här är info om steget!
men jag är totalt kass på utrikiska så läs själv..
Exonic Class D Monoblock Car Amplifier
RMS Power Rating:
4 ohms: 800 watts x 1 chan.
2 ohms: 1200 watts x 1 chan.
1 ohm: 1500 watts x 1 chan.
Max power output: 3000 watts
MOSFET power supply
Bass Remote Details (Wired remote bass level control included)
LED power and protect indicators
Bass Boost (0-18 dB bass boost at 45Hz)
Mono channel operation
Preamp RCA outputs
3-Way system protection circuitry (thermal, short and overload)
Daisy chain capable
Heavy duty aluminum alloy heatsink
Gold-plated RCA level inputs
Molded bare wire set screw terminals
Variable low-pass filter (30-250 Hz, 24 dB/octave)
Subsonic filter (24 dB at 10-50 Hz)
Frequency response: 10-400 Hz
Damping factor: 300
Dimensions: 14-1/4"L x 12-1/4"W x 2-1/2"H
1/0-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
90 Day Repair Only Warranty
