Kimberlycfc skrev:
P1355, P1358, P1361, P1364, P1479, P0300, P0304.
Vet inte ang service. Köpte den i Sept.
Då började ABS systemet lysa, någon givare bak, lämnade in 3 ggr, problemet fortsatte. 4e gången fixade dom problemet, men skrapade hela sidan på bilen ist. Så då skulle jag lämna in den på lackning. Som kompensation lovade han att bjuda på en service, men jag ser ju att det gamla biltema oljefiltret etc fortfarande sitter kvar, så han sket ju i det han
P1355
(1), P1358
(2), P1361
(3), P1364
(4);
Cylinder
(X) Ignition Circuit: Open Circuit
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Misfire
No Spark
Possible CausesFaulty Ignition coil(s) with output stage
Fuse(s) faulty
Wiring and/or Connector(s) from coil(s) to ECM faulty
Possible SolutionsCheck/Replace Coil(s)
Check Fuse(s)
Check Wiring and/or Connector(s)
17887/ P1479/005241 - Brake Boost Vacuum System: Mechanical Failure
Possible CausesFuse(s) faulty
if the blade wheel (rotor) in the vacuum pump is stuck, most probably a fuse will burn
Hoses from/to Brake Boost Vacuum Pump faulty
Possible SolutionsCheck / replace fuses
check if the blade wheel (rotor) of the vacuum pump is stuck, otherwise the fuse will burn again
Check Hoses from/to Brake Boost Vacuum Pump
Check Brake Boost Vacuum Pump
check if blade wheel (rotor) is stuck
Perform Output Test
Perform Short Trip in Basic Settings. Group 008 is commonly the self test for this system and may be activated Key On, Engine Off. If needed activate basic settings using [On/Off/Next] and pump the brake pedal.
Special NotesWhen this fault is stored in conjunction with misfire and system lean fault codes check the PCV system and any other possible sources of engine mechanical vacuum leaks. Although PCV failure is most common on the 1.8T engines equipped with the auxiliary vacuum pump, any engine with low vacuum can cause that electric pump to run excessively - resulting in this fault code.
16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
Possible CausesAir Intake System leaking
Fuel Supply faulty
Injector(s) faulty
Ignition Cable(s) and/or Spark Plug(s) faulty
Ignition Coil(s) faulty
Exhaust Gas Recirculation (EGR) Valve (N18) stuck/open
Camshaft Position Sensor (G40) faulty
Possible SolutionsCheck Misfire Recognition
Check Air Intake System
Check Fuel Supply
Check Injector(s) and Injector Sealing
Check Ignition Cable(s) and Spark Plug(s)
Check Ignition Coil(s)
Check Exhaust Gas Recirculation (EGR) Valve (N18)
Check Camshaft Position Sensor (G40)
Special NotesThis DTC indicates that one or multiple cylinders are misfiring, but the ECU fails to identify the cylinder.
16688/P0304/000772 - Cylinder 4 Misfire Detected
Possible CausesIgnition system
Fuel injectors
Fuel pressure
Running out of fuel
EVAP canister purge valve
Evaporative emission system
Low compression
Base engine problems
Controle Module damaged
Special NotesThis feature search for engine misfire in a specific cylinder. Most of the time the cause for a misfire is a lack of combustion in a cylinder due to absence of spark, poor fuel metering, or poor compression.
Kan även, vilket jag vet av egen erfarenhet vet, vara så enkelt som bromsljuskontakten.
