Tuesday,22,February,2022,14:04:57:04918
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64)
Data version: 20210903 DS330.0
www.Ross-Tech.comVIN: WAUZZZ8F4AN004077 License Plate:
Chassis Type: 8F-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 26 2E 42 46 47 52 53 55 56
62 69 72 77
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
26-Auto Roof -- Status: Malfunction 0010
2E-Media Player 3 -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CCWA) Labels:| 059-907-401-V1.clb
Part No SW: 8R0 907 401 J HW: 8K1 907 401 A
Component: 3.0TDI EDC17 H01 0008
Revision: 15H01--- CVN: 95CBEA3B
Coding: 011C002C240F0920
Shop #: WSC 80093 222 69422
ASAM Dataset: EV_ECM30TDI0118R0907401J 001008
ROD: EV_ECM30TDI0118R0907401J.rod
VCID: 39416FF6B84AA44146-806C
VINID: 9D196AAAA2161117800040071C84D690DA
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8K0 927 156 B HW: 0B5 927 156 D
Component: 0B5 30 TDIRdW H02 0009
Revision: --H02--- Serial number: 0000000018 CVN: 00005C5C
Coding: 000001
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_TCMDL501 A02044
ROD: EV_TCMDL501.rod
VCID: 335D5DDE9A265E118C-8066
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AJ HW: 8K0 907 379 AJ
Component: ESP8 quattro H04 0040
Revision: -------- Serial number: --------------
Coding: 1C8D00
VCID: 0131C716981A3C814E-8054
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 BQ HW: 8K0 907 064 BQ
Component: BCM2 1.1 H90 0247
Revision: 00002001
Coding: 05030F
Shop #: WSC 02399 823 56573
VCID: 0037C2129310358941-8054
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000013353018
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H36 0042
Serial number: 0209000022163001
5 Faults Found:
00183 - Interior Access/Start Authorization Antenna 1 (R138)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 135696 km
Time Indication: 0
Date: 2021.11.25
Time: 11:01:24
00182 - Luggage Compartment Access/Start Authorization Antenna (R137)
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 135696 km
Time Indication: 0
Date: 2021.11.25
Time: 11:01:24
03283 - Antenna for Access & Start Authorization; Left
011 - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 135696 km
Time Indication: 0
Date: 2021.11.25
Time: 11:01:24
03287 - Sensors for Contact with Door Handles
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 135697 km
Time Indication: 0
Date: 2008.05.29
Time: 05:10:08
00955 - Key 1
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 117
Mileage: 135713 km
Time Indication: 0
Date: 2008.06.17
Time: 03:07:37
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AA HW: 8T1 820 043 AA
Component: KLIMA 1 ZONE H06 0150
Revision: A1000000 Serial number: 01140420090286
Coding: 36030000
Shop #: WSC 02391 823 56573
VCID: 70D792D2A3B02509B1-8024
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 77
Mileage: 135712 km
Time Indication: 0
Date: 2008.05.27
Time: 00:18:11
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 J HW: 8K0 907 063 D
Component: BCM1 1.0 H26 0372
Revision: 05026001 Serial number: 00000000355255
Coding: 2600D691403400010009000300005D5D0F1C438800010001000000
VCID: 365B64CA81544B39AB-8062
Subsystem 1 - Part No SW: 8F1 955 119 HW: 8K1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 250309 H06 0021
Serial number: SWF09030255496
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 T HW: 8K0 941 531 T
Component: E1 - LDS H07 0090
Serial number: 00000000000304090190
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 F HW: 8K0 919 475
Component: PARKHILFE 4K H06 0040
Revision: 11001001 Serial number: 40140909619319
Coding: 000101
VCID: 3C4F76E2BF7891695D-8068
Address 15: Airbags (J234) Labels:| 8F0-959-655.clb
Part No SW: 8F0 959 655 HW: 8F0 959 655
Component: AirbagVW-AU10 H08 0430
Serial number: 003A4D040S9S
Coding: 30333635353130303030554A304C38463053
ASAM Dataset: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaAU10SMEAU485.rod
VCID: 75D9A3C6D4D2002162-8020
Crash sensor for side airbag: driver side:
Serial number: 6334MSME47126729B
Front Passenger's Side Airbag Crash Sensor:
Serial number: 6344MSME46535716B
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 6352QSME572023242
Passenger side rear thorax airbag crash sensor:
Serial number: 6362QSME3E20182CK
Crash sensor for front airbag: driver side:
Serial number: 63732SME5D233C30/
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME59203B0A/
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304ID7000JP
Coding: 000016
VCID: 3D497BE6A46298616A-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8T0 920 931 A HW: 8T0 920 931 A
Component: KOMBIINSTR. H32 0224
Revision: 00200000 Serial number: 9D525F249
Coding: 0F07190003000008000000
VCID: 355963C69C524021A2-8060
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 M HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0095
Revision: GB300043 Serial number: 4300G093318327
Coding: 000303
VCID: 4BAD253EEAD626D1E4-801E
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0160
Serial number: 19072FFC250309
2 Faults Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 4
Reset counter: 117
Mileage: 135696 km
Time Indication: 0
Date: 2021.11.25
Time: 13:07:00
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 4
Reset counter: 117
Mileage: 135696 km
Time Indication: 0
Date: 2021.11.25
Time: 17:07:00
Address 26: Auto Roof (J256) Labels:* 8F0-959-255.clb
Part No SW: 8F0 959 255 HW: 8F0 959 255
Component: VSG-AUDI-B8 H09 0160
Coding: 010000
ASAM Dataset: EV_ElectRoofContr 001007
ROD: EV_ElectRoofContr.rod
VCID: 71D197D6A0BA2C01BE-8024
1 Fault Found:
0004 - Switch for Convertible Top
B11A0 02 [009] - Signal Failure
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 77
Mileage: 135712 km
Date: 2008.05.27
Time: 00:46:31
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8T0 035 785 HW: 8T0 035 785
Component: SG ext.Player H08 0210
Revision: 00000000
Coding: 020202
VCID: 78C7AAF2CBC07D4979-802C
2 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0304
Revision: Serial number: 0000100888863
Coding: 011C42724008330C03
VCID: 45B91306CCB2D0A132-8010
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0118009212
Coding: 01001EA0003900210120038000000000
3 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 135696 km
Time Indication: 0
Date: 2021.11.25
Time: 11:01:55
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 135696 km
Time Indication: 0
Date: 2021.11.25
Time: 12:00:33
01519 - Bulb for Back-Up Lights; Right (M17)
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 135696 km
Time Indication: 0
Date: 2008.05.29
Time: 05:03:01
Address 47: Sound System (J525) Labels: None
Part No SW: 8F0 035 223 F HW: 8F0 035 223
Component: DSP Prem H03 0310
Revision: 00003001 Serial number: 34819000100500
Coding: 0203010302
Shop #: WSC 00046 000 00000
VCID: 237DAD9E22C6CE917C-8076
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0303
Revision: Serial number: 0000100911434
Coding: 011C42324008330C03
VCID: 44BF0E02C788E9A925-8010
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 G HW: 8K0 907 801 G
Component: EPB Audi B8 H08 0080
Revision: 00000003 Serial number: 10000000214050
Shop #: WSC 00000 000 00000
VCID: 335D5DDE92265E118C-8066
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000002
VCID: 77C5A9CE06DE723170-8022
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 P HW: 8T1 035 186 P
Component: Concert3 H02 0310
Revision: 00000005 Serial number: AUZ5Z6I1198095
Coding: 0403008201038508415B070800
Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
Component: Display
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8K0 959 795 E HW: 4F0 959 795 L
Component: TSG HL H10 0303
Revision: Serial number: 0000100940430
Coding: 010C02324008370C03
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
Component: Anhaenger H09 0100
Revision: 1A001001 Serial number: 00000150862253
Coding: 0100000000000000
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H10 0303
Revision: Serial number: 0000100940420
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 335 C HW: 8T0 862 335 C
Component: FSE_256x BT H33 0550
Revision: 00000000 Serial number: 00000005068777
Coding: 0010300
Shop #: WSC 02335 785 00200
VCID: 3A4370FA754CAF594F-806E
End-------------------------(Elapsed Time: 02:49)--------------------------
