR REJÄLT RÄDD FÖR DJUR I ALLMÄNHET, ALLTSÅ INTE NÅGON SPECIELL ART, SÅ LIDER DU AV ZOOFOBI.
I INDIEN TALAR MAN ÖVER 140 HUVUDSPRÅK OCH 845 DIALEKTER.
GODAHOPPSUDDEN ÄR INTE AFRIKAS SYDLIGASTE UDDE UTAN DET ÄR FAKTISKT KAP AGULHAS SOM LIGGER CIRKA 150 KILOMETER SYDÖST OM GODAHOPPSUDDEN.
I MEDELTAL FÅR VARJE PERSON ÅRLIGEN I SIG 12 ST PUBISHÅR NÄR DE ÄTER PÅ RESTAURANG.
EUROPEISKA UNIONENS NATIONALSÅNG ÄR AN DER FREUDE UR LUDVIG VON BEETHOVENS NIONDE SYMFONI.
WILLIAM BOOTH, MANNEN SOM SKÖT USA:S 16:E PRESIDENT ABRAHAM LINCOLN, VAR SKÅDESPELARE.
JORDNÖTTER ÄR EN UTAV BESTÅNDSDELARNA I DYNAMIT.
DE FEM OLIKFÄRGADE RINGARNA PÅ OS-FLAGGAN SYMBOLISERAR FÖRENINGEN AV DE FEM KONTINENTERNA OCH ATT OS SKA VARA EN MÖTESPLATS FÖR HELA VÄRLDENS IDROTTARE.
SEAN CONNERY, MANNEN SOM BLEV DEN FÖRSTE JAMES BOND FÖR VÄRLDENS BIOBESÖKARE, HADE VUNNIT TÄVLINGEN MR. UNIVERSUM INNAN HAN BLEV SKÅDESPELARE.
EN KATT HAR TRETTIOTVÅ MUSKLER I VARJE ÖRA.
DET ÄR INTE LOPPOR SOM APORNA SITTER OCH PLOCKAR FRÅN VARANDRAS KROPPAR PÅ ZOO ELLER I VILT TILLSTÅND UTAN SMÅ SALTSMAKANDE HUDFLAGOR.
NÄR DU SITTER OCH SKRIVER PÅ ETT TANGENTBORD GÖR VÄNSTERHANDEN 56% AV JOBBET.
ORDET KALKON BETYDER EGENTLIGEN "TUPP FRÅN CALICUT".
HADE DET INTE VARIT FÖR FÖRSTA VÄRLDSKRIGET HADE NOG BLIXTLÅSET INTE BLIVIT DEN TIDIGA SUCCÉ SOM DEN BLEV. DESS FÖRSTA STORA ANVÄNDNING VAR DOCK INTE PÅ KLÄDER UTAN PÅ ETT PENNINGBÄLTE SOM USA:S SOLDATER TAGIT MED SIG TILL EUROPA.
MÅNGA HAMSTRAR BLINKAR MED ETT ÖGA ÅT GÅNGEN.
PACEMAKERN UPPFANNS PA 1950-TALET AV SVENSKEN RUNE ELMQVIST PÅ FÖRETAGET PACESETTER.
CHANSEN ATT ÖVERLEVA EN FLYGOLYCKA ÄR BÄTTRE PÅ DE BAKRE STOLSRADERNA. DÄR HAR MAN BÄST SKYDD UNDER START OCH LANDNING, DÅ RISKEN FÖR ATT FÖROLYCKAS ÄR STÖRST.
OM BARBIE VARIT EN RIKTIGT MÄNNISKA HADE HENNES MÅTT VARIT 97-58-97.
ATT DET ÄR VARMARE I STÄDER ÄN UTE PÅ LANDET BEROR I HÖG GRAD PÅ ATT DE ASFALTERADE GATORNA OCH VÄGARNA ABSORBERAR MER SOLENERGI ÄN GRÄS, TRÄD OCH ANDRA VÄXTER.
DEN LÄNGSTA LANDSGRÄNSEN MELLAN TVÅ STATER I EUROPA ÄR DEN MELLAN SVERIGE OCH NORGE - 1619 KILOMETER LÅNG.
JOHN RHYS-DAVIES SOM SPELAR DVÄRGEN GIMLI I DE TRE SAGAN OM RINGEN-FILMERNA HADE ETT TUNGT JOBB UNDER HELA INSPELNINGEN. HANS RUSTNING VÄGDE NÄMLIGEN 30 KILO.
FRÅN BÖRJAN HADE ASKUNGEN INTE SKOR AV GLAS UTAN AV SKINN. ATT HON SEDAN SLUTET AV 1600-TALET HAR FÅTT BÄRA GLASSKOR ÄR ATT NÄR FOLKSAGAN NEDTECKNADES SÅ BLANDADES DE FRANSKA ORDEN "VAIR" OCH "VERRE" IHOP, DET FÖRRA BETYDER SKINN, DET SENARE GLAS.
EN ORKAN PRODUCERAR I GENOMSNITT 200 GÅNGER MER ENERGI ÄN VÄRLDENS ALLA KRAFTVERK TILLSAMMANS.
EIFFELTORNET BYGGDES AV GUSTAVE EIFFEL TILL PARISUTSTÄLLNINGEN 1899 OCH VAR TÄNKT ATT MONTERAS NER EFTER UTSTÄLLNINGENS SLUT.
ETT DYGN, ALLTSÅ DEN TID EN PLANET SNURRAR KRING SIG SJÄLV, PÅ PLANETEN JUPITER ÄR BARA 9 TIMMAR OCH 55 MINUTER LÅNGT.
DEN AFRIKANSKA STRUTSEN ÄR INTE BARA VÄRLDENS STÖRSTA FÅGEL, DEN LÄGGER VÄRLDENS STÖRSTA ÄGG OCKSÅ. I GENOMSNITT VÄGER ETT DYLIKT ÄGG 1-1,7 KILO. DET MOTSVARAR UNGEFÄR 45 VANLIGA HÖNSÄGG.
OM MAN INTE TAPPAR HÅRET OCH LEVER TILLS MAN BLIR 77 ÅR KAN ENS HÅR VÄXA SAMMANLAGT 111 MIL UNDER DE ÅREN. DET MOTSVARAR NÄSTAN STRÄCKAN MELLAN MALMÖ OCH UMEÅ.
ORKANER FÅR ALLTID NAMN FÖR ATT DET SKA VARA LÄTTARE ATT HÅLLA REDA PÅ DEM OCH ÅRETS FÖRSTA ORKAN FÅR ALLTID ETT NAMN PÅ A. JÄMNA ÅR BÖRJAR LISTAN MED ETT POJKNAMN OCH OJÄMNA ÅR MED ETT FLICKNAMN. SÅ HAR DET VARIT SEDAN 1979 DA METEOROLOGERNA GAV EFTER FÖR KVINNORÖRELSENS PÅTRYCKNINGAR. INNAN DESS HADE ORKANERNA BARA MANLIGA NAMN.
EN NYFÖDD KÄNGURU VÄGER CIRKA ETT GRAM.
NÄR FILMEN "DIAMANTFEBER" SPELADES IN DRABBADES PRODUKTIONEN EN DAG AV EN KATASTROF. VATTENBÄDDEN MED TROPISKA FISKAR BUBBLADE AV LIV HELA TIDEN, MEN EN DAG SÅ HADE ALLA FISKARNA DÖTT. LÖSNINGEN ATT FÅ DEM ATT SE LEVANDE UT I FILMEN VAR ATT FRYSA NER DEM OCH ANVÄNDA LINOR FÖR ATT FÅ DEM ATT RÖRA SIG.
DET ÄR OMÖJLIGT ATT NYSA MED ÖGONEN ÖPPNA.
GLASSHUVUDVÄRK ORSAKAS DÅ KYLA KOMMER I KONTAKT MED ETT SPINDELVÄVSLIKNANDE NÄT AV NERVER I GOMMEN. NÄR DETTA NERVNÄT KYLS NED TROR HJÄRNAN ATT DEN HÅLLER PÅ ATT FÖRFRYSA OCH SKICKAR BUD OM MASSA VARMT BLOD DIT SOM SKA VÄRMA UPP HJÄRNAN. BLODET FORSAR DIT (I ONÖDAN) OCH KYLER INTE ALLS NER HJÄRNAN UTAN SKAPAR HUVUDVÄRKEN I STÄLLET.
UTOMJORDINGEN ET:S ANSIKTE I FILMEN MED SAMMA NAMN MODELLERADES EFTER POETEN CARL SANDBORG, FYSIKERN ALBERT EINSTEIN OCH EN MOPS (HUNDEN ALLTSÅ).
FLYGPLANET SOM BUDDY HOLLY BEFANNS SIG I NÄR DET KRASCHADE HETTE "AMERICAN PIE% DON MCLEAN TOG DET NAMNET TILL SIN SÅNG SOM HAN SLÄPPTE NÅGRA ÅR SENARE.
SENGÅNGAREN RÖR SIG SÅ SAKTA ATT ALGER FAKTISKT KAN VÄXA OHINDRAT PÅ DJURET, DÄRAV DESS IBLAND GRÖNAKTIGA PÄLS.
DET ÄR INTE BARA TIGERNS PÄLS SOM ÄR STRECKFÄRGAD UTAN ÄVEN DESS SKINN.
UTTRYCKET SCHACK MATT KOMMER FRÅN DET ARABISKA UTTRYCKET SHAH MAT VILKET BETYDER "KONUNGEN ÄR DÖD".
TVÄRTEMOT VAD MÅNGA TROR SÅ ÄR DET VARE SIG URTAVLAN ELLER TORNET I LONDON SOM HETER BIG BEN. DET KÄNDA NAMNET TILLHÖR DEN KLOCKA SOM HÄNGER BAKOM URTAVLAN OCH SLÅR TIMSLAGEN.
NÄR DEN NORDAMERIKANSKA OPOSSUMEN BLIR HOTAD SPELAR DEN INTE BARA DÖD FÖR ATT UNDKOMMA FARAN,DEN SVIMMAR AV REN RÄDSLA.
DOCKORNA BERT OCH ERNIE PÅ TV-PROGRAMMET SESAM FICK SINA NAMN EFTER POLISEN BERT OCH TAXIFÖRAREN ERNIE I FILMEN "LIVET ÄR UNDERBART" MED JAMES STEWART I HUVUDROLLEN.
KAMELER HAR TRE ÖGONLOCK SOM SKYDDAR VARANDRA FRÅN SAND SOM BLÅSER MOT DEM.
EN ÅSNAS ÖGONS PLACERING PÅ DESS HUVUD GÖR DET MÖJLIGT FÖR DJURET ATT SE ALLA SINA FYRA HOVAR HELA TIDEN.
NÄR DU FÖDS HAR DU 300 BEN I DIN KROPP, MEN NÄR DU DÖR HAR DU BARA 206.
DEN ENDA MÅNAD I HISTORIEN SOM INTE HAFT EN FULLMÅNE ÄR FEBRUARI 1865.
ENLIGT FÖRFATTAREN IAN FLEMING VAR JAMES BONDS PAPPA FRÅN SKOTTLAND OCH HANS MAMMA FRANSYSKA.
EN STRUTS ÖGA ÄR STÖRRE ÄN DESS HJÄRNA.
BRÖDROSTEN INTRODUCERADES PÅ MARKNADEN AV GENERAL ELECTRIC I USA 1909.
VOLVO ÄR EGENTLIGEN ETT ORD FRÅN LATINET SOM BETYDER "JAG RULLAR".
TURISTATTRAKTIONEN LUTANDE TORNET I PISA LUTAR MOT SÖDER.
INSKRIFTEN PÅ JESU KORS, I.N.R.I., STÅR FÖR JESUS NAZARENUS, REX IUDAEORUM. DET ÄR LATIN FÖR JESUS FRÅN NASARET, JUDARNAS KONUNG.
UNDER ANDRA VÄRLDSKRIGET UTBILDADE SIG DROTTNING ELIZABETH II TILL BILMEKANIKER.
DUELLERANDE I PARAGUAY ÄR BARA TILLÅTET OM DE BÅDA STRIDANDE ÄR REGISTRERADE BLODGIVARE.
DIAMANTERS VIKT ANGES I KARAT. FRÅN BÖRJAN MOTSVARADE EN KARAT VIKTEN AV EN JOHANNESBRÖDSKÄRNA, MEN 1913 SÅ BESTÄMDES VIKTEN MER EXAKT TILL 0,2 GRAM.
I SVERIGE ÄTS DET MEST TUNNBRÖD I NORR, KNÄCKEBRÖD I MELLANSVERIGE OCH MER LIMPOR I SÖDER.
I SYDAFRIKA HAR MAN ELVA HUVUDSPRÅK. DÄRFÖR KAN MAN EMELLANÅT STÖTA PÅ MYCKET LÅNGA VÄGSKYLTAR. ALLA MÅSTE JU KUNNA FÖRSTÅ DEM.
THOMAS ALVA EDISON UPPFANN INTE ALLS GLÖDLAMPAN, DET HADE ETT FLERTAL GJORT LÅNGT INNAN HONOM. VAD HAN DOCK GJORDE VAR ATT FÖRFINA UPPFINNINGEN LITE OCH SEDAN TA PATENT PÅ DEN.
JORDEN VÄGER UNGEFÄR 5 924 000 000 000 000 000 000 TON.
PULSEN HOS EN FÖRBANNAD KOLIBRIHANNE KAN SLÅ UPP TILL 1000 SLAG I MINUTEN. SAMTIDIGT HINNER HAN DRA CIRKA 500 ANDETAG.
SÅ SENT SOM 1820 MENADE MAN ATT UNIVERSUM VAR 6000 AR GAMMALT. I DAG BERÄKNAS ÅLDERN VARA MELLAN 15 OCH 20 MILJARDER ÅR.
SVARTA HÅL ÄR EN STJÄRNA SOM FALLIT SAMMAN TILL ETT LITET KLOT. HÅLET BLIR SVART FÖR TYNGDKRAFTEN ÄR SÅ STOR ATT INTE ENS LJUS KAN KOMMA UT.
VISSA SPINDELARTERS HANNAR HAR EN SCHYSST ÖVERLEVNADSINSTINKT. FÖR ATT UNDVIKA RISKEN ATT BLI UPPÄTEN EFTER PARNINGEN BINDER HANEN FAST HONAN MED SPINDELVÄV INNAN HAN PARAR SIG MED HENNE.
I DEN STORA BRANDEN I LONDON 1666 BRANN HALVA LONDON NER, MEN BARA SEX PERSONER SKADADES.
I VANLIGA FALL TILLVERKAS OSCARSSTATYETTERNA AV TENN OCH KOPPAR, MEN UNDER ANDRA VÄRLDSKRIGET SÅ GJORDES DE AV GIPS MED ÖVERDRAG AV GULD DÅ ALL METALL GICK TILL KRIGSMAK-TEN.
MYGGAN LEVER INTE PÅ BLOD UTAN AV NEKTAR. DOCK SUGER MYGGHONAN BLOD FÖR ATT FÅ PROTEIN VID ÄGGLÄGGNINGEN.
OM MAN UTVANN ALLT SALT FRÅN ALLA VÄRLDENS HAV SKULLE DET TÄCKA KONTINENTERNA MED EN HALV METER.
VALSPRÅKET SOM AGENTEN JAMES BONDS FAMILJ HAR PÅ SIN VAPENSKÖLD LYDER "VÄRLDEN RÄCKER INTE TILL".
RIKTIGT RENT GULD ÄR SÅ MJUKT ATT MAN KAN FORMA DET MED HÄNDERNA.
EN HÄSTKRAFT ÄR DEN KRAFT SOM KRÄVS FÖR ATT LYFTA 75 KILO EN METER LODRÄTT UPP PÅ EN SEKUND.
26 PÅVAR HAR HAFT OTUREN ATT BLI MÖRDADE.
TONGAÖARNA HADE ETT TAG ETT BANANFORMAT FRIMÄRKE.
ARAKNOFOBI ÄR BENÄMNINGEN PÅ VÅR RÄDSLA FÖR SPINDLAR.
DE ORTER SOM HAR DET KORTASTE NAMNET ÄR A (NORGE), O (JAPAN) OCH Y (FRANKRIKE).
OM DU FÖRVARAR EN LEVANDE GULDFISK I ETT BECKSVART RUM SA KOMMER DEN SLUTLIGEN BLI VIT.
HÄSTHUVUDET SOM ANVÄNDES I FILMEN GUDFADERN KOM FRÅN EN HUNDMATSFABRIK.
A-SYSTEMET FÖR PAPPERSSTORLEK (A3, A4, AS ETC) ÄR FRÅN BÖRJAN EN TYSK UPPFINNING SOM 1930 BLEV EN INTERNATIONELL STANDARD.
DET FINNS ÖVER 500 NAMNGIVNA FOBIER. EN AV DE MER SÄLLSYNTA ÄR TAUROFOBIN DÄR MAN ÄR RÄDD FÖR TJURAR.
I MJUKGLASS FINNS DET ETT FÖRTJOCKNINGSMEDEL SOM UTVINNS UR TÅNG.
SEDAN 1989 FÅR DE SOM DELAR UT OSCARSTATYETTERNA INTE LOV ATT SÄGA "AND THE WINNER IS..." DET INSINUERAR ATT ALLA DE ANDRA NOMINERADE ÄR FÖRLORARE. DE MÅSTE DÄRFÖR SÄGA "AND THE OSCAR GOES TO..."
FÅGLAR HAR ALLTID KALLA FÖTTER.
KOALAN HAR FÅTT SITT NAMN AV AUSTRALIENS ABORIGINER. KOALA BETYDER "INGEN DRYCK" OCH SYFTAR PÅ ATT DJURET FÅR ALL VÄTSKA FRÅN EUKALYPTUSBLADEN DJURET ÄTER.
EN AV DE FÖRSTA MOBILTELEFONERNA SOM INTE HADE ETT BATTERI STORT SOM EN MINDRE VÄSKA ÄR ERICSSONS NMT900-LUR CURT. DEN VÄGDE 750 GRAM OCH HADE EN SAMTALSTID PÅ 12 MINUTER.
FILMSTJÄRNAN NICHOLAS CAGE HADE ETT HELT ANNAT EFTERNAMN FRÅN BÖRJAN. HAN HETTE EGENTLIGEN COPPOLA, VILKET PÅVISAR HANS SLÄKTSKAP MED FRANCIS FORD COPPOLA SOM ÄR NICHOLAS FARBROR.
SPETÄLSKA DRABBAR FÖRUTOM MÄNNISKAN BARA ETT ENDA DJUR - DEN SYD- OCH MELLANAMERIKANSKA BÄLTAN.
VÅR MÅNE HAR UTVIDGAT SIN BANA UNDER MILJARDER ÅR OCH DEN GÖR DET FORTFARANDE. VARJE ÅR DRAR SIG MÅNEN CIRKA 4 CENTIMETER FRÅN JORDEN.
BRONTOFOBI ÄR BENÄMNINGEN PÅ VÅR RÄDSLA FÖR ÅSKA.
DIAMANTER ÄR RENT KOL OCH DE KAN DÄRFÖR OCKSÅ BRINNA. VID UNGEFÄR 800 GRADER CELSIUS BRINNER DE OCH FÖRVANDLAS TILL GRAFIT.
RICK SÄGER ALDRIG "PLAY IT AGAIN, SAM" I FILMEN CASABLANCA. DEN KORREKTA REPLIKEN ÄR "YOU PLAYED IT FOR HER, YOU CAN PLAY IT FOR ME. PLAY IT!". REPLIKEN "PLAY IT AGAIN, SAM" KOMMER FAKTISKT FRÅN FILMEN "EN NATT I CASABLANCA" MED BRÖDERNA MARX.
VÄRLDENS SNABBASTE DJUR ÄR TORNSVALAN SOM KOMMER UPP I DEN IMPONERANDE HASTIGHETEN 171 KILOMETER I TIMMEN. GEPARDEN KOMMER FÖRST PA 8:E PLATS MED SINA 105 KILOMETER I TIMMEN.
EN IGEL KAN SUGA I SIG NÅGRA KUBIKCENTIMETER BLOD OCH EFTER DET FASTAR DEN I UNGEFÄR ETT ÅR.
NAMNET WENDY DÖK UPP FÖR FÖRSTA GÅNGEN NÅGONSIN I BOKEN PETER PAN.
1906 VAR STENSTÖTNING EN AV DE OLYMPISKA GRENARNA.
RONALD REAGAN ARBETADE SOM SPORTKOMMENTATOR INNAN HAN BLEV FILMSTJÄRNA.
LEONARDO DICAPRIOS FÖRSTA FRAMTRÄDANDE FRAMFÖR EN KAMERA VAR I EN REKLAMFILM FÖR MJÖLK.
ETT MÄNNISKOFOSTERS HJÄRTA BÖRJAR SLÅ NÄR DET ÄR TRE VECKOR GAMMALT.
BLÅVALENS PENIS ÄR OFTA MELLAN FEM OCH SEX METER LÅNG.
MÄNNISKANS VANLIGASTE SJUKDOM ÄR CORYZA, MER KÄND SOM FÖRKYLNING. DEN FINNS I STORT SETT ÖVERALLT PÅ JORDEN.
MÄNNISKOKROPPENS STÖRSTA CELL ÄR KVINNANS ÄGG.
VÄRLDENS MINSTA LAND ÄR VATIKANSTATEN I ROM SOM BARA ÄR 0,44 KM2 STORT.
ROBOTEN R2-D2 I FILMERNA STJÄRNORNAS KRIG HETER C1-P8 I ALLA DE ITALIENSKA VERSIONERNA AV FILMERNA.
PAUL SIMON OCH ART GARFUNKEL VAR KLASSKAMRATER.
DET ÄR OMÖJLIGT ATT NYSA I SÖMNEN.
GRUNDÄMNET CALIFORNIUM HAR UPPKALLATS EFTER DEN AMERIKANSKA STATEN KALIFORNIEN.
DUMDUMKULOR HAR FÅTT NAMN EFTER STADEN SOM AMMUNITIONEN URSPRUNGLIGEN TILLVERKADES I DUMDUM I INDIEN.
EN SIFONAPTEROLOG STUDERAR LOPPOR.
HUDEN PÅ EN FULLVUXEN MÄNNISKA VÄGER UNGEFÄR 3 KILO.
NÄR TOM JONES SPELADE IN TITELSÅNGEN TILL JAMES BOND-FILMEN "THUNDERBALL" SÅ SJÖNG HAN MED SÅDAN INLEVELSE OCH SÅDANT RÖJ ATT HAN FICK EN BLACKOUT I INSPELNINGSBÅSET.
DEN FÖRSTA HALSKOTAN PÅ 055 MÄNNISKOR HETER ATLAS.
PLANETEN VENUS, VÅRT SOLSYSTEMS NÄST INNERSTA PLANET, SNURRAR ÅT MOTSATT HÅLL JÄMFÖRT MED DE ANDRA ÅTTA PLANETERNA.
PONT NEUF ÄR DEN ÄLDSTA BRON I PARIS.
ETT LAMADJUR KAN SÄNDA IVÄG EN SPOTTLOSKA UNGEFÄR FEM METER.
PÅ BAHAMAS FINNS DET EN KLASSIFIERING GÄLLANDE STARK VIND. OM DET BLÅSER EN BANANVIND SÅ BLÅSER DET SÅ HÅRT ATT BANANERNA PÅ TRÄDEN RYCKS LOSS OCH RAMLAR NER PÅ MARKEN.
I EN MÄNNISKOHJÄRNA FINNS DET LIKA MÅNGA NERVCELLER SOM DET FINNS STJÄRNOR I VINTERGATAN, CIRKA 100 MILJONER.
TRÅDARNA I NYLONSTRUMPOR ÄR VANLIGEN FEM GÅNGER TUNNARE ÄN MÄNNISKOHÅR.
ANDRA FÖRSLAG PÅ NAMN TILL TVSERIEN "MONTY PYTHON'S FLYING CIRCUS" VAR "GWEN DIBLEY'S FLYING CIRCUS", "OWL-STRETCHING TIME", "BUN, WHACKETT, BUZZARD, STUBBLE AND BOOT", "A TOAD ELEVATING MOMENT", "SEX AND VIOLENCE" SAMT "A HORSE, A BUCKET AND A SPOON".
DET FINNS ÖVER 500 NAMNGIVNA FOBIER. EN AV DE MER SÄLLSYNTA ÄR SCIOFOBIN DÄR DU ÄR RÄDD FÖR SKUGGOR.
BAKTERIER ÄR OTROLIGT SMÅ. I EN ENDA LITEN VATTENDROPPE KAN DET FINNAS 50 MILJONER BAKTERIER.
DEN ENDA MUSKEL PÅ MÄNNISKAN SOM INTE LIGGER DOLD UNDER HUDEN ÄR TUNGAN.
PÅ NYA GUINEA FINNS DET ETT SPRÅK SOM HETER TAKI. VAD SOM GÖR DET SÅ SPECIELLT ÄR ATT DET BARA INNEHÅLLER 340 ORD.
UNDER EN ENDA FOTBOLLSMATCH KAN EN ELITSPELARE RÖRA SIG NÄSTAN ELVA KILOMETER.
GEORGE CLOONEYS FÖRSTA FILMROLL VAR EN BIROLL I "RETURN OF THE KILLER TOMATOES".
CLEOPATRA KUNDE TALA 13 SPRÅK.
ALBATROSSEN KAN SOVA MEDAN DEN FLYGER.
IDEN MED ATT RÄKNA BAKLÄNGES, TILL EXEMPEL NÄR MAN SKA SÄNDA UT EN RAKET I RYMDEN, INTRODUCERADES FÖR FÖRSTA GÅNGEN I EN TYSK SCIENCE FICTIONFILM. REGISSÖREN TYCKTE ATT NEDRÄKNINGEN ÖKADE SPÄNNINGEN.
BINNIKEMASKAR KAN BLI MYCKET LÅNGA. DEN LÄNGSTA SOM TRIVS I MÄNNISKOR ÄR TAENIA SAGINATA. HONAN KAN BLI 24 M LÅNG.
MÄNNISKANS SVAGASTE MUSKEL ÄR STAPEDIUSMUSKELN I MELLANÖRAT. DESS ENDA UPPGIFT ÄR ATT FÅ DEN 3 MILLIGRAM TUNGA STIGBYGELN ATT FLYTTA SIG EN HALV MILLIMETER.
VÄRLDENS LÄNGSTA ALFABET ÄR KHMER SOM ANVÄNDS AV CIRKA 8 MILJONER MÄNNISKOR I KAMBODJA. DET HAR 74 BOKSTÄVER.
ATT KYSSAS ÄR TREVLIGT, OCH DET ÄR BRA FÖR ENS TÄNDER OCKSÅ EFTERSOM SALIV UTSÖNDRAS NÄR MAN KYSSER VARANDRA OCH SALIVEN FÖREBYGGER PLACK.
DE FYRA RINGARNA PÅ HAVENS MANETER ÄR DJURENS KÖNSORGAN. HANENS AR VITAKTIGA MEDAN HONAS AR MER RÖDAKTIGA.
MÄNNISKANS BLODOMLOPP ÄR HYGGLIGT LÅNGT. ALLA KÄRL INRÄKNADE ÄR DET MELLAN 50 000 OCH 100 000 KILOMETER LÅNGT.
EN KOMODOVARAN KAN ÄTA EN OCH EN HALV GÅNGER SIN EGEN KROPPSVIKT PÅ BARA NÅGRA MINUTER.
98% AV VÅRA GENER ÄR LIKADANA SOM HOS DVÄRGSCHIMPANSER. DET ÄR ALLTSÅ BARA 2% SOM GÖR OSS TILL TVÅ HELT OLIKA ARTER.
MACH 1 ÄR DEN TEKNISKA BENÄMNINGEN FÖR LJUDETS HASTIGHET - 1195 KILOMETER I TIMMEN.
JORDEN RÖR SIG I BANA RUNT SOLEN MED EN FART PÅ CIRKA 30 KILOMETER I SEKUNDEN.
FULLTANKAD RYMMER ETT CONCORDEPLAN 119280 LITER BRÄNSLE.
BJÖRNAR ÄR I LIKHET MED MÄNNISKAN HÖGER- ELLER VÄNSTERHÄNTA.
DET ÄR INTE BARA DU SOM FYLLER ÅR PÅ DIN FÖDELSEDAG. UNGEFÄR NIO MILJONER ANDRA MÄNNISKOR GÖR DET OCKSÅ.
EN BANANFLUGAS VINGAR SLÅR FRAM OCH TILLBAKA 200 GÅNGER I SEKUNDEN.
EN DÖDLIG DOS AV ARSENIK ÄR ENDAST 120 MILLIGRAM.
NÄR APOTEKAREN JOHN PEMBERTON BLANDADE IHOP DEN LÖSNING SOM SEDERMERA SKULLE BLI COCA-COLA SÅ VAR KOKAIN, KOKABLAD OCH COLANÖT EN DEL AV INGREDIENSERNA.
JOHN LENNONS FÖRSTA FLICKVÄN HETTE THELMA PICKLES.
WINSTON CHURCHILL FÖDDES PÅ EN DAMTOALETT.
KAMELEONTERNA ÄR BÄST BLAND DJUREN PÅ ATT RÄCKA UT TUNGAN. EN DEL AV DEM HAR EN TUNGA SOM ÄR LÄNGRE ÄN DJURETS EGNA KROPP.
DEN DANSKA FILMEN "FESTEN" FICK ETT LITE ANNORLUNDA PRIS I TYSKLAND 1999. UTMÄRKELSEN VAR "SÄMST DUBBADE FILM".
ÄVEN OM EN KACKERLACKAS HUVUD SKULLE BLI AVHUGGET KAN DEN FORTSÄTTA LEVA I NIO DAGAR INNAN DEN SVÄLTER IHJÄL.
ELEKTRISKA STOLEN UPPFANNS AV EN TANDLÄKARE.
PÅ GRUND AV FRIKTION KAN ETT CONCORDEPLANS NOSPARTI BLI CIRKA 180 GRADER VARMT UNDER EN FLYGNING. RESTEN AV PLANET BLIR OCKSÅ VARMARE PÅ GRUND AV FRIKTIONEN, FAST INTE LIKA MYCKET. DÅ METALL UTVIDGAR SIG VID VÄRME BLIR PLANET 24 CENTIMETER LÄNGRE NÄR DEN FLYGER MED TOPPHASTIGHET.
DET FINNS ÖVER 30 000 OLIKA SORTERS ROSOR.
DET VAR TYSKEN FRIEDRICH SERTONER SOM 1806 LYCKADES RENFRAMSTÄLLA DEN VERKSAMMA SUBSTANSEN UR OPIUM. HAN DÖPTE ÄMNET TILL MORFIN EFTER SÖMNGUDEN MORFEUS.
KOALAN ÄLSKAS AV BARN ÖVER HELA VÄRLDEN, MEN ÄR SAMTIDIGT ETT AV DE MEST SÖMNIGA DJUREN I FAUNAN. DEN ANVÄNDER 22 TIMMAR AV ETT DYGN TILL ATT SOVA.
PAPUA NYA GUINEAS ALFABET ROTOKAS ÄR DET KORTASTE ALFABET MAN HAR FUNNIT. DET HAR BARA ELVA BOKSTÄVER: A, B, E, G, I, K, O, P,R,TOCHU.
LÄKAREN ALEXANDER WOODS UPPFANN INJEKTIONSSPRUTAN 1852.
PÅ JAPANSKA UTTALAS ORDEN FÖR FYRA OCH DÖD PÅ PRECIS SAMMA SÄTT. DETSAMMA GÄLLER FÖR ORDEN FÖR NIO OCH SMÄRTA. DÄRFÖR HAR INGA HOTELLRUM I JAPAN NUMMER 4 ELLER NUMMER 9.
OM MAN FYLLER ETT VANLIGT KONISKT SNAPSGLAS TILL HALVA HÖJDEN, SÅ ÄR GLASET BARA FYLLT TILL 12-13 PROCENT.
DET ÄR FYSISKT OMÖJLIGT FÖR DIG ATT SLICKA SPETSEN AV DIN ARMBÅGE.
FRENOLOGI ÄR EN GAMMAL LÄRA SOM FÖRESPRÅKAR ATT MAN KAN UTLÄSA EN MÄNNISKAS KARAKTÄR UTIFRÅN SKALLENS FORM.
DEN AFRIKANSKA STRUTSEN LÄGGER VÄRLDENS STÖRSTA ÄGG. SKALET PÅ ÄGGET ÄR 1,5 MILLIMETER TJOCKT OCH DET RÄCKER FÖR ATT BÄRA VIKTEN AV EN VUXEN MAN.
DET FINNS ÖVER 500 NAMNGIVNA FOBIER. EN AV DE MER SÄLLSYNTA ÄR LUTRAFOBIN DÄR MAN ÄR RÄDD FÖR UTTRAR.
VÄRLDENS HÖGSTA STATY SOM PABLO PICASSO HAR GJORT FINNS HÄR I SVERIGE, NÄRMARE BESTÄMT I KRISTINEHAMN I VÄRMLAND.
I ETT DIGITALUR VIBRERAR KVARTSKRISTALLEN 32 768 GÅNGER PER SEKUND.
STEVEN SPIELBERG ACCEPTERADE INTE ATT FÅ NÅGON LÖN FÖR SITT JOBB MED FILMEN "SCHINDLERS LIST% HAN TYCKTE ATT DE PENGARNA SKULLE VARA BLODSPENGAR.
DE 7 STRÅLARNA I FRIHETSGUDINNANS KRONA REPRESENTERAR DE SJU VÄRLDSHAVEN OCH KONTINENTERNA.
DE SVENSKA SEDLARNA BESTÅR AV RÅBOMULL, INTE PAPPER SOM MAN KAN TRO. DET ÄR DÄRFÖR SOM DE ÖVERLEVER EN OMGÅNG I TVÄTTMASKINEN.
HAJEN ÄR DEN ENDA FISKEN SOM KAN BLINKA MED BÅDA ÖGONEN.
HAJAR HAR INGET SKELETT AV BEN SOM ANDRA FISKAR OCH RYGGRADSDJUR UTAN DERAS SKELETT BESTÅR HELT OCH HÅLLET AV BROSK.
SKÅDESPELAREN DOLPH LUNDGREN HAR EN AKADEMISK EXAMEN FRÅN KUNGLIGA TEKNISKA HÖGSKOLAN.
STÄPPFOLKET WATUSIERNA SOM LEVER I KONGO ÄR VÄRLDENS LÄNGSTA FOLKSLAG. DE BLIR UPP TILL 2,1 METER. LUSTIGT NOG ÄR DE GRANNAR MED PYGMEERNA SOM ÄR VÄRLDENS KORTASTE FOLK.
NOSHÖRNINGENS HORN BESTÅR AV SAMMANPRESSAT HÅR.
FRÅN BÖRJAN SÅLDES COCA-COLA PÅ RECEPT MOT MELANKOLI, HYSTERI OCH MIGRÄN.
OMRÅDET SOHO I NEW YORK HAR FÅTT SITT NAMN EFTER ATT DET LIGGER SÖDER OM HOUSTON STREET, ALLTSÅ SOUTH OF HOUSTON.
GREKLANDS NATIONALSÅNG HAR 158 VERSER.
GRISEN ÄR DET ENDA DJUR SOM LIKSOM MÄNNISKAN KAN BLI SOLBRÄND.
VÄRLDENS LÄNGSTA NAMN PÅ EN STAD BESTÅR AV 167 BOKSTÄVER.
BRUCE WILLIS ÄR VÄNSTERHÄNT, MEN I FILMEN "SJÄTTE SINNET" SKRIVER HAN MED HÖGER HAND, ENBART FÖR ATT KAMERAVINKELN SKULLE BLI BÄTTRE I EN SCEN.
EN SPÄCKHUGGARE KAN BLI 80-90 ÅR GAMMAL.
EN MULA ÄR EN KORSNING MELLAN EN ÅSNEHINGST OCH ETT HÄSTSTO.
ETT KOSMISKT ÅR ÄR DE CIRKA 240 MILJONER ÅR DET TAR FÖR VÅRT SOLSYSTEM ATT FULLGÖRA ETT VARV RUNT CENTRUM I VÅR GALAX, VINTERGATAN.
ETT FLERTAL AV DE STÖRRE STRIDSSCENERNA l "BRAVEHEART" VAR TVUNGNA ATT FILMAS EN GÅNG TILL EFTERSOM MÅNGA AV STATISTERNA VISADE SIG HA ARMBANDSUR OCH SOLGLASÖGON PÅ SIG.
DEN FRANSKE FÖRFATTAREN ANTOINE SAINT-EXUPERY, SOM HAR SKRIVIT BOKEN "DEN LILLE PRINSEN" DOG GENOM ATT HANS ENSITSIGA PLAN STÖRTADE DEN 31:A JULI 1944. INGEN VET RIKTIGT VARFÖR DET STÖRTADE.
DET FINNS ÖVER 500 NAMNGIVNA FOBIER. EN AV DE MER SÄLLSYNTA ÄR COULFOFOBIN DÄR MAN ÄR RÄDD FÖR CLOWNER.
TV-SERIEN "STAR TREK" VAR INTE NÅGON STÖRRE SUCCÉ DÅ DEN DEBUTERADE 1964. EFTER TVÅ SÄSONGER TRÖTTNADE TV-BOLAGET NBC OCH VILLE LÄGGA NED DEN.
DEN FÖRSTA PRODUKTEN I VÄRLDEN SOM FICK EN STRECKKOD PÅ SIG VAR DET AMERIKANSKA TUGGUMMIT WRIGLEY'S.
HAR MAN RÅKAT UT FÖR POLYDAKTYLI HAR MAN FÖTTS MED FLER ÄN TIO FINGRAR OCH TIO TÅR.
DEN FÖRSTA KVINNA SOM FICK TILLSTÅND ATT UNDERVISA PÅ UNIVERSITETET SORBONNE I PARIS VAR NOBELPRISTAGAREN MARIE CURIE.
EN BLIXT VÄRMER I GENOMSNITT UPP LUFTEN TILL CIRKA 3000 GRADER.
I EN TIDIG MANUSVERSION AV "ALIEN" SKULLE ROLLEN SOM RIPLEY SPELAS AV EN MAN.
JOSEF STALIN SLAPP GÖRA RYSK MILITÄRTTJÄNST UNDER FÖRSTA VÄRLDSKRIGET EFTERSOM HANS ENA FOT VAR MISSBILDAD OCH HADE TVÅ IHOPVÄXTA TÅR.
EN TROLLSLÄNDA KAN FLYGA BAKLÄNGES LIKA FORT SOM DEN KAN FLYGA FRAMLÄNGES.
EN GRUPP SKOGSFÅGLAR PÅ NYA GUINEA, PITOHUIERNA, HAR GIFTIGA FJÄDRAR OCH GIFTIG HUD. ETT ROVDJUR SOM FÅNGAR FÅGELN I MUNNEN REAGERAR INSTINKTIVT OCH SPOTTAR UT FÅGELN IGEN.
ÄR MAN EN ENORM KAFFEDRICKARE OCH DRICKER 100 KOPPAR KAFFE PÅ FYRA TIMMAR LIDER MAN STOR RISK ATT DÖ AV KOFFEINET MAN DÅ HAR FÅTT I SIG.
INNAN DE BYTTE TILL SINA NYA NAMN HETTE MICHAEL CAINE FAKTISKT MAURICE MICKLEWHITE OCH CHER HETTE CHERILYN SARKISIAN LA PIERE.
DET KRÄVS BARA TVÅ MUSKLER FÖR ATT LE, DET VILL SÄGA DRA UPP MUNGIPORNA. OM MAN SEDAN RÄKNAR IN ALLA MUSKLER RUNT ÖGONEN SOM GER ETT ÄKTA LEENDE SÅ BLIR DET MÅNGA, MÅNGA FLER.
ATT KVINNOKLÄDER OCH MANSKLÄDER HAR OLIKA KNÄPPNING HAR SITT URSPRUNG FRÅN DEN TIDEN DÅ MÄN TOG PÅ SIG SINA KLÄDER SJÄLVA MEDAN KVINNOR FICK HJÄLP AV EN KAMMARJUNGFRU SOM DÅ KNÄPPTE KLÄDERNA FRAMIFRÅN.
ENGELSKA SPRÅKET ANSES VARA DET ORDRIKASTE SPRÅKET MED RUNT 455000 AKTIVA OCH 700000 DÖDA ORD.
RÅ SPARRIS ÄR SVAGT GIFTIG.
ARNOLD SCHWARZENEGGER FICK 15 MILJONER DOLLAR FÖR SIN ROLL I "TERMINATOR 2", EN FILM DÄR HAN SÄGER 700 ORD. DET BLIR 21,429 DOLLAR PER ORD. CITATKLASSIKERN " "HASTA LA VISTA, BABY" KOSTADE ALLTSÅ 85,716 DOLLAR.
PÅ EN FLIGHT FRÅN ANTWERPEN TILL LONDON 1997 VAR HELA 21 ST AV PASSAGERARNA 100 ÅR GAMLA.
OM MAN SÄGER GANDHI SÄGER NOG DE FLESTA ATT HELA HANS NAMN VAR MAHATMA GANDHI, MEN HAN HETTE FAKTISK MOHANDAS KARAMCHAN GANDHI. MAHATMA VAR EN HEDERS-TITEL SOM BETYDER STOR ANDE.
VERKTYGEN SOM ANVÄNDS FÖR ATT FIXA TILL JACK NAPIER (JACK NICHOLSON) EFTER HANS KEMIKALIEBAD I FILMEN "BATMAN" ÄR SAMMA VERKTYG SOM DEN SADISTISKE TANDLÄKAREN ORIN SCRIVELLO (STEVE MARTIN) ANVÄNDER I FILMEN "LITTLE SHOP OF HORRORS" FRÅN 1986.
DE FLESTA FISKAR ÄR MER ELLER MINDRE VAKNA HELA SITT LIV, MEN DET FINNS FISKAR SOM SOVER I VATTNET. DE LUTAR SIG DÅ MOT EN STEN ELLER STÅR LODRÄTT I VATTNET.
EN SNIGEL KAN SOVA I TRE AR.
MYGGOR KAN SPÅRA MÄNNISKOR PÅ UPP TILL 100 METERS HÅLL VIA ÄMNEN I VÅR ANDEDRÄKT.
VÄRLDENS STÖRSTA TAVLA, "SLAGET VID GETTYSBURG% ÄR MÅLAD AV AMERIKANEN PAUL PHILIPPOTEAUX OCH HANS 16 ASSISTENTER. DEN ÄR 21 METER HÖG OCH 125 METER BRED.
TYRANNOSAURUS REX LED AV PORTVINSTÅ (GIKT).
DET FINNS 336 FÖRDJUPNINGAR PÅ EN GOLFBOLL.
VÄRLDENS STÖRSTA SPRÅK ÄR MANDARIN-KINESISKA SOM ÄR MODERSMÅL FÖR NÄSTAN 900 MILJONER MÄNNISKOR. ENGELSKA SOM MODERSMÅL HAR "BARA" 322 MILJONER ANHÄNGARE.
DET KRÄVS 150 HUGG FRÅN EN KOBRA FÖR ATT FÅ FRAM TILLRÄCKLIGT MYCKET GIFT FÖR ATT PRODUCERA 1 GRAM SERUM.
ALFRED NOBELS BROR EMIL NOBEL DOG AV EN EXPLOSION I BRÖDERNAS LABORATORIUM DÄR DE BÅDA EXPRIMENTERADE MED SPRÄNGOLJA, FÖREGÅNGAREN TILL DYNAMITEN.
OM ALLT REGN I ATMOSFÄREN FÖLL PÅ EN GÅNG SKULLE DET FALLA 25 MILLIMETER REGN ÖVER HELA JORDEN.
MITT INNE I SOLEN ÄR DET 15 MILJONER GRADER VARMT. PÅ YTAN ÄR DET BETYDLIGT SVALARE - BARA 5800 GRADER.
SALTET I VÅRA TÅRAR KOMMER FRÅN MATEN VI ÄTER. DET TRANSPORTERAS VIA BLODOMLOPPET TILL ÖGATS TÅRKANALER DÄR TÅRARNA BILDAS.
LIDER DU AV ODONTOFOBI HAR DU REJÄL RESPEKT FÖR TANDLÄKARE.
JONATHAN FRAKES VÄGRADE RAKA SIN RYGG I SIN KÄRLEKSSCEN MED MARTINA SIRTIS I FILMEN "STAR TREK: NEMESIS". RYGGHÅREN FICK DÄRFÖR TAS BORT PÅ DIGITAL VÄG.
SVARTA STRECK PÅ EN STRECKKOD MOTSVARAR SIFFRAN ETT, DE VITA MELLANRUMMEN MOTSVARAR SIFFRAN NOLL. TILLSAMMANS BILDAR DE EN LÅNG KOD SOM INNEHÅLLER ALL INFORMATION OM VARAN MAN KAN VILJA VETA.
DEN STÖRSTA SKILLNADEN MELLAN EBB OCH FLOD HAR UPPMÄTTS I FUNDY BAY MELLAN KANADA OCH STATEN MAINE I USA. 16 METER VAR SKILLNADEN MELLAN EBB OCH FLOD.
UNDER JURATIDEN FANNS DET HAVSDINOSAURIER - ICHTYOSAURIER - MED UPP TILL 22 CENTIMETER STORA ÖGON.
DEN ROSA ELLER RÖDA FÄRGEN PÅ FLAMINGOR INDIKERAR ATT FÅGELN HAR BLIVIT KÖNSMOGEN. DE ÄR DÄRFÖR HELT VITA NÄR DE KLÄCKS OCH FÅR FÄRGEN FÖRST EFTER ETT PAR ÅR.
BARBIES HELA NAMN ÄR BARBARA MILLICENT ROBERTS.
KNÖLVALAR KAN ÅSTADKOMMA LJUD SOM ÄR 190 DB HÖGT.
DET MOTSVARAR LJUDET RUNT EN JUMBOJET SOM LYFTER.
INNAN JOSEF STALIN BLEV REVOLUTIONÄR TÄNKTE HAN SATSA PÅ EN KARRIÄR SOM PRÄST MEN BLEV AVSTÄNGD FRÅN PRÄSTSKO-LAN EFTERSOM ATT HAN VAR ALLDELES FÖR AGGRESSIV, VÅLDSAM OCH SÖP.
WALT DISNEY VAR RÄDD FÖR MÖSS.
TJUGO PROCENT AV VÄRLDENS BEFOLKNING HAR ETT GENETISKT FEL SOM GÖR ATT DE SAKNAR EN KINDTAND.
IKEA-VARUHUSET SOM LIGGER I KUNGENS KURVA I STOCKHOLM AR ARKITEKTONISKT INSPIRERAD AV GUGGENHEIMMUSEET I NEW YORK.
VÄTSKAN INUTI UNGA SMÅ KOKOSNÖTTER, KOKOSVATTEN, KAN ANVÄNDAS SOM ERSÄTTNING FÖR BLODPLASMA.
DEN STÖRSTA HAJEN MÄNNISKAN KÄNNER TILL ÄR VALHAJEN. DEN KAN BLI UPP TILL 14 METER LÅNG.
EN BIL STÅR I GENOMSNITT STILLA 23 AV DYGNETS 24 TIMMAR.
50% AV ALLA BANKRÅN SKER PÅ FREDAGAR.
200 BARN FÖDS VARJE MINUT, VÄRLDEN ÖVER.
ALEXANDER GRAHAN BELL SOM UPPFANN TELEFONEN FICK ALDRIG PRATA VARKEN MED SIN MOR ELLER FRU PÅ DEN. BÅDA VAR NÄMLIGEN DÖVA.
ALFRED HITCHCOCK HADE INGEN NAVEL.
HJÄRTAT PÅ EN RÄKA SITTER I DESS HUVUD.
I EN 80 ÅR LÅNG UNDERSÖKNING AV 200 000 STRUTSAR RAPPORTERADES INTE ETT ENDA FALL DÅ EN STRUTS STUCKIT HUVUDET I MARKEN.
DET ÄR FYSISKT OMÖJLIGT FÖR GRISAR ATT TITTA UPP I HIMLEN.
FLER ÄN 50 % AV VÄRLDENS BEFOLKNING HAR ALDRIG GJORT ELLER TAGIT EMOT ETT TELEFONSAMTAL.
HÄSTAR KAN INTE KRÄKAS.
"SIXTH SICK SHEIK'S SIXTH SHEEP'S SICK" ÄR DEN SVÅRASTE TUNGVRICKAREN SOM FINNS PA ENGELSKA SPRÅKET.
RÅTTOR FÖRÖKAR SIG SÅ FORT, ATT PÅ ARTON MÅNADER KAN DE HA FLER ÄN EN MILJON AVKOMMOR.
EN TIMMES ANVÄNDANDE AV HÖRLURAR ÖKAR BAKTERIEMÄNGDEN I ÖRAT 700 GÅNGER.
23% AV ALLA FEL SOM UPPSTÅR PÅ KOPIERINGSAPPARATER UPPSTÅR AV ATT FOLK SITTER PÅ DEM NÄR DE KOPIERAR BILDER PÅ SIN EGEN RUMPA.
NÄSTAN ALLA LÄPPSTIFT INNEHÅLLER FISKFJÄLL.
INGET PAPPER KAN VIKAS I HÄLFTEN FLER ÄN 7 GÅNGER.
MAN BRÄNNER FLER KALORIER NÄR MAN SOVER ÄN NÄR MAN TITTAR PÅ TV.
HJÄRTER KUNG ÄR DEN ENDA KUNGEN UTAN MUSTASCH.
AMERICAN AIRLINES SPARADE PÅ ETT ÅR 40 000 DOLLAR FRÅN ATT DRA IN EN OLIV PÅ VARJE SALLAD I FÖRSTA KLASS.
DET MESTA DAMMET I DITT HEM KOMMER FRÅN DIN EGEN DÖDA HUD.
MICHAEL JORDAN FICK MER SPONSORPENGAR FRÅN NIKE ÅRLIGEN ÄN VAD ALLA NIKES FABRIKSARBETARE I MALAYSIA TJÄNADE TILLSAMMANS.
RICHARD MILLHOUSE NIXON VAR DEN FÖRSTA AMERIKANSKE PRESIDENTEN VARS NAMN INNEHÖLL ALLA DE BOKSTÄVER FÖR ATT FORMA ORDET "CRIMINAL"
SKÖLDPADDOR KAN ANDAS GENOM RUMPAN.
ENGELSKANS LÄNGSTA ORD, ENLIGT THE OXFORD ENGLISH DICTIONARY ÄR, PNEUMONOULTRAMICROSCOPIC-SILICOVOLCANOCONIOSIS.
NAGELTRÅNG ÄR ÄRFTLIGT.
DET LÄNGSTA GEOGRAFISKA NAMNET SOM FORTFARANDE ANVÄNDS ÄR EN KULLE PÅ NYA ZEELAND.TAUMATAWHAKATANGIHA HAKATANGIHA NGAKOAUAUOTAMATEATURIPUKAKAPIKIMAUNGAHORONUKUPOKAIWE-NUAKIT NATAHU, HETER DEN.
TELLY SAVALAS OCH LOUIS ARMSTRONG DOG BÅDA PÅ SINA FÖDELSEDAGAR.
KALLE ANKAS ANDRA NAMN ÄR FAUNTLEROY.
FÖRKORTNINGEN FÖR DEN RYSKA UNDERRÄTTELSETJÄNSTEN KGB, STÅR FÖR KOMITET GOSUDARSTVENNOY BEZOPASNOSTI.
KÄNGURUN OCH EMUN KAN INTE GÅ BAKLÄNGES, OCH ÄR DÄRFÖR SYMBOLER FÖR KONTINENTEN AUSTRALIEN.
GORDON SUMNER, ROCKSTJÄRNAN ÄVEN KÄND SOM STING, FICK SITT SMEKNAMN FRÅN DE GUL-SVARTRANDIGA TRÖJORNA HAN BRUKADE ANVÄNDA. DE ANDRA BANDMEDLEMMARNA TYCKTE HAN SÅG UT SOM EN HUMLA.
EN SMAKLÖKS LIVSLÄNGD ÄR 10 DAGAR.
FRAM TILL 1890 BLEV KORGOSSARNA I VATIKANEN KASTRERADE FÖR ATT DERAS RÖSTER INTE SKULLE MÖRKNA.
UNDERSÖKNINGAR VISAR ATT MYGGOR DRAR SIG TILL FOLK SOM NYLIGEN ÄTIT BANANER.
EN KATT HAR STÖRRE CHANS ATT KLARA ETT FALL FRÅN 20:E VÅNINGEN ÄN ETT FRÅN 7:E.
OM NASA BESTÄMDE SIG FÖR ATT SKICKA FÅGLAR UT I RYMDEN, SKULLE DE SNART DO. FÅGLAR BEHÖVER NÄMLIGEN DRAGNINGSKRAFTEN FÖR ATT SVÄLJA.
VARJE GÅNG DU SLICKAR PÅ ETT FRIMÄRKE FÅR DU I DIG EN TIONDELS KALORIE.
I MEDELTAL SKRATTAR EN VUXEN 15 GÅNGER OM DAGEN. EN BEBIS SKRATTAR 400.
EN DUVAS BEN VÄGER MINDRE ÄN DESS FJÄDRAR.
MAN HÖR INTE LIKA BRA NÄR MAN ÄR PROPPMÄTT.
DEN MEST POPULÄRA TIDEN ATT FÅ SYN PÅ ETT UFO ÄR KL: 23.00.
DET GÅR 31,557,600 SEKUNDER PÅ ETT ÅR.
ÄR EN BLÄCKFISK TILLRÄCKLIGT HUNGRIG KAN DEN ÄTA UPP SINA EGNA ARMAR.
PÅ VILKEN DEL AV KROPPEN SITTER MEST BAKTERIER? MELLAN TÅRNA.
JO-JON ÄR VÄRLDENS NÄST ÄLDSTA LEKSAK EFTER DOCKAN.
ORDET "KRIG" PÅ SANSKRIT BETYDER "ÖNSKAN OM FLER KOR".
KÄNGURUR ÄR LAKTOS INTOLERANTA.
GETTER FÅR ENLIGT LAG INTE BÄRA BYXOR I MASSACHUSETTS.
UNGEFÄR 250 GÅNGER KOMMER DU ATT SNYTA DIG I ÅR.
MYGGOR HAR 47 ST TÄNDER.
I STADEN LAWRENCE, KANSAS ÄR DET EMOT LAGEN ATT BÄRA OMKRING BIN I DIN HATT.
ENDAST 30% AV ALLA MÄNNISKOR KAN VIFTA PÅ NÄSVINGARNA.
UR LUTANDE TORNET I PISA HAR FLER ÄN 250 MÄNNISKOR FALLIT MOT DÖDEN SEDAN 1174.
I ANTIKENS EGYPTEN VAR DET DÖDSSTRAFF PÅ ATT DÖDA EN KATT.
ENLIGT BRITTISK LAG 1845 VAR DET BELAGT MED DÖDSSTRAFF FÖR FÖRSÖK ATT BEGÅ SJÄLVMORD.
JULEN VAR EN GÅNG FÖRBJUDEN I ENGLAND.
I HARTFORD, CONNECTICUT ÄR DET OLAGLIGT FÖR EN MAN ATT KYSSA SIN FRU PÅ SÖNDAGAR.
I KENTUCKY ÄR DET OLAGLIGT ATT GÅ OMKRING MED GLASS I BAK FICKAN.
ATT SKICKA EN HEL BYGGNAD HAR VARIT OLAGLIGT I USA SEDAN 1916 DÅ EN MAN POSTADE ETT 40 000 TON TUNGT TEGELHUS FÖR ATT UNDVIKA HÖGA FRAKTKOSTNADER.
EN FULLASTAD OLJETANKER BEHÖVER 20 MINUTER FÖR ATT BROMSA TILL STILLASTÅENDE.
ALLT SOLLJUS SOM TRÄFFAR JORDENS YTA UNDER ETT ENDA ÖGONBLICK, VÄGER LIKA MYCKET SOM ETT KRYSSNINGSFARTYG.
UNDER ATOMBOMBENS FÖDELSE I ALAMOGORDO, NEW MEXICO, USA KUNDE ANSTÄLLNINGSKRAVEN FÖR EXEMPELVIS VAKTMÄSTARE OCH STÄDARE SE ANNORLUNDA UT. ICKE LÄSKUNNIGA OCH ANALFABETER FÖREDROGS FRAMFÖR BÄTTRE UTBILDADE. ANLEDNINGEN VAR ATT MYNDIGHETERNA INTE VILLE ATT DE SKULLE KUNNA LÄSA DET SOM STOD PÅ DE PAPPER SOM SLÄNGDES.
4000 MÄNNISKOR SKADAS AV TEKANNOR VARJE ÅR.
ALLA SJUKHUS I SINGAPORE ANVÄNDER PAMPERSBLÖJOR.
COLGATE MÖTTE EN STOR UTMANING NÄR DE SKULLE MARKNADSFÖRA SIN TANDKRÄM I SPANSKTALANDE LÄNDER. COLGATE BETYDER NÄMLIGEN PÅ SPANSKA "STICK OCH HÄNG DIG".
DET FINNS I MEDELTAL 333 BITAR TOALETTPAPPER PÅ EN RULLE.
KROPPEN INNEHÅLLER CA 100,000,000,000,000 CELLER.
INGEN AMERIKANSK PRESIDENT HAR HAFT BRUNA ÖGON.
DEN ENDA DEL AV KROPPEN SOM INTE KAN DRABBAS AV CANCER ÄR ÖGATS LINS.
KVINNLIGA HYENOR HAR EN OUTVECKLAD PENIS.
AVSTÅNDET FRÅN JORDENS YTA TILL JORDENS MITTPUNKT ÄR 5955 KM.
BOWLING UPPFANNS I EGYPTEN 5000 ÅR FK.
DALMATINER FÖDS UTAN PRICKAR.
DELFINER HAR ALLTID ETT ÖGA ÖPPET NÄR DE SOVER.
EUROPA OCH NORDAMERIKA GLIDER ISÄR VARANDRA MED SAMMA HASTIGHET SOM VÅRA NAGLAR VÄXER.
LEONARDO DA VINCI KUNDE SKRIVA MED EN HAND SAMTIDIGT SOM HAN MÅLADE MED DEN ANDRA.
DET FINNS INGA KLOCKOR I LAS VEGAS CASINON.
JORDENS VARMASTE PLATS ÄR EL AZIZIA, l LIBYEN.
HÖGERHÄNTA PERSONER LEVER I GENOMSNITT 9 ÅR LÄNGRE ÄN VÄNSTERHÄNTA.
DET TRYCKS MER MONOPOLPENGAR ÄN VANLIGA PENGAR I HELA VÄRLDEN.
I MEDELTAL INNEHÅLLER VARJE CHOKLADKAKA FÖRUTOM CHOKLAD, ÄVEN 8 ST INSEKTSBEN.
EN ISBJÖRNS HUD ÄR SVART.
ELVIS HADE EN TVILLINGBROR SOM DOG VID FÖDSELN. HAN HETTE GARON.
KINA HAR FLER MÄNNISKOR SOM TALAR ENGELSKA ÄN USA.
OM ALLA INVÅNARE I KINA GICK PÅ LED FÖRBI DIG SKULLE DET FORTSÄTTA I ALL EVIGHET, MED TANKE PÅ REPRODUKTIONEN.
MYROR FALLER ALLTID PÅ HÖGERSIDAN OM DE BLIR BERUSADE.
SÅ HÄR MYCKET KAN DU FÅ OM DU SÄLJER VARJE ANVÄNDBAR DEL AV DIN KROPP: 400 MILJONER KR.
2 MIN. 18 SEK. ÄR REKORDET FÖR EN UNDERVATTENSKYSS.
5% AV ALLA VUXNA GÅR I SÖMNEN.
EN BRA BUTLER BÖR BYTA SKOR VAR TREDJE TIMME.
"KING KONG" VAR ADOLF HITLERS FAVORITFILM.
DET KRÄVS UNGEFÄR 1,12 MILLIONER MYGGOR FÖR ATT TÖMMA DIN KROPP HELT PÅ BLOD, FÖRUTSATT ATT DE BITER DIG SAMTIDIGT.
ETT AV SKÄLEN TILL ATT FIDEL CASTRO ODLADE SKÄGG VAR ATT USA'S HANDELSHINDER GJORDE DET SVÅRT ATT FÅ TAG PÅ RAKBLAD.
DET TAR I MEDELTID 138 MIN FÖR EN VUXEN ATT SE FILMEN "BROARNA I MADISON COUNTY" MEN BARA 118 MIN ATT LÄSA BOKEN.
LIMMET PÅ ISRAELISKA FRIMÄRKEN ÄR KOSCHER GODKÄNT.
"DNA" STÅR FÖR DEOXYRIBONUCLEIC ACID.
DET VETENSKAPLIGA ORDET FÖR ATT PETA SIG I NÄSAN ÄR RHINOTILLEXONAMIA.
SYLVESTER STALLONE JOBBADE EN GÅNG I TIDEN MED ATT STÄDA UR LEJONBUREN PÅ EN CIRKUS.
"BILLIE JEAN" AV MICHAEL JACKSSON VAR DEN FÖRSTA MUSIKVIDEON ATT SPELAS PA MTV, GJORD AV EN SVART ARTIST.
EN FLYGPLATS I ENGLAND ANVÄNDER TINA TURNER LÅTAR FÖR ATT SKRÄMMA BORT FÅGLAR FRÅN START OCH LANDNINGSBANAN.
1938 BLEV ADOLF HITLER VALD TILL "TIMES - MAN OF THE YEAR".
EFTER SIN DÖD BLEV ALBERT EINSTEINS HJÄRNA SATT I BURK FÖR ATT UNDERSÖKAS OCH SPARAS.
EMILIO MARCO PALMA VAR DEN FÖRSTE PERSONEN ATT FÖDAS PÅ ANTARKTIS ÅR 1978.
I SNITT FÖRSVINNER 7,5% AV ALLA DOKUMENT PÅ ETT KONTOR.
BILL GATES BÖRJADE PROGRAMMERA DATORER VID 13 ÅRS ÅLDER.
I USA KÖPER UNGA TUGGUMMI FÖR EN HALV MILJARD ÅRLIGEN.
I DE FLESTA REKLAMFOTON MED EN KLOCKA AVBILDAD STÅR TIDEN PÅ 10.10.
OGIFTA LEDER SJU OCH EN HALV GÅNGER SÅ STOR RISK ATT BLI INTAGNA PÅ PSYKIATRISK VÅRD.
MÄNNISKAN PRODUCERAR UNDER SIN LIVSTID TILLRÄCKLIGT MYCKET SALIV FÖR ATT FYLLA TVÅ SWIMMINGPOOLER.
ETT FYRAÅRIGT BARN FRÅGAR I SNITT 437 FRÅGOR OM DAGEN.
INGEN VET VARFÖR MEN 90% AV ALLA KVINNOR GÅR DIREKT ÅT HÖGER NÄR DE KOMMER IN I ETT VARUHUS.
I NEW YORK BLIR 311 MÄNNISKOR PER ÅR BITNA AV RÅTTOR. HELA 1519 BLIR DOCK BITNA AV ANDRA NEW YORK BOR.
OM EN LOPPA VORE MÄNNISKA, KUNDE DEN HOPPA 300 M RÄTT UPP I LUFTEN.
MER ÄN 213 AV ALLA MÄNNISKOR SOM BLIVIT ÄLDRE ÄN 65 ÅR LEVER ÄN IDAG.
EN MÄNNISKA ANDAS IN CA 20 KG DAMM UNDER EN LIVSTID.
BEBISAR FÖDS ALLTID MED BLÅA ÖGON.
1988 FÖLL EN PUDEL FRÅN ETT HÖGHUS I BUENOS AIRES OCH DÖDADE TRE PERSONER. EN FICK PUDELN I HUVUDET, DEN ANDRE BLEV ÖVERKÖRD AV EN BUSS OCH DEN TREDJE FICK EN HJÄRTATTACK.
DET FINNS FLER ÄN 8000 ICKE FUNGERANDE SATELITER SOM KRETSAR RUNT JORDEN.
BILL WYMAN I "ROLLING STONES" BLEV TILLSAMMANS MED 13-ÅRIGA MANDY SMITH. SJU ÅR SENARE GIFTER SIG BILL WYMANS SON, STEPHEN MED MANDY'S MOR. DETTA GÖR STEPHEN TILL STYVFAR TILL SIN EGEN STYVMOR.
OLÖSTA MYSTERIER
OM MAN LYCKAS MED ATT MISSLYCKAS, VAD HAR MAN DÅ EGENTLIGEN GJORT?
VARFÖR KALLAS TIDEN DÅ TRAFIKEN GÅR SOM LÅNGSAMMAST FÖR RUSNINGSTRAFIK?
HUR SNABBT ÄR MÖRKRETS HASTIGHET?
OM NU BARBIE ÄR SÅ POPULÄR, VARFÖR MÅSTE DU KÖPA HENNES KOMPISAR?
VAD HÄNDER OM DU SKRÄMS HALVT TILL DÖDS TVÅ GÅNGER?
HUR KAN ETT HUS BRINNA UPP NÄR DET BRINNER NER?
OM DIN DAMMSUGARE SUGER, AR DET DÅ EN DÅLIG SAK?
HUR KAN MAN VETA NÄR EN SMURF HAR SATT NÅGOT I HALSEN?
OM ETT ORD I ORDLISTAN ÄR FELSTAVAT, HUR FÅR MAN REDA PÅ DET?
OM MAN VÄNTAR SIG DET OVÄNTADE, BLIR INTE DÅ DET OVÄNTADE VÄNTAT?
NÄR MAN TAR KORT PÅ EN OMELETT, VAD SÄGER DEN DÅ?
HAR TE-DRICKARE KAFFERAST?
VARFÖR RAPPORTERAR DE OM STRÖMAVBROTT PÅ TV?
VARFÖR TRYCKER MAN HÅRDARE PÅ FJÄRRKONTROLLEN NÄR BATTERIERNA ÄR DÅLIGA?
OM DET BLIR NOLL GRADER PÅ KVÄLLEN OCH IMORGON BITTI SKALL DET VARA DUBBELT SÅ KALLT, HUR KALLT BLIR DET DÅ?
VARFÖR ÄR ORDET "FÖRKORTNING" ETT SÅ LÅNGT ORD?
VARFÖR KAN EN KILLE TRO PÅ ATT DET FINNS 400 MILJARDER STJÄRNOR MEN OM DU SÄGER ATT DET ÄR NYMÅLAT MÅSTE HAN ÄNDÅ RÖRA VID DET?
VEMS GRYMMA IDE VAR DET ATT SÄTTA ETT "S" I LÄSPA?
SKULLE EN FLUGA UTAN VINGAR KALLAS FÖR EN GÅA?
VARFÖR BLIR HÅRET LJUSARE AV SOLEN MEDAN HUDEN BLIR MÖRKARE?
VARFÖR KAN INTE TJEJER LÄGGA PÅ MASCARA MED STÄNGD MUN?
VAFÖR SER MAN ALDRIG RUBRIKEN "SPÅGUMMA VANN PÅ LOTTO"?
HUR KOMMER DET SIG ATT FÖR ATT STÄNGA AV WINDOWNS 98 MÅSTE MAN TRYCKA PÅ "START"?
VARFÖR FINNS DET INTE KATTMAT MED MUSSMAK?
NÄR HUNDMATEN ÄR "NY OCH FÖRBÄTTRAD SMAK" VEM ÄR DET DÅ SOM HAR SMAKAT?
DEN OKROSSBARA SVARTA LÅDAN SOM SITTER I FLYGPLAN? VARFÖR BYGGER DE INTE HELA PLANET I DET MATERIALET?
VARFÖR KRYMPER INTE FÅR NÄR DET REGNAR?
OM DET ÄR SÅ SÄKERT ATT FLYGA SOM DE SÄGER, VARFÖR KALLAS DÅ FLYGPLATSEN FÖR TERMINAL?
VARFÖR STERILISERAS SPRUTORNA INNAN DE ANVÄNDS, VID GIFTAVRÄTTNINGAR I USA?
OM DU FÄRDAS I LJUSETS HASTIGHET OCH SÄTTER PA DIN PANNLAMPA. VAD HÄNDER DÅ?
FINNS DET LEDMÄNNISKOR FÖR BLINDA HUNDAR?
VAD ÄR EN GRATIS GÅVA?
OM EN SCHIZOFREN PERSON HOTAR ATT TA LIVET AV SIG, RÄKNAS DET DÅ SOM EN GISSLAN SITUATION?
OM DU HAMNAR I EN LIVSKRIS SAMTIDIGT SOM DU LEKER KURRAGÖMMA, FÖRLORAR DU DÅ AUTOMATISKT EFTERSOM DU INTE KAN FINNA DIG SJÄLV?
VEM BOGSERAR BOGSERINGSBILEN NÄR DEN GÅR SÖNDER?
OM OLIVOLJA KOMMER FRÅN OLIVER, VARIFRÅN KOMMER DÅ BABYOLJA?
ETT ANNAT ORD FÖR SYNONYM?
VARFÖR KALLAS DET FÖR MISSIL? BORDE DET INTE HETA TRÄFFIL?
FLYTER VATTEN?
VART FÖRSVINNER DET VITA NÄR SNÖN SMÄLTER?
VARFÖR ÄR EN BOXNINGSRING FYRKANTIG?
VARFÖR ROPAR FOLK "SE UPP" NÄR NÅGONTING ÄR PÅ VÄG MOT EN. VILL DE ATT MAN SKALL FÅ DET I ANSIKTET?
VARFÖR FASTNAR INTE LIM PÅ INSIDAN AV FLASKAN?
OM MAN PLANTERAR FÅGELFRÖN, VÄXER DET DÅ...?
R.I.P. Michael Jackson!
