sök efter ett altec lansing ada 995 tror jag de heter slår nog z-5500.... finns tyvärr inte attköpa nytt men beggat finns för typ 1000 kr vääääldigt bra ljud slog till och med mitt hemma bio ljud så jävla klrt ljud..
The ADA995 is a THX Certified, high power Altec Lansing multimedia speaker system designed specifically for superior audio performance and seamless integration to your 5.1 computer sound system. The ADA995 Multimedia Speaker System consists of six interconnected speaker components, five speakers and a subwoofer.
Specifications:
Manufacturer: Altec Lansing Technologies, Inc.
Model: ADA995.
System Frequency Response: 38 Hz to 20 kHz.
System Acoustic Output: > 105 dB SPL at 28 inches.
System Signal-to-Noise (S/N) Ratio: > 75 dB A-weighted.
Total Amplifier Power Rating: > 200 watts continuous average power (all speakers operating) at < 1% (THD+N), 63 Hz and 1 kHz (per EIA Standard RS-490).
Input Sensitivity for Rated Output: 200 mV rms.
Input Impedance (any line input): > 10 kΩ
Maximum Input Signal Voltage: 2 V rms.
Input Cables: Attached, color coded 3.5 mm stereo plugs.
Power Requirements: 120 Vac ±10%, 60 Hz ±3 Hz, 400 Watts.
Power Cord Length: 2 m (6 ft).
Operating Temperature Range: 0 oC to 50 oC.
Humidity, Non-condensing: 95% RH @ 50 oC.
Front, Rear, & Center Satellite Speaker Specifications:
Configuration: 2-way, one woofer and one tweeter, magnetically shielded.
Woofer Size: 76.2 mm (3") full range driver.
Woofer Impedance: 8 Ω.
Tweeter Size: 32 mm (1.25").
Frequency Response: 150 Hz to 20 kHz.
Output Power per Channel: > 21 watts continuous average power @ < 1% (THD+N), each front and rear channel.
> 23 watts continuous average power @ <1% (THD+N), center channel.
Dimensions: 51.2 cu in inside volume.
Color: Dell Midnight Gray with Dell Ion accents.
Speaker cables:
Length: 3m (10 ft), Front and center speakers
5m (16 ft), Rear speakers.
Connectors: RCA phono connectors, color-coded and mechanically keyed.
Subwoofer Specifications:
Number of speakers: Two (2).
Woofer Size: (170) mm (6.5") long throw driver.
Enclosure type: Ported, rigid wood construction.
Frequency Response: 38 Hz to 150 Hz.
Output Power: > 94 watts continuous average power @ < 1% (THD+N).
Dimensions: 17.7x8.2x17.3 (450x209.5x440 mm) outside dimensions.
Color: Midnight Gray.
Package Contents:
1 - Subwoofer.
4 - Satellite speakers.
1 - Center speaker (horizontal stand NOT included).
User's Guide may or may not be included (please see links for on-line guides).
såldes med dell datorer förr
http://support.dell.com/support/edocs/acc/ada995/
Specifications:
Model: ADA995.
Speaker cables:
Package Contents:
1 - Subwoofer.
Senast redigerat av christofer_k (23 september 2008)
0
0
0
0
