Kungen-EssE skrev:
hur mycket kan ni egentligen???
BMW M3 CSL har slått rekordet på ringen
M3an e snabbast på ringen, 7minuter 22,9 sekunder.
så kom inte med era bugatti eller gt-r lr vilka ni syftar på
Hur mkt kan du egentligen??
Ser ut som loaded m3:an du syftar på.
inte orginal nånstans.
gine: 3,2 L Supercharged engine, new low-comp pistons,10,5:1 compression,
Vortec V2 Super silent with water-cooling system, extra oil cooling system, new fuel system with catch tank and Bosch fuel pumps. Extra oilcoolersystem with Modified oilfilter housing, Carbon fibre enginecover. Carbon fibre airinduct. 55 degrees water thermostat.
RWHP: 532,71 / 0.85bar / 98 oktan fuel
Torque: 483,67 / 0.85bar / 98 oktan fuel
Suspension: KW 3-way adjustable race kit
Chassie:
adjustable front camber plates
front springs 120 mm + helper
rear springs 100 mm + helper
prepared front wishbones
excentric caster bearing kit
3-way adjustable anti-rollbar + uniball thrust-rods
stiffer rear frame, changed kinematic points
aluminium bushings (frame)
aluminium bushings (final drive cover)
excenter uniball bearings (camber)
center uniball bearings (tow)
center uniball bearings (top arm outside)
stiffer rubber bearing top arm inside
aluminium machined lower arm + uniball bearings
2-way adjustable anti-rollbar + thrust rods
prepaired drive shafts + vent system
Frontbrakes: AP 6 pot caliper, PFC 355 mm Ø disc, PFC 01 race pads
INOX brake line system, brake vent system 80 mm Ø.
Rearbrakes: AP 4 pot caliper, PFC 323 mm Ø disc, carbon race pads, INOX brake line system
Frontwheels: BBS GT split, F18"x10 ET 40, 15 mm spacerdiscs, Tiresize 265/35/18”
Rearwheels: BBS GT split R18"x11 ET 35, 12 mm spacerdiscs, Tiresize 295/30/18"
Tires: Michelin pilot Sport Cup R tires
Rims: BBS Racing 18" Sandmold magnesium center with forge aluminium lane
Exhaust: Supersprint lightweight racing all the way.
Spec: 100% Stainless exhaust system, Oversize 2x Ø 60 mm
-Manifold. (LHD)
-Front pipes kit.
-Replaces Kat.
-Centre exhaust. 76mm LIGHTWEIGHT RACING EXHAUST
-LIGHTWEIGHT RACING EXHAUST Rear exhaust OO 80 R. + OO 80 L
Drive train/clutch: 3:91 ratio differential, Sachs Sinterclutch kit.
Exterior: Carbon fibre roof, hood, trunk, fenders, front and diffusor.
Interior: bolted rollcage light version (25 kg), adjustable Recaro race seat system with 6 points harness. A lot of carbon fibre interior as standard CSL
