6190
är motorn i en bmw 535 en 24 ventilare?
106 Inlägg
11 juli 2007
som rubriken lyder...
Kungen i Lerbäckshult
718 Inlägg
11 juli 2007
Ja
106 Inlägg
11 juli 2007
ok... tack för svaret big_smile
10 287 Inlägg
12 juli 2007
Vi citerar Wiki:
The big six motor found in the 533i and 535i/is models is known as the "M30". The M30 is also a 12 valve SOHC inline six cylinder design. It has seven main bearings, four camshaft bearings and a rocker arm type valvetrain. US M30's also came equipped with cast aluminum acoustically tuned common plenum intake manifolds and single throttle bodies. Unlike the M20 it has a chain-driven valvetrain. Its larger dimensions allow for a longer stroke and larger bore, which makes for almost 3.5 L displacement in later motors.
http://en.wikipedia.org/wiki/BMW_E28
/Göran
(Groucho Marx).
Teddan
2 495 Inlägg
12 juli 2007
535 e28 och e34 har 12v... alltså som tidigare talare sa M30 motor.
www.byebyepolizei.se, för dig som gillar snabba bilar
106 Inlägg
12 juli 2007
tack för infon... big_smile
