Hycklaren skrev:
Kollat felkoder igen å
01237
00539
01176
Kan dessa vara boven?
Alldeles säkert.
01237 - Fuel Shut-Off Valve (N109): Malfunction
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Limp Mode / Reduced Power
Engine Stops suddenly
Possible Causes
Fuel Shut-Off Valve (N109) faulty/leaking/jammed
Possible Solutions
Check/Replace Fuel Shut-Off Valve (N109)
Perform Output Test
01237 - Fuel Shut-Off Valve (N109): Open/Short to Ground
Possible Symptoms
Possible Causes
Fuse(s) faulty
Wiring and/or Connector(s) from/to Fuel Shut-Off Valve (N109) faulty
Possible Solutions
Check Fuse(s)
Check Wiring and/or Connector(s) from/to Fuel Shut-Off Valve (N109)
Perform Output Test
00539 - Fuel Temperature Sensor (G81)
01176 - Key
01176 - Key: Signal too Low
Possible Symptoms
Possible Causes
Immobilizer
Wiring and/or Connector(s) from/to Immobilizer Reader Coil faulty
Immobilizer Transponder in Key faulty OR incorrect Transponder in Key
Remote Control
Remote Control Battery low
Remote Control faulty OR incorrect Remote Control used
Possible Solutions
Immobilizer
Check Wiring and/or Connector(s) from/to Immobilizer Reader Coil
Check Key Immobilizer Transponder Status
See Measuring Value Blocks (MVB)
Check/Renew Immobilizer Key Matching
Check/Replace Key
Remote Control
Check/Replace Remote Control Battery
Mvh Tommy
