2954
Sänkningssatser (80/75, 80/80) BMW E30
BMW Power
2 362 Inlägg
18 juli 2007
Meeen varför ska allt vara så krångligt.. den där sidan med jamex satserna så hittar jag 80 sats, men sen när man ska gå in på "mer information" så står det:
Notes
1 Version with cylindrical front springs
2 Version with conical front springs (last spring winding turned inwards)
3 Only to be installed with sports shock absorbers with shortened piston rod
4 Measure outer front spring seat: 45mm or 51mm
5 Sportsline does not fit on 325iX model types
6 M-Tech (inc. M3) will lower approx 20mm less than the specified lowering
7 Use Sportsline only for model types from 6.92 and later
8 Left and Right shock absorbers are different
9 Use Sportsline only for model types from 8.90 and later Touring model type only from 8.91 and later
10 Includes metal blocks to lower the original leaf spring and installation instructions
11 Use Sportsline 140143 for model types 1.2 and 1.4 models with chassis codes up to No.9210
12 With the exception of models with height adjustment
13 Sports version will be lowered approx. 30mm less than indicated
14 Golf I and Scirocco I produced before 9.79: use the upper springseat of a Golf or Scirocco produced 9.79 or later, or those of the Golf II (front struts only)
15 Polo I produced before 9.79: use the upper springseats of a Polo II produced 9.79 or later (front struts only)
16 Not applicable
17 Not applicable
18 Rear shock absorber with eye mounting below
19 Rear shock absorber with fork mounting below
20 Not applicable
21 Lower SDi 40mm maximum
22 Kit will not fit when original part number of shock absorber is either 770 786 597 or 7700 807 873
Fattar fan inget.. orkar inte läsa ordentligt heller, för har ont i huvudet.. varför ska det vara så krånligt? "lower SDi 40mm maximum" liksom vadå?!!? tongue haha:P
Finns det ingen svensk återförsäljare som fixar Jamex grejer? tongue
BMW, bogsering med wire :/
Fordonstekniker
1 740 Inlägg
18 juli 2007
http://www.power-tuning.fr/en/road_tuni … 86351.html
Samma som blocket annonsen. GT Cupline. 80mm
Senast redigerat av darkwizard (18 juli 2007)
BMW Power
2 362 Inlägg
18 juli 2007
Stämmer bra det, hitta ett annat företag med som säljer dom.. men om jag inte ser fel där så sänker just den där 40/80 wink
BMW Power
2 362 Inlägg
18 juli 2007
Jätte tack för alla som har hjälpt än så länge!
Men helst vill man ju hitta en svensk återförsäljare eller någom som säljer "beggat" nytt på blocket t.ex.
820 Inlägg
18 juli 2007
Notes
16 Not applicable
17 Not applicable
20 Not applicable
Du får läsa i tabellen på just den modellen du vill ha och läsa på "note" där det står typ, 4 5 6 eller något liknande, och då läser du helt enkelt kommentarerna 4,5 och 6 smile tror jag...
BMW Power
2 362 Inlägg
18 juli 2007
aha, nu fattar jag wink
tack wh0re!
Gödseldräng
4 529 Inlägg
19 juli 2007
vad är det för tum på fälgarna du ska ha ??
provade ett par 16 tum på min och har 40 - 40 runt om och den blev jävligt låg med det
ca 8cm var den i fronten
dock så ska dom väck tongue så jävla hårt att köra på grusväg med sänkning tongue
kolla på autopower om det finns där på köp och sälj smile
BMW Power
2 362 Inlägg
19 juli 2007
Jag har redan ett par fälgar..
Brock B1 16"x9" breda.. 215/40/16 på dom..
Och nej finns inget på Autopower, surfar där varje dag.
80/80 eller 80/75 kit letas för fullt! om någon vet vart man kan köpa från svensk återförsäljare får gärna skriva... eller om någon vet vilka som är återförsäljare åt Jamex!
820 Inlägg
19 juli 2007
Jag har beställt Jamex fjädrar till min bil från gbkperformance.co.uk Men jag har inte fått dom än... och jag tror bara dom säljer fjädrar tyvärr och inget kit...
BMW Power
2 362 Inlägg
19 juli 2007
Men ändå sätter dom ut bild på stötdämpare med? så det skulle väl vara lite dumt? sälja sänkningsfjädrar men inte stötdämpare till dom så att man kan få på skiten? tongue
283 Inlägg
1 april 2010
jag lånar tråden! jag har en satsa FK 60/40 men skulle vilja ha 60mm bak av märket FK. någon som vet var jag hittar detta?
BMW Power
2 362 Inlägg
1 april 2010
Hehe oj vilken gammal tråd av mig big_smile lite roligt och läsa.. för min del blir det fullt millway chassi istället wink budgetchassi körde man på när man var yngre big_smile
1 353 Inlägg
1 april 2010
http://cgi.ebay.de/TC-Tech-Sportfahrwer … 27b0044dba
finns flera sidor med grejer på ebay.de smile
141 euro för en sats med 80/75 mm.-
haha, jag skrev innnan jag läste hur gammal tråd det var tongue
Senast redigerat av Batta (1 april 2010)
There's no replacement for displacement
283 Inlägg
1 april 2010
den kanske är gammal men det gör väl inget! jag hittar bara FK fjädrar som sänker 50mm bak. ingen som vet FK som sänker 60mm bak?
BMW Power
2 362 Inlägg
2 april 2010
Annars så kan du föja "Batta"s tips..
Jag hittade ett 80/75 kit som jag körde med efter den här tråden gjordes.. funkade fint tills jag ville börja bygga värre..
Tror det hette något med GT Cupline eller nåt sånt.. HKmotorsport tror jag mina saker kommer ifrån.. om det nu finns kvar dvs..
283 Inlägg
2 april 2010
får kolla upp det! nu när man får i tyngre motor och lättar bilen så blir höjden lite fel ^^
BMW Power
2 362 Inlägg
2 april 2010
Hehe ja kan ju bli så..
Kolla på min röda innan den revs ner igen.. finns massa bilder på den hur "hög" den var med 80/75 sänkning.. m20b25 maskin satt i den, full inredning osv osv..
283 Inlägg
4 april 2010
ingen som vet var jag hittar 60/60 sänkning?
