7 december 2009
tja tja. tänkte kolla om ngn har tid för att räkna ut en låda åt mig,
bil: audi a6 kombi
bas speccs:
Fs (free-air resonance, Hz) 30.78
Vas (equivalent compliance, liters) 15.98
Qms (Q, mechanical) 3.63
Qes (Q, electrical) 0.42
Qts (total driver Q) 0.38
Re (DC resistance, ohms) 3.93
Z (nominal impedance, ohms) 2 x 2
Le (inductance, mh) 1.93
Efficiency (1W @ 1M, dB) 83
Xmax (one way linear excursion, in.) 1.0
Xmax (one way linear excursion, mm) 25
Pe (continuous power handling, watts) 1500
Peak power handling (music, watts)** 3000
Mms (total moving mass, grams) 261.93
Cms (mechanical compliance, mm/N) 0.102
Bl (motor strength, Tesla-M) 21.81
Sd (effective radiating area, sq. cm.) 333.3
Frequency range (Hz) 31-250
Energy Bandwidth Product (EBP) 74
Speaker Displacement (cu ft.) 0.1268
Mounting hole diameter (mm) 238
Mounting hole diameter (inches) 9.37
Mounting depth (mm) 214
Mounting depth (inches) 8.425
Magnet Weight (Oz) 263.7
tack på förhand//ronny
