1 februari 2008
Lite mera fakta om basen
Lightning audio s312-4
Elements 1-Way
Size 12"
Nominal Power Handling 300 Watt RMS
Powered Non-Powered
Technical Features
Peak Power Handling 900 Watt
Sensitivity 86.8 dB
Impedance 4 ohm (Dual Coil)
Components
Woofer Material Poly / Plastic
Surround Material Rubber
Mounting
Enclosure Non-Enclosed
Top Mounting Depth 5.75 In.
Mounting Diameter / Length 11.56 In.
Funkar det har steget tro???
Lightning audio FF250.1
250-Watt The Fast And The Furious Monoblock Amplifier:
Line or Speaker Level Inputs
Optional CT-1 Cooling Turbine
Variable 40-130 Hz Low-Pass Crossover
Variable 12dB Juice Boost Bass Enhancement Circuit
Chrome-Plated Top Cover
Included Remote Level Control
350 Watts Into A 2-Ohm Load
Senast redigerat av Xaos (1 februari 2008)
