10 juli 2009
RMS INPUT POWER W 750 + 750
MAX INPUT POWER W 1500 + 1500
RESONANCE FREQUENCY Hz 29
FREQUENCY RANGE Hz 20/300
NOMINAL IMPEDANCE 4 + 4
VOICE COIL RESISTANCE 3,4 + 3,4
VOICE COIL INDUCTANCE mH 5,90
SENSITIVITY dB 93
QMS - 5,39
QES - 0,59
QTS - 0,53
MMS g 315,00
VAS l 85,20
X MAX ± mm 20,00
SURROUND TYPE - FOAM
CONE TYPE - TREATED PAPER
VOICE COIL FORMER - ALUMINIUM
VOICE COIL DIAMETER Æ mm 99
SPEAKER DIAMETER Æ mm 392
BAFFLE HOLE Æ mm 353
MAX REAR DEPTH mm 193
MAGNET DIMENSION mm 220 X 40
WOOFER USING - BOX & FREE AIR
menar du de?
powered by stetsom
