Tribbe skrev:
Hej på sidan sid 67 i kapitel 11 i ägarmanualen kan man läsa detta.
HID headlight bulbs (
optional on certain
U.S. models)
High-intensity-discharge (HID) bulbs are used
for the low beams of the headlights. These HID
bulbs use an extremely high voltage. To avoid
the risk of an electric shock and resulting serious
injury, you should not attempt to replace
them. Neither should you attempt to replace the
high-beam bulbs, remove/refit the headlight assemblies,
or remove any headlight-assembly
components. For replacement of the headlight
bulbs (low-beam and high-beam), removal and
installation of the headlight assemblies, and removal
of headlight-assembly components,
contact your Saab dealer.
Ask your Saab dealer to check whether your vehicle
is equipped with HID headlights.
