3065
V70 2,4T rycker och går slött
320 Inlägg
18 september 2013
jag tagit nummer ifrån VIDA
107 Inlägg
18 september 2013
Okej klicka in skriv siffrorna igen till LMM.
Så VIDA säger att en Volvo v70 b5244t3 -01 2,4t ska ha de nummret ?
320 Inlägg
18 september 2013
23 : Fuel system 5CYL   Print  Back
  Fig. Description Qty. PS Part number
1 Lambda sond, front 1.00  8627750
  TURBO, V70 CH -2762, (8631670)
  TURBO, V70 CH 2763-, V70XC S60, -2001
  Lambda sond, front 1.00  8670276
  2002- TURBO
  Lambda sond, front 1.00  9497252
  -2002 W/O TURBO
  2003- B5244SG/SG2
  Lambda sond, front 1.00  8627599
  2003- W/O TURBO, EXC B5244SG/SG2, 2VVT
  Lambda sond, front 1.00  8658237
  2003- W/O TURBO, EXC B5244SG/SG2, VVT
  Lambda sond, rear 1.00  9186934
  -2001 TURBO
  Lambda sond, rear 1.00  8642230
  2002 TURBO
  2003- B5234TX
  2003-2004, B5204TX, B5244TX.
  Lambda sond, rear 1.00  8677894
  2003-2004, B5254TX
  Lambda sond, rear 1.00  30650109
  2005- B5244TX,, B5254TX, B5204T5.
  Lambda sond, rear 1.00  9497468
  -2001 W/O TURBO
  Lambda sond, rear 1.00  8627600
  2002 W/O TURBO
  Lambda sond, rear 1.00  30622243
  2003- BI-FUEL
  Lambda sond, rear 1.00  30622252
  2003-2004 W/O TURBO
  Lambda sond, rear 1.00  30650090
  2005- W/O TURBO
  Lambda sond, rear 1.00  30622251
  2003-2004 W/O TURBO
  Lambda sond, rear 1.00  30650089
  2005- W/O TURBO
2 Fresh air hose 1.00  8649258
  -2002 W/O TURBO
2b  Grommet 1.00  3507985
  2003- B5244SG/SG2
  Fresh air hose 1.00  30636180
  2003- W/O TURBO, EXC B5244SG/SG2, V70 FC1; CH -357586, V70 FC2; CH -357738, XC70 CH -126237, S60 CH -324013, REPL 1PCS 30636828-3, 1PCS 3524376-5, 2PCS 978172-5,, 1PCS 8653469-0.
  Fresh air hose 1.00  30636828
  W/O TURBO, V70 FC 1; CH 357587-, V70 FC 2; CH 357739-, XC70 CH 126238-, S60 CH 324014-
  Fresh air pipe 1.00  30680446
  -2007, TURBO, EXC S60R, V70R
  Fresh air pipe 1.00  30792627
  2008-, TURBO, EXC S60R, V70R
  Fresh air pipe 0.00
  Air filter V70R, S60R.
2a  Nipple 1.00  8653644
  TURBO
3 Mass air flow sensor 1.00  8670263   ....................................................här har du MAF (luftmassmätaren)
  -2001 TURBO, (9470640)
  Mass air flow sensor 1.00  8670398
  2002- TURBO, EXC B5254T4 B5244T4/T5
  Mass air flow sensor 1.00  8670114
  B5254T4, B5244T4/T5
  Mass air flow sensor 1.00  30713512
  W/O TURBO, (9202199)
4 Engine control unit 1.00
  Regulating system fuel supply V70, V70XC, XC70 5CYL W/O TURBO
  Regulating system fuel supply V70, V70XC, XC70 5CYL TURBO
  Regulating system fuel supply V70, V70XC, XC70 DSL
  Regulating system fuel supply S60 5CYL W/O TURBO
  Regulating system fuel supply S60 5CYL TURBO
  Regulating system fuel supply S60 DSL
5 Hose clamp 1.00  985760
6 Hose clamp 1.00  988014
  (983596)(9470247)
7 Six point socket screw 2.00  986063
8 Fuel pressure pipes with fittings 1.00
  Fuel pressure pipes with fittings 5CYL W/O TURBO
  Fuel pressure pipes with fittings 5CYL TURBO
9 Bracket 1.00  30731819
  AUTO.TRANS, B5254T4, 2006-
  Bracket 1.00  9469657
  AUTO.TRANS, EXC B5254T4, 2006-
  AUTO.TRANS, -2005
10 Clip 1.00  9454733
  AUTO.TRANS
11 Clip 1.00  9125845
  AUTO.TRANS
12 Clamp 2.00  952624
  W/O TURBO
13 Bracket 1.00  8670010
  EXC B5254T4, MAN.TRANS
  Bracket 1.00  30677176
  B5254T4, MAN.TRANS
14 Flange screw 1.00  982805
  EXC B5254T4
  Flange screw 2.00  982757
  B5254T4
15 Retainer 2.00  9470430
16 Strip clamp 2.00  983057
  W/O TURBO
17 Clamp 1.00  8692389
  B5254T4
18 Retainer 1.00  982615
  B5254T4
19 Clamp 1.00  987163
  B2554T2
20 Six point socket screw 1.00  986200
  B5254T2
21 Hose, by the meter 1.00  31257540
22 Hose clamp 2.00  978172
23 Ejector 1.00  30665561
  (8653469)
24 Heat shield 1.00  30637806
  W/O TURBO
Add to list    New parts list 1
Details    Comments
-2001 TURBO, , (9470640)
408 Inlägg
18 september 2013
albinberg skrev:
pompe90 skrev:
albinberg skrev:
Byte magnet ventilen = ingen skillnad!!!!
Sökte på Vida = magnetventien.
Bytte LMM = går gött som fan igen wink
Härligt! smile se till och hålla vakuumslangar fräscha och spjällhus rent så går den mer än toppen wink
Mycket jobb o riva isär spjällhuset ?
För att endast rengöra behöver man inte ta isär spjällhuset utan istället ha exempelvis brakeclean(Bräkleen -CRC)/biltemas bromsrengöring å spraya i spjällhuset samt putsa rent om man vill det.
Om man tar isär spjällhuset behöver du packning vid ihopsättningen vilket gör att man inte orkar ta isär allt.
För mig funkar det klockrent att bara ta isär slangarna så man ser spjället å spreja och putsa tills det är rent och fint.
- Nuvarande:
- Sålda:Peugeot 208 GTi LE -13,Peugeot 205 GTi -92 flyttgods - Pug 205 CTi-89, Peugeot 206 GTi-99,Toyota MR2 Turbo-91,Volvo V70 AWD -98 mfl.
www.peugeot-sport-club.se
One Man Clan
4 287 Inlägg
18 september 2013
Ni jämnför volvo nr 86xxxx vs bosch nr 0280xxxxxxx, klar som faen de felar då ! big_smile
107 Inlägg
18 september 2013
Va nu fattar jag inte ??
107 Inlägg
18 september 2013
Behöver ju veta Bosch nummret smile
107 Inlägg
18 september 2013
Så volvos nummer är = med ett annat bosch nummer ??
Förklra gärna utförligt!!! RLP518 är min regg skylt om ni ska kolla upp!!
320 Inlägg
18 september 2013
när du beställer hos nån återförsäljare , de går efter volvos nummer inget annat. så omvandlar de till det mostvarigheten
320 Inlägg
18 september 2013
men som sagt gå in på givarspecialisten.se så får du för 800:- inom 4 dagar
107 Inlägg
19 september 2013
Kommer din därifrån ?
Hört att eftermarknds kan hacka och dumma sig.. ?!
408 Inlägg
19 september 2013
Vet ej hur det är med tredje parts hos specialister, oftast ska det funka. Biltema funkar EJ ex vis men dom är ju ingen specialist wink
Kolla med http://www.atech2.com/
Dom är grymma när det kommer till spjällhus/givare utav olika slag, billigare än nya och behöver till 98% inte programmera in det renoverade spjällhuset eller vad man behöver byta.
Vet att detta gäller LMM, där ska det nog inte vara några problem. Men jag vet ej priser eller så då du får maila och kolla om dom fixar sådant fortfarande smile
Senast redigerat av pompe90 (19 september 2013)
- Nuvarande:
One Man Clan
4 287 Inlägg
19 september 2013
Ja nån skriver att dom ska ha 86xxxx Nr på lmm men de är bara beställningsnr!.
Nån annan skriver att de ska vara 0280 xxxxxx å de är boschs egna nr.
Dvs ni jiddrar säkert om precis samma sak men volvos egna artikelnr vs bosch egna artikelnr.
107 Inlägg
20 september 2013
Volvonummret som slutade på 263 stämde, MEN bosch nummret som motsvarade vart 0 218280108 typ smile
107 Inlägg
20 september 2013
Monterad Laddtryckmätare i dag för o se hur turbon jobbar. Fick Nöstan exakt samma som denna killen helt CP.....http://www.jagrullar.se/forum/viewtopic.php?f=16&t=74778
Tomgång ska bilen ha undertryck ? min står på 0
Vid gas så går den till 0,1 och när jag släpper gasen så får jag fram va den egentilgen laddar 0,4-0,5.
Kopplade in mig via ett T kors mellan magnet ventil till inlopps röret. ( mellan LMM och turbo )
Vad fan kan detta vara ????
A.Sörman
1 299 Inlägg
20 september 2013
Ja har du kopplat på den korta slangen från luftröret till magnetventil har du problemet där big_smile
107 Inlägg
20 september 2013
Det har jag med big_smile
A.Sörman
1 299 Inlägg
20 september 2013
Du har en slang som går från insuget skarva med t-kors 3cm från insuget koppla på laddtrycksmätaren där ska du se att undertryck å laddtryck stämmer bättre smile Koppla inte vid luftburk eller magnetventil då spökar laddet direkt
Här är en bild Lånad av Tobzter
blå slangen är den han har kopplat på
https://www1.garaget.org/gallery/images/17/16508/16508-262d792867db959360b4e9bbda8acfcd.jpg
Senast redigerat av Drunk (20 september 2013)
107 Inlägg
20 september 2013
http://www1.garaget.org/gallery/images/17/16508/16508-262d792867db959360b4e9bbda8acfcd.jpg
Då ska jag med prova det big_smile
107 Inlägg
20 september 2013
HAHAH sitter och funderar, fan vad dum i huvudet jag är!!!!!
Finns ju fan inget undertryck där. och jag får ju värdena när turbon släpper trycket när den '' luftdumpar'' fan vad kass jag är!!
