5011
1041 bakaxel olja
9 Inlägg
torsdag 15:14
Någon som vet vilken typ av olja det bör vara i en 1041 bakaxel? (slungdiff)
5 579 Inlägg
torsdag 23:18
Automatic Locking Differential Lubricants. [Note from Michael Asmussen, Torque Control Products Division of Eaton Corp.] We recommend the following lubrications for our 1041 automatic locking differentials:
1)Texaco 2276; Synthetic 75 W90; GM Part # 9986115
2)Texaco 9622; Mineral based 80W90; GM Part # 9985290
3)Texaco 2080; Synthetic 75W140 (heavy duty applications); GM part # 9985991
Note - All of the above lubes are preblended with friction modifier. No additional modifiers are necessary or recommended. As far as other lubes are concerned, any standard GL 5 lube will work, but the units perform optimally with the three listed above.
[Comment from Castrol:] Thank you for contacting Castrol regarding Syntec 75W-90 GL-5 gear oil in your Volvo 1041 differentials with an Eaton Automatic Lock. You may use SYNTEC gear oil with full confidence.
[Comment from Mobil:] Mobil 1 Synthetic Gear Lubricant meets the GL-3, GL-4 and GL-5 API ratings. If the manufacturer requires the use of a GL-4 rated lubricant ONLY, then you should not use Mobil 1 Synthetic Gear Lubricant.
https://www.volvoforums.org.uk/showthread.php?t=17782
Standard API GL-5
Dvs bara vanlig bakaxelolja.
