2695
Volvo 740gl små styling första bil :-: dax att skrämma lite liv i motorn !
gammalt projekt
424 629 Visningar
Uppdaterades senast 22 augusti 2017
729 Inlägg
28 juli 2011
suddigt... men aa ny vs gammal
https://www1.garaget.org/gallery/images/153/152762/152762-05e771fcf5e1266de7deab5dfe4eb788.jpg
borta smile
https://www1.garaget.org/gallery/images/153/152762/152762-a3d43768cfaa09d7db8654e57b5de905.jpg
en styck drivaxel ute smile
https://www1.garaget.org/gallery/images/153/152762/152762-768a4d80ba3f9502ddac1f66f570e8d4.jpg
porr smile
https://www1.garaget.org/gallery/images/153/152762/152762-0efd0d1496fe64b5629936e987313e08.jpg
https://www1.garaget.org/gallery/images/153/152762/152762-c19e08a77c530fe1fb72542956099007.jpg
drivaxel tbx smile
gött med lift big_smile
https://www1.garaget.org/gallery/images/153/152762/152762-e601266565eec7018bfe8c4a10ad97ac.jpg
https://www1.garaget.org/gallery/images/153/152762/152762-845f87808ef830d20ae60c5c36252c2e.jpg
ett styck vad det nu heter ? bakaxelhållare? behöver bytas smile
https://www1.garaget.org/gallery/images/153/152762/152762-f6fa0860acf2cce02b88c2c4005c66ce.jpg
drivaxel tbx smile
https://www1.garaget.org/gallery/images/153/152762/152762-b5113c35f951eeae9abe396726af6ca4.jpg
skrot smile
https://www1.garaget.org/gallery/images/153/152762/152762-2452a469a2d78769f525dd6acecc746e.jpg
https://www1.garaget.org/gallery/images/153/152762/152762-b6e76eda25873a5327972369401e547e.jpg
https://www1.garaget.org/gallery/images/153/152762/152762-51b032bc11a758a65e1c2fd7e1843300.jpg
https://www1.garaget.org/gallery/images/153/152762/152762-9ec5119e8a70363660999a3e3ab30e4b.jpg
https://www1.garaget.org/gallery/images/153/152762/152762-2a521a40be54acee1ef05cb44b89b081.jpg
vakert smile
https://www1.garaget.org/gallery/images/153/152762/152762-cb2a6651b7ca06697913b4dba903b45a.jpg
https://www1.garaget.org/gallery/images/153/152762/152762-a754647a17071824ea29047ca840aad6.jpg
sista bild för idag nogot man inte kan klara sig utan smile
https://www1.garaget.org/gallery/images/153/152762/152762-209e8e547d8928586adcfbbaf2e7be3a.jpg
729 Inlägg
28 juli 2011
det som står på köplistan först nu är bakbromsok + slang bak h+v
och sedan nya stolar. har nu en ny fråga det finns ju 940 som har halvskin från fabrik passar dom i min 740 utan omyggnad???
komentera massor nu smile
Pim_Pim
28 juli 2011
#683
Ja de passar smile
729 Inlägg
28 juli 2011
Pim_Pim skrev:
Ja de passar smile
underbart smile
213 Inlägg
29 juli 2011
#685
Gött med fräscha delar! big_smile
Men inte slänger du spacers? :p
729 Inlägg
29 juli 2011
aa fan smile
ne ne inte dom smile
729 Inlägg
2 augusti 2011
hejsan har bara lite att berätta men tyvär inte några bilder ..
bytt bromsköldar,skivor,klossar,handbromsbackar v+h bak och skölda,skiva,klossar h fram inte klar med v än men när jag skulle tästa hur det kändes så sprack bromsslangen v bak :Pså blir till attt byta slangar bak kanske ok big_smile
och till lite roligare har kompisen en volvo 740 16-valve som han ska skrota så jag har fått elhissar,c-lås,el-speglar,glt/turbo rutor, sänkningsfjädrar bak, bakaxel upphängning, stora taklampan så kommer bli lite pill big_smile
Osponsrad
1 631 Inlägg
2 augusti 2011
#688
stora taklampan så kommer bli lite pill ??? vilken är det ? den med läslampor bakåt och en stor framåt ??
729 Inlägg
2 augusti 2011
ne läslampor fram och stora bakåt tongue
Fri fart för ett fritt folk!
14 223 Inlägg
2 augusti 2011
#690
baksätet passar inte från 940 eller passar och passar man får modda och sen får man göra ny hatthylla som är högre än orginal eftersom ryggstödet är högre på 940
men inte jättesvårt att modda dit så det klarar du utan problem
kolla mina bilder på min 740 så ser du hur det ser ut med baksätet från 944:an
729 Inlägg
4 augusti 2011
liten plåt kvar iallafall smile
https://www1.garaget.org/gallery/images/153/152762/152762-5be03567c586523202823b44750526ab.jpg
lackad för att skydda mot rost smilea
https://www1.garaget.org/gallery/images/153/152762/152762-167eab6337f34a1efd8b1b3ff2e3d574.jpg
nerslipad lite smile
https://www1.garaget.org/gallery/images/153/152762/152762-17e0c7a7a045c73698173ba661a57d4e.jpg
GLT/Turbo rutor
https://www1.garaget.org/gallery/images/153/152762/152762-039a6511bbff0175493dc0cdc79ea6e6.jpg
https://www1.garaget.org/gallery/images/153/152762/152762-63acf5196498e1337502fa7051484eeb.jpg
volvo smile
https://www1.garaget.org/gallery/images/153/152762/152762-971ed4022161701adef040fd4dba44b2.jpg
släpper på handbromsen lite:)
https://www1.garaget.org/gallery/images/153/152762/152762-2146d5259946e939a8b5b68039dd832c.jpg
en kass slang smile
https://www1.garaget.org/gallery/images/153/152762/152762-244c5333030614db119c6f5f72070507.jpg
skydda mot värmen smile
https://www1.garaget.org/gallery/images/153/152762/152762-74485ad580f276bfaa15c9a0d28ea53f.jpg
over and out big_smile
729 Inlägg
15 augusti 2011
nya slangar big_smile
https://www1.garaget.org/gallery/images/153/152762/152762-45145095885873a1d768062a3915e0fa.jpg
https://www1.garaget.org/gallery/images/153/152762/152762-578357fdf043bf6a25c00ba9e526e204.jpg
https://www1.garaget.org/gallery/images/153/152762/152762-f138ccca7a3228792c18314011a5bcc7.jpg
nya ok
https://www1.garaget.org/gallery/images/153/152762/152762-f73b84eca70533aaac9f9f18d7400b92.jpg
luftnuppel big_smile
https://www1.garaget.org/gallery/images/153/152762/152762-1951c5a1ea15078927648ac847f265dc.jpg
nya vad dom nu heter: P
https://www1.garaget.org/gallery/images/153/152762/152762-88a234e8adb7ce7e1f258e14b9fc953b.jpg
och sist men inte minst en ny bromsskiva big_smile
kan berätta lite med vad som har hänt jag har kopplat in el-hissar fran idag samt att jag har fixat sänkningsfjädrar bak till volvo 850 behöver bara skaffa den övre delen till 850 för den ska passa samt att jag fick en halvsats i rostfritt av en kompis och den stora taklampan monterad big_smile
729 Inlägg
19 augusti 2011
lite kasst med komenterer sad..
idag har jag tvättat och damsugit noga samt fixat elhissarna odentligt smile
och imon blir det att fixa ordning på bilden fixa allt det sista som fylla på lite olja glyckol en sista tvätt kontrolera allt det sista innan vallåkra smile
så kommer nog lite bilder imon har ju även kopplat in elhisar fram smile
729 Inlägg
19 augusti 2011
och om någon har dom listerna runt handtagen som är till elhissar fram svarta och ska till vallåkra på lördag får gjärna ta med sig dom om ni vill sälja om dom är hela för har en bkå på just nu hmm
1 168 Inlägg
19 augusti 2011
#695
ÅH!!! har en (förardörren), därimot är jag 100 på att jag slängde den förra veckan. men jag tar ett kik innan jag åker till vallåkra imorgon, har jag den så letar jag upp din bil på söndagen o lägger den vid din bil.
729 Inlägg
19 augusti 2011
helt underbart isåfall big_smile
177 Inlägg
19 augusti 2011
#697
du, ifall du får in några volvo org prylar hör av dig! köper troligtvis så släng förfan inte.... men bilen ser kanon ut far på vallåkra med dig direkt!
729 Inlägg
19 augusti 2011
något specielt du behöver eller smile?
729 Inlägg
19 augusti 2011
lite låg nivå tongue
https://www1.garaget.org/gallery/images/153/152762/152762-ca8b474790970cc6b2e9af825dabd8e7.jpg
nylammade smile
https://www1.garaget.org/gallery/images/153/152762/152762-e2a88c9f59625d7b1e160cecdb4bc212.jpg
https://www1.garaget.org/gallery/images/153/152762/152762-961350713552bbd0702ef56ec621f882.jpg
polering smile
https://www1.garaget.org/gallery/images/153/152762/152762-7942e6b449b339109aa7adc5f3f9dfa7.jpg
https://www1.garaget.org/gallery/images/153/152762/152762-42d1c489925901b277c68ea4b0628e5c.jpg
https://www1.garaget.org/gallery/images/153/152762/152762-57bc43369986ec7c9acb3c9df1954031.jpg
https://www1.garaget.org/gallery/images/153/152762/152762-1fe74b64cfb9dabae7c4621632bc62f7.jpg
https://www1.garaget.org/gallery/images/153/152762/152762-0138e7260debcb1bb6b5d32b84b16361.jpg
https://www1.garaget.org/gallery/images/153/152762/152762-cd3b15c3ce0157538babc3a74aebc8cb.jpg
https://www1.garaget.org/gallery/images/153/152762/152762-556b5daf5fe74ca7dd9704d0fa62c22d.jpg
https://www1.garaget.org/gallery/images/153/152762/152762-eb86fdad05f9e25b8e2d78ee8031f3fb.jpg
https://www1.garaget.org/gallery/images/153/152762/152762-3ce481ce8214e34061357547c77fb7e5.jpg
volvo orginal smile
https://www1.garaget.org/gallery/images/153/152762/152762-e9ed41e079c8455b52e6ebf8e9f63cd3.jpg
nya muttrat  smile samt några pinbultar smile
https://www1.garaget.org/gallery/images/153/152762/152762-0784cf55821072b5509a28cf51c8c50f.jpg
https://www1.garaget.org/gallery/images/153/152762/152762-b4a99164074ef2e467fcc02a0b90f658.jpg
R
https://www1.garaget.org/gallery/images/153/152762/152762-2fd3efd42f9b26d725c26cb814ee3a79.jpg
el-hissarmunterade smile
https://www1.garaget.org/gallery/images/153/152762/152762-a254ad2725a57f05ed7962923f98a78d.jpg
damsugit smile
https://www1.garaget.org/gallery/images/153/152762/152762-33a234dc04ac877d3aa0bfc1300c3e9e.jpg
älskar denna front smile
https://www1.garaget.org/gallery/images/153/152762/152762-9e64163ce11c35612c9fe69f242c9a41.jpg
komerntera masson nu för f*n big_smile
514 Inlägg
19 augusti 2011
#700
Snygg!
