23 juli 2007
Har hittat ett slutsteg jag funderar på att köpa. Det ska driva två tolvor på 300wrms vardera. Så det lär nog funka, men någon som vet nått om detta steg är det bra???
Power! The new amplifiers from CARPOWER impress by an overall powerful performance. Solid heat sinks, top workmanship with high-quality connections, and last but not least PSUs and power amplifier circuits of very high power capability. The POWER amplifiers set new standards!
Car HiFi amplifier, 4 channels, 900W
4-channel power amplifier (2Ω stability) with adjustable low-pass and high-pass, can be bridged (2-channel, 3-channel, and 4-channel modes), high output power with an excellent radiation and perfect stability, also at high capacity utilization, var. bass boost, parallel line out (mono master), RCA line input and high level IN plug-in connection. The solid heat sink emphasizes the power capability of the power amplifier also with its appearance (POWER writing at the cut edge of the heat sink). Solid screw connections for power and speakers.
Technical Facts
Max. power: 900WMAX
RMS power 2Ω: 4 x 160WRMS
RMS power 4Ω: 4 x 100WRMS
Bridged power 4Ω: 2 x 320WRMS
Frequency range: 10-20,000Hz
Load impedance (min.): 2Ω (bridged: 4Ω)
Input sensitivity (line): 0.2-4V
Input sensitivity (high): 0.65-7V
Channel separation: > 40dB
S/N ratio: > 85dB (A)
THD: < 0.1%
Low-pass: 30-250Hz, 12dB/oct.
High-pass: 60-1,200Hz, 12dB/oct.
Bass boost: 0-12dB/50Hz
Operating voltage: 10-16V DC current /80A
Connections: screw terminals
Line: 2 x RCA L/R
High input: cable connectors
Speakers: screw terminals
Line: 1 x RCA L/R
Admiss. ambient temp.: 0-40 °C
Dimensions: 255x65x432mm
Weight: 5.8kg
Gatebil Mantrop 2007
