2875
BMW E30 Street/TimeAttack (DTM style control arms)
-work in progress-
134 276 Visningar
Uppdaterades senast 22 augusti 2018
144 Inlägg
15 september 2013
Today I made the first version of engine mounts, I also attached gearbox behind the engine with a few bolts to be sure it fits. I had to shorten oilpan's sump a little bit to get whole package in a good position.
http://i187.photobucket.com/albums/x281/mice325/WP_001662_zps6c9c0114.jpg
Engine in it's place:
http://i187.photobucket.com/albums/x281/mice325/WP_001670_zpscd3399e0.jpg
http://i187.photobucket.com/albums/x281 … 2fce69.jpg
http://i187.photobucket.com/albums/x281 … 018f3b.jpg
Earlier this week me and my friend fixed the engine mount attachments from the block with a special welding stick, wasn't the easiest thing to weld:
http://i187.photobucket.com/albums/x281 … 266a38.jpg
http://i187.photobucket.com/albums/x281 … 415806.jpg
http://i187.photobucket.com/albums/x281 … d64f07.jpg
144 Inlägg
19 september 2013
Ran out of argon this week so I've done some sheetmetal work to the rear end with MAG.
Cut:
http://i187.photobucket.com/albums/x281/mice325/WP_001677_zpsaf6bff97.jpg
Paste:
http://i187.photobucket.com/albums/x281/mice325/WP_001691_zpsec41990c.jpg
http://i187.photobucket.com/albums/x281 … 85b1de.jpg
Should be roomy enough, wheel shouldn't ever reach that point when the shock absorber is mounted.
http://i187.photobucket.com/albums/x281 … 35d063.jpg
144 Inlägg
24 september 2013
Drivetrain almost acquired, only need to find suitable output shafts and of course there's a little bit of fitting. roll
TYP230 differential, 3.62 ratio:
http://i187.photobucket.com/albums/x281/mice325/WP_001717_zps78c69e88.jpg
http://i187.photobucket.com/albums/x281 … 404738.jpg
E60 M5 driveshaft compared to E30 320i driveshaft:
http://i187.photobucket.com/albums/x281/mice325/WP_001626_zps163a0741.jpg
http://i187.photobucket.com/albums/x281 … 4bb579.jpg
Did a place for the fuel cell:
http://i187.photobucket.com/albums/x281/mice325/WP_001711_zpsd9329389.jpg
http://i187.photobucket.com/albums/x281 … 3bc97f.jpg
Also front inner wheel arcs almost done:
http://i187.photobucket.com/albums/x281/mice325/WP_001725_zpsa2d1fbe5.jpg
http://i187.photobucket.com/albums/x281 … 788ea3.jpg
Feel free to comment!
Like and share our Facebook page, link below
wink
http://www.facebook.com/magnusracingteam
144 Inlägg
31 oktober 2013
Long time no see, time for a little update. smile
I've been working with the front end for a couple of days and this is what it looks like:
Route for engine bay hot air exit marked with the red arrows:
http://i187.photobucket.com/albums/x281/mice325/hotair_zpsb937cf32.jpg
From the other side, you can see the mounting points for removable strut brace.
http://i187.photobucket.com/albums/x281/mice325/WP_001784_zps1f39bf8e.jpg
Then the rear axle needs a little work too... neutral
http://i187.photobucket.com/albums/x281 … 13a945.jpg
I've ordered a water-to-air intercooler kit, the intercooler will sit right in front of the engine and the radiator in the trunk.
Picture of the kit, except I chose a bigger intercooler 400x310x115mm:
http://www.votionspeed.com/catalog/type1basic.jpg
Added a few pictures earlier of my 3D works to Facebook page:
https://www.facebook.com/magnusracingteam
-Iceen Garage-
772 Inlägg
4 november 2013
Sick!!! This is awesome!
Sponsorer: Spacer.se
ICEEN GARAGE
Följ gärna min projekttråd: http://www.garaget.org/forum/viewtopic. … 15&p=1
144 Inlägg
13 november 2013
Today's quick update:
Made this removable strut brace from 30mm pipe and it's fastened with four M12 bolts. Didn't weld it completely yet if I have to modify it later, hope not. roll
http://i187.photobucket.com/albums/x281/mice325/IMG_2908_zps3dd4cc93.jpg
http://i187.photobucket.com/albums/x281/mice325/IMG_2912_zps6d807827.jpg
Griffin radiator 26x19" to keep temperatures normal:
http://i187.photobucket.com/albums/x281 … c3e255.jpg
144 Inlägg
25 november 2013
Hello folks, got some new pictures of the project and it will soon look like a car I think yikes Lot's of sheet metal work done and the hardest part might be over now.
Fitted outer fenders:
http://i187.photobucket.com/albums/x281/mice325/WP_001815_zpsf865c0ac.jpg
Welded some sheet metal:
http://i187.photobucket.com/albums/x281 … 43cb17.jpg
Here's the engine bay ventilation solution:
http://i187.photobucket.com/albums/x281 … cdf183.jpg
Almost done:
http://i187.photobucket.com/albums/x281/mice325/WP_001850_zpsc8a3f67f.jpg
Water-to-air intercooler set also came one day:
http://i187.photobucket.com/albums/x281/mice325/IMG_2919_zps9f63885f.jpg
This is where I'll put the intercooler:
http://i187.photobucket.com/albums/x281 … 957785.jpg
And the IC radiator goes down there:
http://i187.photobucket.com/albums/x281 … a91685.jpg
That's all for this time, I'll try to keep the same rate through the winter despite of cold weather.
Doesn't anybody have anything to say? Även på svenska om det är svårt på engelska lol
Jag har samma tråd på PPF forum och det är lika tyst... roll
102 Inlägg
25 november 2013
fyfan vilket grymt jobb du lägger ner! otroligt bra jobbat!
144 Inlägg
3 januari 2014
I'm a little bit excited because I should get this car on track next year!! tongue Lots of work to be done, lots of hours at the garage..
I installed top mounts to the chassis right after christmas:
http://i187.photobucket.com/albums/x281/mice325/WP_001883_zps9472fcd7.jpg
After that I started to build the rear axle, parts fitted to the jig:
http://i187.photobucket.com/albums/x281 … f3e87a.jpg
Things seems to fit, but it's a little tight there:
http://i187.photobucket.com/albums/x281 … dd5a91.jpg
Today I continued with the differential cradle, 90% done:
http://i187.photobucket.com/albums/x281/mice325/WP_001922_zps0190e22e.jpg
http://i187.photobucket.com/albums/x281 … b33f79.jpg
29 Inlägg
3 januari 2014
ser riktigt bra ut!
144 Inlägg
14 januari 2014
Tack tack! smile
Differential/carrier mountings done, I'll put a 25mm aluminium spacer/bushing between chassis and carrier:
http://i187.photobucket.com/albums/x281 … 2b7aeb.jpg
http://i187.photobucket.com/albums/x281 … 897417.jpg
Jig for the rear trailing arm for welding camber and toe adjustment parts:
http://i187.photobucket.com/albums/x281/mice325/WP_001968_zps38511672.jpg
http://i187.photobucket.com/albums/x281/mice325/adjusting_zps8aa6f0a0.jpg
I should also get these from machining, carrier big ends:
http://i187.photobucket.com/albums/x281 … 4918c6.jpg
144 Inlägg
19 januari 2014
Time for a sunday update smile
A few new ideas which I decided to fulfil:
http://i187.photobucket.com/albums/x281/mice325/WP_001976_zps085c56e6.jpg
Earlier I though to arrange parts this way, but seems there's no enough room for the radiator:
http://i187.photobucket.com/albums/x281 … 84aa0b.jpg
So I started to create mounts for the front end parts:
http://i187.photobucket.com/albums/x281/mice325/WP_002003_zps10e6d9e2.jpg
Mounting points:
http://i187.photobucket.com/albums/x281 … e71943.jpg
Hood with a figure to show where radiator hot air comes out:
http://i187.photobucket.com/albums/x281 … 77e806.jpg
Pipes welded together:
http://i187.photobucket.com/albums/x281 … dcb427.jpg
I also welded a sidemount turbo manifold and V-band outlet for my friend's Mazda Miata:
http://rs187.pbsrc.com/albums/x281/mice325/WP_001996_zpsbd084598.jpg~c200
52 Inlägg
19 januari 2014
Ser skitbra ut!
Prem lagd! smile
144 Inlägg
2 mars 2014
Lite har hänt igen... tongue
I got this order from my friend a while ago, including rear trailing arm adjusting parts, rear axle carrier big ends and rear upper spring plates. 25 row oil cooler beneath:
http://i187.photobucket.com/albums/x281/mice325/WP_002059_zpse72aaebb.jpg
Coilover assembly:
http://i187.photobucket.com/albums/x281 … 2a1f76.jpg
This weekend I built rear trailing arms ready, first I fitted parts to the jig, then made sure it sits in the rear axle carrier:
http://i187.photobucket.com/albums/x281/mice325/WP_002289_zpsa72b8dc2.jpg
Welding:
http://i187.photobucket.com/albums/x281/mice325/WP_002305_zps0c4217ba.jpg
http://i187.photobucket.com/albums/x281 … e3474e.jpg
Next thing is to modify mounting points of the carrier, including roll center correction etc..
129 Inlägg
2 mars 2014
Ser riktigt bra ut!
144 Inlägg
4 april 2014
Recently I modified the axle carrier mounting points to meet the modified trailing arms:
http://i187.photobucket.com/albums/x281/mice325/WP_002335_zpsbf373928.jpg
Carrier is now almost finished, only a pair of extra fastening to the chassis needed..
Today I played a little with TIG AC mode, changed the oil filler cap location:
http://i187.photobucket.com/albums/x281/mice325/IMG_3200_zps18aab249.jpg
http://i187.photobucket.com/albums/x281 … b82129.jpg
It's a strange alloy or maybe it has sucked oil in itself by time, here's another try with pure alu plate:
http://i187.photobucket.com/albums/x281 … fa4658.jpg
Tüsk / JDM
262 Inlägg
6 maj 2014
Nice Project, Dunno if you prefer to speak swedish or english but i'll bet its english wink
Why dont you "Imgtag" all your pics? Some pics show right away and some are just links tongue
144 Inlägg
6 maj 2014
Hi Jimmy,
Both languages are ok, but English feels a little easier big_smile I "imgtag" main pictures and all extra pics are just links. If you like to see more of the object, just click the links below..
Also some people read these threads with mobiles or just have a slow connection, so I try to make their lives easier.
