CrackzY skrev:
fick hem ett annat verktyg nu och fick fel koderna
00515: camshaft position sensor (half effect sensor)-no signal (G4):check CMP, if OK replace distributor
16487: mass or voltm air flow circuit-low input
17967: fanns inget i manualen men enligt google så står det Throttle Valve Control.
någon som vet vilket man bör testa o byta ut först o se vilket funkar bäst ?
00515 - Camshaft Position (Hall) Sensor (G40): No SignalPossible CausesWiring to Camshaft Position (Hall) Sensor (G40) faulty
Possible SolutionsCheck Wiring to Camshaft Position (Hall) Sensor (G40)
Check/Replace Camshaft Position (Hall) Sensor (G40)
Check/Replace Engine Control Module
Special NotesSome older engines store this code as long as the engine is not running, if in doubt read fault codes with the engine running again.
16487/P0103/000259 - Mass Air Flow (MAF) (G70): Signal too HighPossible SymptomsProbably no serious malfunctions
Loss of power
Possible CausesWiring and/or connections (short circuit?)
Mass Air Flow (MAF) (G70) defective
Possible SolutionsCheck wiring and connections
Check / Replace Mass Air Flow (MAF) (G70)
Special NotesIn MY 1995-2002 (?) in Europe at VW-diesel-cars G70 had the bad reputation of slowly losing his performance, causing loss of power. It's not a matter of defective or breaking down, but it is filthy / dirty (not easy to clean). You can check functionality by making a log in [01-engine], [meas.blocks-08], group 003 (3e gear, full throttle, from 1700-4000rpm)
17967/P1559/005465 - Throttle Body (J338): Fault in Basic SettingsPossible SymptomsNot known
Possible CausesIdle Switch Open or Open Circuit
Throttle Valve sticks and won't close
Speed Impuls from Engine Speed Sensor (G28) recognized
Possible SolutionsPerform Throttle Body Adaptation
Så uppenbarligen; Sista skulle jag börja med och göra en TBA
(Tror spontant fortfarande det är portemuleringsfel med din kabel, men skit samma
