3589
Volvo racing 245 ! motorbygge !
114 Inlägg
17 mars 2011
innan jag börjat
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/DSC00068-Kopia.jpg
byggt fronten!
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/P5010815.jpg
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/P4130805.jpg
stag till fjäderben smile
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/P5010814.jpg
Motorn
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/P5010812.jpg
Blir en motor med starkare vev. h-profil. 531 topp planad portad stora ventiler och måne 7 kan smile lättat svänghjul!
lådan som ska i, 4vxlad m45
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/P5010811.jpg
baklås smile
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/P5010816.jpg
motorkuddar smile
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/P5010820.jpg
405 toppen
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/P5010821.jpg
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/P5010822.jpg
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/P5010824.jpg
portning av insprut
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/P5020008.jpg
polera mpste man smile
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/P5020005.jpg
rost
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/P5010817.jpg
allt för mig smile
FÅR HOPPAS INTE ADMIN TAR BORT MIN TRÅD BARA FÖR ATT DET ÄR EN FOLKRACEBIL OCH INGEN "VANLIG" BIL! TYCKER FOLKRACEBILAR SKA VARA TILLÅTNA HÄR! TACK PÅ FÖRHAND ADMIN! smile
114 Inlägg
17 mars 2011
Lagade lite mer rost !
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/DSC00065.jpg
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/DSC00064.jpg
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/DSC00063.jpg
lappa igen här med
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/DSC00049.jpg
Kofångarn!
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/DSC00057.jpg
överblick!
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/DSC00066.jpg
515 Inlägg
17 mars 2011
Ska det bli folkrace bil? lycka till:)
§9 Annonsering gäller även signaturen!
114 Inlägg
17 mars 2011
klart det ska bli smile dåra ?
1 314 Inlägg
31 mars 2011
Kan bli kul att följa wink
Lycka till wink
1 574 Inlägg
31 mars 2011
Om du nu ska bygga folkrace, varför lägga pengarna på h-profil stakar? lollol Inte bättre å lägga dom på ett par fina förgasare? roll
Ser väl bra ut annars om man räknar bort plastgrillen du satt dit..
114 Inlägg
31 mars 2011
Lycka till wink
tackar tackar smile mjo, ska bli en bil byggt till ngk masters 2011! big_smile
114 Inlägg
31 mars 2011
UPPDATE!!!
lite saker som landade i garaget nu i veckan smile
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/423633_jskpnt.jpghttp://i1219.photobucket.com/albums/dd435/Daniel_Garsten/bur_005.jpg
blir en 405 topp isf för 531 en. plat/port enemkam och stora ventilisar smile
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/IMAG0043.jpg
114 Inlägg
31 mars 2011
börjat måla lite smile
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/IMAG0023.jpg
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/IMAG0021.jpg
bara jag som gillar v70grillen ? smile
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/IMAG0022.jpg
även satt fast tank o batteri!
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/IMAG0020.jpg
1 574 Inlägg
1 april 2011
Va ska du sätta fast tanken mer i? såg klent ut med endast ett band och så långtfram
KHRacing
1 april 2011
batteriet måste väl sitta minst 20cm bort från tanken enligtreglerna ?
KHRacing
1 april 2011
går ju inte att sätta tanken längre bak liksom .. detta är ju varningstriangelsluckan längst bak.
114 Inlägg
1 april 2011
för h-profilsstakarna llåg hemma på en hylla, tyckte dom gjorde bättre nytta i bilen:)  förgasare är inte ett allternativ tycker jag. insprut blirmycket rappare och jämnare smile sen ska de varvas så e de bra med h-profil och nya lager roll
Senast redigerat av Volvo142turboo (1 april 2011)
114 Inlägg
1 april 2011
ja men det är cirka 18 cm. tror det går igenom annars får jag flytta på den smile
114 Inlägg
1 april 2011
tanken sitter kan ja lova wink ska på med ett till band över bakdelen, men hade inte hunnit det när jag tog kortet roll
1 574 Inlägg
1 april 2011
Jag syftade på att bandet som håller i tanken satt så långt fram.
Och va ja vet så är de inte nå 20cm som de ska va emellan, bara att de ska va 10cm emellan slang och kablar typ..
Sen går de ju få en förgasar bil att va rapp och gå jämnt, de är ju upp till dig hur du ställer i dom.. Wall kör ju med förgasare, kan ju inte klaga på att dom går kasst? roll
Senast redigerat av Brago (1 april 2011)
192 Inlägg
1 april 2011
gör inte den till folkrace big_smile gör en frän street bil eller nått wink
114 Inlägg
1 april 2011
Men wall är wall.... skillnad på motortrimmar proffs och "hemmatrimmare". visst förgarare är bättre om du har fräsha och riktiga och kan ställa in dom. hade en 245 me solex 45 er 531 topp port/plan stora ventiler och månen 8, extaktorgrenrör. den ville inte gå på grund av dom jävla solexerna. kör hellre på insprut och får en jämt och ren gång wink
114 Inlägg
1 april 2011
haha, naaa. lite sent nu kanske smile den ska byggas för att gå ngk 2011 och så ska de förbli wink
114 Inlägg
13 april 2011
UPDATE!!
inte hunnit gjort ngt med 245 då jag bytt koppling, växelåda och svetsat upp karossen på den andra folkraecbilen !
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/IMAG0069.jpg
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/IMAG0068.jpg
billyften kommer på fredag !
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/IMAG0049.jpg
go smäll
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/IMAG0046.jpg
MOTOR: b23 borrad t 2.5 L. 405 topp port/plan stora ventiler lättatsvänghlul enem kam mekaniskt insprut, extractorgrenrör. dåligt video men alltid något !
http://i1219.photobucket.com/albums/dd435/Daniel_Garsten/th_VIDEO0004.jpg
KOmmetera !
