2 februari 2010
Aha... Skrev fel tidigare.. Det står inte "Inspr" utan "Insp".... Kan ju absolut betyda inspection... Tack
Hittade en guide:
1: With ignition off, press the trip reset button on the right under the odometer and hold.
2: Turn ignition on. Don't start engine. Release button.
You should now see "Service Oil" displayed.
3: Press button again. You should see "Service Insp", displayed.
By pressing the button once more it displays "Service Insp" again.
4: Now press and hold the button again with right hand whilst turning the other button "for adjusting the clock", to the right with the other hand.
The display should now change to Service ----.
5: Turn off ignition.
Your Service Inspection notice should now be reset.
If this is not the case then repeat 1-5 but hold the button down once "Service Oil" is displayed.
Senast redigerat av nosferatos (2 februari 2010)
200sx S13 -92
The devil is not as frightful as he is painted
