k1mm0 skrev:
Model: 4K2 D
RMS Power @ 13.8V Mono 2 Ohms: 5500 Watts
/ <0,9% THD Mono 4 Ohms: 3200 Watts
RMS Power @ 12.6V Mono 2 Ohms: 4200 Watts
/ <0,9% THD Mono 4 Ohms: 2800 Watts
Number of Channels: 1
Minimum input sensitivity: 0,2V
Total Harmonic Distortion: < 0,9 % THD
Signal to Noise: > 90 dB
Crossover Frequency LOW PASS: 50 to 15 KHz
Frequency Response: (FULL RANGE) 20 Hz to 15 KHz (-3dB)
Power Tension: 9 to 15V
Consumption with musical signal: 6 to 240 A
Consumption with BASS signal: 6 to 470 A
Dimensions (H X W X L): 70 x 280 x 350 mm
Weight: 5 Kg.
