http://wiki.ross-tech.com/wiki/index.php/0028700287 - ABS Wheel Speed Sensor Rear Right (G44): Signal Outside Specifications
00287 - ABS Wheel Speed Sensor Rear Right (G44): Electrical Fault in Circuit
Possible Causes
Open Circuit in Wiring from/to ABS Wheel Speed Sensor Rear Right (G44)
ABS Wheel Speed Sensor Rear Right (G44) faulty
Possible Solutions
Check Wiring from/to ABS Wheel Speed Sensor Rear Right (G44)
Check ABS Wheel Speed Sensor Rear Right (G44)
00287 - ABS Wheel Speed Sensor Rear Right (G44): Mechanical Malfunction
Possible Causes
Excessive Air Gap between ABS Wheel Speed Sensor Rear Right (G44) and Rotor
Short Circuit in Wiring from/to ABS Wheel Speed Sensor Rear Right (G44)
Possible Solutions
Check ABS Wheel Speed Sensor Rear Right (G44) Installation
