Fick fram dessa felkoder och när jag nollställt dessa och provar starta så kommer dom tillbaka. Kamaxelgivare är nog de som gör att den inte går. Har bytt givare till två olika. Måste kolla kablaget en tredje gång. Kan triggern på kamaxeln gå ur läge? Läst nånstans att dessa är pressade dit?
Car Scanner ELM OBD2
DTC report
Selected brand: Volvo
VIN: YV1BW714081004277
============1==============
P0725
Raw code: 0725
ECU: Transmission control unit
Status: Confirmed
OBDII: Engine RPM input - circuit malfunction
============2==============
P1719
Raw code: 1719
Status: Confirmed
============3==============
P0201
Raw code: 0201
ECU: Engine control unit
Status: Pending
OBDII: Injector 1 - circuit malfunction
============4==============
P0672
Raw code: 0672
Status: Pending
OBDII: Glow plug, cylinder 2 - circuit malfunction
============5==============
P0341
Raw code: 0341
Status: Pending
OBDII: Camshaft position (CMP) sensor A, bank 1 - range/performance problem
============6==============
P2452(02)
Raw code: 245202
Status: Test failed, Test failed (current drive cycle), Confirmed, Test failed since last DTC clear
OBDII: Diesel particulate filter (DPF) pressure sensor A - circuit malfunction
============7==============
P0700(00)
Raw code: 070000
Status: Test failed, Test failed (current drive cycle), Confirmed, Test failed since last DTC clear, Warning indicator requested
OBDII: Transmission control system, MIL request - circuit malfunction
============8==============
P0340(00)
Raw code: 034000
Status: Test failed, Pending, Test failed since last DTC clear
OBDII: Camshaft position (CMP) sensor A, bank 1 - circuit malfunction
============9==============
P0341(00)
Raw code: 034100
============10==============
P0672(00)
Raw code: 067200
Status: Test failed, Test failed (current drive cycle), Pending, Test failed since last DTC clear
============11==============
P0201(00)
Raw code: 020100
============12==============
P2452(02)
Raw code: 245202
============13==============
P0340(00)
Raw code: 034000
============14==============
P0341(00)
Raw code: 034100
============15==============
P0700(00)
Raw code: 070000
============16==============
P0672(00)
Raw code: 067200
============17==============
P0201(00)
Raw code: 020100
============18==============
B1C82(14)
Raw code: 9C8214
ECU: CEM
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
