det är annan slaglängd, 77mm vs 90mm.
B5204T3
The B5204T3[79] is a 2.0 L (1,984 cc) straight-five. Bore is 81 mm (3.2 in) and stroke is 77 mm (3.0 in) with a compression ratio of 8.4:1. It is turbocharged and intercooled with a power output of 225 PS (165 kW; 222 hp) at 5700 rpm and 310 N⋅m (229 lb⋅ft) of torque at 2700–5100 rpm. It is equipped with Bosch Motronic 4.4 engine management for model years 1997 and 1998. It is equipped with Bosch ME7 for model years 1999 and 2000. It was only offered in Italy,[78] Portugal,[78] and Taiwan,[78] due to high taxes on cars with more than 2000 cc engine capacity.
B5234T3
The B5234T3[72] is a 2.3 L (2,319 cc) straight-five. Bore is 81 mm (3.2 in) and stroke is 90 mm (3.5 in) with a compression ratio of 8.5:1. It is turbocharged and intercooled with a power output of 240 PS (176 kW; 236 hp) at 5100 rpm and 330 N⋅m (240 lb⋅ft) of torque at 2400–5100 rpm. Model years 1997 and 1998 are equipped with Bosch Motronic 4.4 engine management, model years 1999 and up are equipped with Bosch ME7 engine management. Also added for the 1999 model year was variable valve timing for the exhaust cam. For model year 2001 and up power output was increased to 250 PS (184 kW; 247 hp) at 5200 rpm with 330 N⋅m (240 lb⋅ft) of torque at 2400–5200 rpm.
tagit ifrån https://en.wikipedia.org/wiki/Volvo_Modular_engine
Mvh Christian
