Hej,
Har en Audi med dessa felkoder samt tänder den lampor för styrning, TPMS, ESP och nyckel. Vart ska man börja, säkring, kabel, något styrdon?
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Cannot be reached 0100
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 0010
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
VCDS
Self-Diagnosis Log
Saturday,04,January,2025,01:17:08:00009
Page 2
VIN: License Plate:
Address 01: Engine (J623-CLAA) Labels: None
Part No SW: 4G0 997 311 HW: 4G0 907 401
Component: 3.0TDI EDC17 H39 0002
Revision: 53H39--- CVN: F3F6438C
Coding: 1225401A053601020000
Shop #: WSC 65535 000 00000
ASAM Dataset: EV_ECM30TDI0114G0997311 001002
ROD: EV_ECM30TDI0114G0997311.rod
VCID: 69D908A38879EBC775-803C
VINID: 9D196AAAA1171947801861081495E10D62
3 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 293890 km
Date: 2025.01.04
Time: 01:03:07
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 67 °C
Intake air temperature: 6 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 11.920 V
Unlearning counter according OBD: 40
Cruise Control System (CCS): switch position-Bits 0-7: 193
Cruise Control System (CCS): status-Bits 0-7: 44
Cruise control switch-off: irreversible-Bits 0-7: 255
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise Control System: specified speed: 0.00 km/h
Engine control module reset status-Bits 0-7: 0
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [039] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 293890 km
Date: 2025.01.04
Time: 01:03:07
VCDS
Self-Diagnosis Log
Page 3
VIN: License Plate:
4482 - Function Restriction due to Implausible Message(s)
U1112 00 [039] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 293890 km
Date: 2025.01.04
Time: 01:03:07
Readiness: 0 0 0 0 X
VCDS
Self-Diagnosis Log
Page 4
VIN: License Plate:
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G1 927 156 J HW: 0B5 927 156 K
Component: 0B5 30 TDIRdW H08 0009
Revision: --H08--- CVN: 00009EC0
Coding: 000001
Shop #: WSC 04940 001 00001
ASAM Dataset: EV_TCMDL501021 001025
ROD: EV_TCMDL501021.rod
VCID: 3467A9D79F3B662F16-8060
1 Fault Found:
10618 - Valve for Transmission Fluid Cooler
P2755 00 [039] - Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 293890 km
Date: 2025.01.04
Time: 01:03:10
Engine RPM: 0 /min
Transmission input speed: 0 /min
Transmission output speed: 0 /min
Engine torque: -48 Nm
ATF temperature: 53 °C
Accelerator pedal position: 0.0 %
Clutch status: Beide Kupplungen offen
Voltage terminal 30: 11.600 V
Transmission oil cooler valve: closed
ATF temperature: 54 °C
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Revision: -------- Serial number: --------------
Coding: 07A68701E065E180FB00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004028
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 366393DF8947743F28-8062
No fault code found.
VCDS
Self-Diagnosis Log
Page 5
VIN: License Plate:
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 CN HW: 4H0 907 064 CN
Component: BCM2 2.0 H32 0421
Revision: 00002001
Coding: 01A93046000000000000
VCID: 77FD5EDBC6CD4D37F3-8022
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Serial number: 2312000183808013
1 Fault Found:
01128 - Immobilizer Pickup Coil (D2)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 114
Mileage: 293890 km
Time Indication: 0
Date: 2025.01.04
Time: 01:11:35
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 AE HW: 4G0 820 043 AE
Component: KLIMA 4 ZONEN H13 0076
Serial number: 23091200040392
Coding: 3612007821
ASAM Dataset: EV_AirCondiComfoUDS 002036
ROD: EV_AirCondiComfoUDS_002.rod
VCID: 62CB1F8F754FB89FB4-8036
VCDS
Self-Diagnosis Log
Page 6
VIN: License Plate:
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CF HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0130
Revision: 20012002 Serial number: 00000001384643
Coding: 2600E01040349FE00181008300001D0C0F98E70826090201000008606100
VCID: 6ED37BBFB9970CFF20-803A
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 120819 H36 0080
Serial number: 120907192914
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 20589552
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 24 09 2012 00000643
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0003
Serial number: 4D28CA46000000000001
VCDS
Self-Diagnosis Log
Page 7
VIN: License Plate:
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AG HW: 4H0 919 475 AG
Component: PARKHILFE ACC H01 0072
Revision: 11001001 Serial number: 61061226402345
Coding: 09C307
ASAM Dataset: EV_EPHVA18AU57X0000 003008
ROD: EV_EPHVA18AU57X0000_003.rod
VCID: 77FD5EDBCECD4D37F3-8022
1 Fault Found:
1079828 - Supply Voltage for Parking Aid Sensor(s)
B107A 14 [009] - Open or Short to Ground
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 114
Mileage: 293890 km
Date: 2025.01.04
Time: 01:03:07
VCDS
Self-Diagnosis Log
Page 8
VIN: License Plate:
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00ABU47
Coding: 30323436313330303431554A304C34473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
Crash sensor for side airbag: driver side:
Serial number: 3575HRB405D1HA3K7G87
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585HRB404P1HGMQ695$
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3515JRB405T1GLOO6PLW
Passenger side rear thorax airbag crash sensor:
Serial number: 3525JRB401G4UH26CH9I
Crash sensor for front airbag: driver side:
Serial number: 3554VRB40064ULPIBHKR
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB40064ULPIK0II
1 Fault Found:
1049600 - Databus
U1121 00 [137] - Missing Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 114
Mileage: 293890 km
Date: 2025.01.04
Time: 01:03:08
VCDS
Self-Diagnosis Log
Page 9
VIN: License Plate:
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20120925001150
Coding: 000015
VCID: 306FA5C763235A0F72-8064
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Component: E221 - MFL H08 0010
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 932 D HW: 4G8 920 932 D
Component: TDieRdw H79 0515
Revision: 28460207 Serial number: 658180912596000
Coding: 13A611000B4100080B0000
ASAM Dataset: EV_RBD4K 004046
ROD: EV_RBD4K_AU57.rod
VCID: 306FA5C76B235A0F72-8064
Address 18: Aux. Heat (J364) Labels:. 8R0-265-105.clb
Part No SW: 4H0 265 105 E HW: 4H0 265 105 E
Component: Standheizung H24 0260
Revision: 66006006 Serial number: 20120821204142
Coding: 5D3F01
VCID: 2447599727DBF6AF86-8070
VCDS
Self-Diagnosis Log
Page 10
VIN: License Plate:
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AA
Component: J533--Gateway H11 0035
Revision: -------- Serial number: 00000000691837
Coding: 00CD077D00
GVL: FDA1D840DC6460010000
ASAM Dataset: EV_GatewPkoUDS 001016
ROD: EV_GatewPkoUDS_001_AU57.rod
VCID: 71E960C3A0A913073D-8024
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790211335
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 120712000000000003B3
1 Fault Found:
4228 - No Communication with ABS Brake Control Module
U0121 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 114
Mileage: 293890 km
Date: 2025.01.04
Time: 01:03:07
Voltage terminal 30: 11.8 V
Voltage terminal 15: 11.8 V
Control Module temperature: 19 °C
System status: Terminal 15 on
IN ESP_standstill flag: standstill detected
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 0
VCDS
Self-Diagnosis Log
Page 11
VIN: License Plate:
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 J HW: 4G0 919 158 J
Component: KLIMA FOND H07 0076
Serial number: 21091200040634
Coding: 21
ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
ROD: EV_ClimaContrUnitRearUDS_002.rod
2 Faults Found:
0025 - Motor for Rear Left Upper Body Vent
B10D3 22 [009] - Signal Amplitude Too High
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 114
Mileage: 293890 km
Date: 2025.01.04
Time: 01:03:11
Voltage terminal 30: 11.95 V
Outside temperature: -3.5 °C
Left Rear Upper Body Vent Motor-Act.val.: 11701
Left Rear Upper Body Vent Motor-Target value: 11701
Left Rear Upper Body Vent Motor-Stop open: 11419
Left Rear Upper Body Vent Motor-Stop closed: 10000
0033 - Motor for Rear Right Upper Body Vent
B10D4 22 [009] - Signal Amplitude Too High
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 114
Mileage: 293890 km
Date: 2025.01.04
Time: 01:03:08
Voltage terminal 30: 11.93 V
Outside temperature: -4.0 °C
Right Rear Upper Body Vent Motor-Act.val.: 11701
Right Rear Upper Body Vent Motor-Target value: 11701
Right Rear Upper Body Vent Motor-Stop open: 11425
Right Rear Upper Body Vent Motor-Stop closed: 10000
VCDS
Self-Diagnosis Log
Page 12
VIN: License Plate:
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H02 0053
Revision: -------- Serial number: EJ1BPA7201HRCH
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA2 005011
ROD: EV_SARA2.rod
VCID: 3365AACB9A3561170F-8066
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0506
Coding: 011C16004000620002080002
VCID: 479DEE1BF6ADFDB743-8012
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0018891906
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 326BAFCF652F681F04-8066
1 Fault Found:
7343439 - Motor for Electric Power Steering
C10AE 13 [137] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 293400 km
Date: 2024.12.26
Time: 14:04:32
Write only channel
VCDS
Self-Diagnosis Log
Page 13
VIN: License Plate:
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0183442700
Coding: 013A062020B90000832009042001040F0000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0506
VCID: 4683E31FF1A7E4BFB8-8012
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 F HW: 4H0 907 801 A
Component: EPB-4 H03 0013
Revision: -------- Serial number: 00000000484511
ASAM Dataset: EV_ParkiBrake 001027
ROD: EV_ParkiBrake_VW51.rod
VCID: 2B55B2AB420539D747-807E
VCDS
Self-Diagnosis Log
Page 14
VIN: License Plate:
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Component: ....LWR12.... H02 0010
Serial number: 120924-0002-023
Coding: 1122A6101002A300
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic_AU21.rod
VCID: 2D51BCB37C1137E759-8078
1 Fault Found:
764928 - Left/Right Driving Switch-Over Active
C1080 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 114
Mileage: 293890 km
Date: 2025.01.04
Time: 01:03:07
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 4G0 035 182 K HW: 4G0 035 182 J
Component: RMC Cnct Plus H53 0775
Coding: 0100010001455B47083B060301010000010000
VCID: 295948A340F92BC7B5-807C
Subsystem 1 - Part No SW: 4G0 919 603 HW: 4G0 919 603
Component: DU6 Basic H42 0084
Serial number: 9464I20C2549663
Subsystem 2 - Part No SW: 4G1 919 610 B HW: 4G1 919 610 B
Component: E380 BDT C7 H11 0204
Serial number: 90349LIK000D4
VCDS
Self-Diagnosis Log
Page 15
VIN: License Plate:
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HL H03 0506
Coding: 010814004000620002080002
VCID: 4999E823E0B90BC755-801C
Address 69: Trailer (J345) Labels:. 4G8-907-383-V1.clb
Part No SW: 4G8 907 383 HW: 4G8 907 383
Component: Anhaenger H09 0100
Revision: 5G001001 Serial number: 00000184211715
Coding: 0109080000000000
VCID: 71E960C3A8A913073D-8024
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0506
End-------------------------(Elapsed Time: 04:54)--------------------------
VCDS
Self-Diagnosis Log
Page 2
VIN: License Plate:
3 Faults Found:
U1113 00 [039] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 293890 km
Date: 2025.01.04
Time: 01:03:07
U1113 00 [039] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 293890 km
Date: 2025.01.04
Time: 01:03:07
VCDS
Self-Diagnosis Log
Page 3
VIN: License Plate:
U1112 00 [039] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 293890 km
Date: 2025.01.04
Time: 01:03:07
VCDS
Self-Diagnosis Log
Page 4
VIN: License Plate:
Coding: 000001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 293890 km
Date: 2025.01.04
Time: 01:03:10
Engine RPM: 0 /min
VCDS
Self-Diagnosis Log
Page 5
VIN: License Plate:
Revision: 00002001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 114
Mileage: 293890 km
Time Indication: 0
Date: 2025.01.04
Time: 01:11:35
Coding: 3612007821
VCDS
Self-Diagnosis Log
Page 6
VIN: License Plate:
Coding: 0045F7
Coding: 02006D
VCDS
Self-Diagnosis Log
Page 7
VIN: License Plate:
Coding: 09C307
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 114
Mileage: 293890 km
Date: 2025.01.04
Time: 01:03:07
VCDS
Self-Diagnosis Log
Page 8
VIN: License Plate:
1 Fault Found:
1049600 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 114
Mileage: 293890 km
Date: 2025.01.04
Time: 01:03:08
VCDS
Self-Diagnosis Log
Page 9
VIN: License Plate:
Coding: 000015
Coding: 5D3F01
VCDS
Self-Diagnosis Log
Page 10
VIN: License Plate:
Coding: 00CD077D00
Voltage stabilizer:
1 Fault Found:
U0121 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 114
Mileage: 293890 km
Date: 2025.01.04
Time: 01:03:07
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
VCDS
Self-Diagnosis Log
Page 11
VIN: License Plate:
Coding: 21
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 114
Mileage: 293890 km
Date: 2025.01.04
Time: 01:03:11
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 114
Mileage: 293890 km
Date: 2025.01.04
Time: 01:03:08
VCDS
Self-Diagnosis Log
Page 12
VIN: License Plate:
ROD: EV_SARA2.rod
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 293400 km
Date: 2024.12.26
Time: 14:04:32
Write only channel
VCDS
Self-Diagnosis Log
Page 13
VIN: License Plate:
VCDS
Self-Diagnosis Log
Page 14
VIN: License Plate:
1 Fault Found:
C1080 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 114
Mileage: 293890 km
Date: 2025.01.04
Time: 01:03:07
VCDS
Self-Diagnosis Log
Page 15
VIN: License Plate:
0
0
0
0
