Sök och du skall finna!
en snabb koll på google gav detta resultat:
Specifications for Jensen Amp Model No. XA6040LX
6 CH: 4 x 75 Watts RMS (4 ohms) [4 x 150 Watts peak] +2 x 150 Watts RMS Bridged (4 ohms) [2 x 300 Watts peak]
5 CH: 4 x 75 Watts RMS (4ohms) [4 x 150 Watts peak] + Bridged 150 Watts RMS (4 ohms) [300 Watts peak]
4 CH: 4 x 75 Watts RMS (4 ohms) [4 x 150 Watts peak] 4 x 100 Watts RMS (2 ohms) [4 x 200 Watts peak]
3 CH: 2 x 75 Watts RMS (4 ohms) [2 x 150 Watts peak] Bridged 150 Watts RMS (4 ohms) [300 Watts peak]
2 CH: Bridged 2 x 150 WattsRMS (4 ohms) [600 Watts peak] 4 ohm
Power Rating@<00.05% THD
4-channel design bridgeble to 6-channel
Switchable low pass crossovers for driving subwoofers @ 100Hz reduce distortion and extend speaker life
MOSFET power supply for cooler, more stable operation
2 ohm stable operation for maximum efficiency
Bass Boost +6db @ 45Hz; Circuit and thermal overload protection prevents amp failure
Variable input sensitivity for perfect match with car stereo
Floating ground inputs
Gold-plated low level inputs and screw terminal connections for: power, ground, sensing and speaker outputs
Discrete bi-polar output transistors for maximum efficiency
Remote on/off sensor turns amp on and off with car stereo
Power LED indicator
State-of-the-art heat sink for efficient power dissipation
Soft turn-on circuit
Cool Diamond-Plate finish
davzan skrev:
hej jag söker lite fakta om ett steg med namnet Jensen XA 6040Lx någon som vet något om detta
