17705/P1297/004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Power Loss
Possible Causes
Leaking Hoses and/or Pipes between Components
Boost Pressure Control Valve (N249) faulty
Diverter Valve faulty
Throttle Body dirty
Vacuum leak
Possible Solutions
Check Hoses and Pipes between Components
Check / Replace Boost Pressure Control Valve (N249)
Check / Replace Diverter Valve
Check / Clean Throttle Body
Perform Throttle Body Alignment (TBA)
Check for Vacuum leak(s) including PCV system
Special Notes
Did anyone install an extra (wrong) dump valve?
When found in the NAR 2.0T (BPY) check RVUTB: 01-09-03 or 2018919 for updated Crankcase Breather Valve
If the breather valve is faulty, full engine vacuum is typically found when removing the oil cap at idle.
When found in the 3B B5/B5.5 Passat 1.8T, check the PCV "bleeder valve" for example part number 06B-103-245
One way to troubleshoot the problem is to pinch closed the vent hose under the coolant bottle, that attaches to the bleeder valve and see if the idle smooths out.
Enligt mig; nej, 1.8t:s originaldump låter inte vidare mycket.
Men, som synes är där ju "lite att titta på" iaf
Senast redigerat av it_mutt (1 april 2015)
