Swedenrockers skrev:
Power T40001bd - 4000 watt 1-channel amplifer
1500x1 @ 4 ohms, 3000x1 @ 2 ohms, 4000x1 @ 1 ohms.
Signal-to-Noise Ratio >80dB A-weighted @ 2Vrms
Crossover Slope 24dB/octave Butterworth
Crossover Frequency variable from 32Hz to 250Hz
Frequency Response 20Hz to 250Hz -3dB
Slew Rate 30 Volts/μS
IM Distortion (IHF) <0.05%
Signal Voltage Adjustment Range Variable from 150mV to 4V (RCA Input)
Protection Short circuit protection shut downs the amplifier in
case of very low impedance or shorted speaker wires.
Thermal switch shuts down the amplifier in case of overheating.
Equalization (Variable Punch Bass) Variable from 0dB to +18dB @ variable 35 to 70Hz
Input Impedance 10k ohms
Infrasonic Filter Selectable 12dB/Octave, -3dB @ 28Hz
BJonsson skrev:
Victorduvet skrev:
Kan släppa de för 8000
spec på steget?
orkar inte googla
