AutoStudio REFERENCE1500.1
Effekt (RMS): 1 x 700 watt (4 ohm) 1 x 1100 W (2 ohm) 1 x 1500 W (1 ohm) Fas (0 ° - 180 °) Bass Boost (0 - 12 dB) Sub Sonic (15 - 50 Hz) Lågpassfilter (30 - 300 Hz)
![http://www.ullareddigital.se/pub_images/original/reference-1500-2_005_4501.jpg]()
![https://www1.garaget.org/gallery/images/55/54849/54849-45e6e8ccf3c1b4b240107d52dd4da657.jpg]()
Genesis Dualmono
Features:
Power Source [Volts] 10.8 ~ 14.4
Number of Channels 2
Rated Power @ 14.4v [4 Ohm] 2 x 100
Watts RMS @ 0.1% - Rated [2 Ohm] 2 x 200
All Channels Driven - Rated [Bridge 4 Ohm] 1 x 400
Typical Power @ 14.4v [4 Ohm] 2 x 150
Watts RMS @ 0.1% - Typical [2 Ohm] 2 x 250
All Channels Driven - Typical [Bridge 4 Ohm] 1 x 500
Maximum Current Draw 58 Amps
Signal to Noise Ratio 'A' Wtd [4 Ohm]>100dB
THD + Noise @ Rated Output 0.1%
Input Sensitivity [Volts RMS] 0.3 ~ 5
Frequency Response 20 Hz ~ 20 KHz
Dimensions H x W x D [mm] 62 x 300 x 210
Weight [Kg] 4.1
![http://a1.trd.cm/thaisecondhand/201107/312/9894682_3.jpg]()
![https://www1.garaget.org/gallery/images/55/54849/54849-43dfb5d85184ae7d7d0c353d02ee4ec9.jpg]()
